 Does anyone have rear disc setup?
PostSubject: Does anyone have rear disc setup?   Thu Jun 20, 2013 8:29 pm
I picked up another "substitute rear" for now so I can continue beeting on the car at the track and learning this whole tuning thing...
Anyways...doese anyone have the rear disc backing plates? Preferably an entire setup (backing plates, calipers, rotors and etc)....but at this point I would settle for just the backing plates asap!
Anyone????
PostSubject: Re: Does anyone have rear disc setup?   Fri Jun 21, 2013 12:07 am
Sorry if I'm thread jacking, but since we, as a community, seem to be stuck on 9C1 or SS backing plates, are there ANY other compatible alternatives??? OTHER GM backing plates?
How hard is it to machine/drill holes to make copies?
PostSubject: Re: Does anyone have rear disc setup?   Fri Jun 21, 2013 5:21 pm
As far as a direct bolt on, the only vehicles that share the same housing ends as out 8.5 10 bolts are some of the full size trucks with the 8.5.
We utilize a different housing end then the g-bodys, camaros or novas that came with the 8.5, so there aftermarket brackets are useless to us.
I have not personally measured, but I am inclined to think that the 14 bolt full floaters may use the same housing ends, which would allow us to use some of the new style Silverado/ Sierra disc brakes, but I can't confirm that just yet.
Regardless....you would have to redrill the 5x5 bolt pattern into the rotor hat.
As far as taking an existing backing plate and machining our housing end pattern into.....that may be a possibility....
EDIT I just looked up the housing end dimensions for us vs the small gm (traditional 8.5 and 7.5 f-body guys).
There is not enough material to redrill the holes if you compare the two bolt patterns in this chart. We would need to start fresh with a new bracket which isn't the end of the world....it's doable.
http://www.jegs.com/photos/800/873/873-axlehousingendform.gif
PostSubject: Re: Does anyone have rear disc setup?   Fri Jun 21, 2013 5:32 pm
Good info. Good discussion so far. Even tho its a WTB thread.
I figured I'd say something HERE because you are an outside of the box kinda guy and would actually get feedback.
Sitting waiting for an impala ss rear to show up will cause more wrinkles on my forehead.
If "simply" getting some raw stock and making OEM spec backing plates is doable, sign me up.
I'm not going to take apart my 9C1 rear and swap everything over to a "civi" rear. I'd rather just spend the time/money and have both.
Just my .02 on the subject.
PostSubject: Re: Does anyone have rear disc setup?   Fri Jun 21, 2013 7:27 pm
You got me thinking so I was doing some research.....I "THINK" trailblazer and envoy rear disc brakes would be a direct bolt on if you have the 5x5 patteren drilled in the rotors.
The rotors are almost 13" and the calipers are aluminum single piston.
You would need....
http://www.rockauto.com/catalog/moreinfo.php?pk=391034&cc=1432192
http://www.cardone.com/Products/Product-Detail?productId=18B4804&p=rock
http://www.rockauto.com/catalog/moreinfo.php?pk=2721236&cc=1432192
I am almost positive that is the same housing end as the 8.5 large patern.
I imagine these things are a dime a dozen in the salvage yards too (making sourcing the parts quick and easy on the cheap. (as long as you know a competent machinist to put the right bolt pattern in your rotor).
PostSubject: Re: Does anyone have rear disc setup?   Fri Jun 21, 2013 7:47 pm
So there ARE alternatives.
Now what about, I'm talking strictly 91-96 B body here (all stock 5x5), duplicating the backing plate of this 8.5 10 bolt.
Unless I'm missing something, you could just go buy the appropriate OEM calipers and what not to make it work since the plate isn't something you can just buy. Then of course, there's the parking brake etc etc.
The reason I bring this up, is the ridiculous plaque of the narrow rear axel on a 9C1.
Instead of waiting and paying a mint for a disk brake rear for an SS, and paying a mint, get a civi axel, put on said machined plates and build your brakes.
Maybe I'm making it too difficult (even for myself)
PostSubject: Re: Does anyone have rear disc setup?   Fri Jun 21, 2013 9:20 pm
No....actually that makes sense.
The problem with machining a backing plate that uses the stock 9c1/ss calipers, would be the integrated parking brake shoes.
I think the best way to approach this project would be to purchase regular 5x5 impala rear rotors, and use "LT1" 4th gen f-body calipers. (where the caliper is the parking brake).
This way I could machine up a backing plate with the correct spacing for the impala rotor to mount up the f-body caliper and be done. Seems like it would make for a nice little setup too.
PostSubject: Re: Does anyone have rear disc setup?   Fri Jun 21, 2013 10:13 pm
Well there you go.
Maybe your problem is solved.
PostSubject: Re: Does anyone have rear disc setup?   Sat Jun 22, 2013 9:32 am
Contact Bill HArper for backing plates
PostSubject: Re: Does anyone have rear disc setup?   Sun Sep 29, 2013 6:28 pm
Figure out how to get them working?
Also, check out these brackets. Both use the Impala SS rotors, and are designed for the large end truck 8.5 axles.
http://www.67-72chevytrucks.com/vboard/showthread.php?p=3259777
http://www.67-72chevytrucks.com/vboard/showthread.php?t=382633
PostSubject: Re: Does anyone have rear disc setup?   Sun Sep 29, 2013 7:15 pm
Now that is a good set of links! It's funny how truck guys can come up with this stuff, but its kinda hard to get out of B body guys.
Thanks for the links!
I have not come up with anything myself since I basically just left it at this thread.
PostSubject: Re: Does anyone have rear disc setup?   Sun Sep 29, 2013 7:40 pm
http://nh.craigslist.org/pts/4066553654.html
Found these on cl the other day. I drive that way at least once every month. Just throwing it out there. The guy has 2 axles with backing plates.
PostSubject: Re: Does anyone have rear disc setup?   Sun Sep 29, 2013 9:14 pm
Yup. That stuffs been posted when I was looking for an SS rear end (got one today)
I posted if anyone could grab one for me aaannnnnd nothing. So hopefully you can help him out.
PostSubject: Re: Does anyone have rear disc setup?   Sun Sep 29, 2013 10:25 pm
Well, I'm just want to see if I can make the Impala SS backing plates fit my 86 C10 rear axle. Altho, I could go the Camaro caliper route seeing as I have a Camaro with no engine and rear disc sitting around......
» 9c1/SS rear disc brakes
» Caprice or Impala Rear End
» FODEN REAR SPRINGS
» GN rear window mod
» roadmaster rear 8.5"?
