| Subject: if caprice's could fly Wed May 01, 2013 7:44 pm | |
| wtf http://www.theday.com/article/20130430/NWS04/130439967/1070/FRONTPAGE | |
| Subject: Re: if caprice's could fly Wed May 01, 2013 8:01 pm | |
| Subject: Re: if caprice's could fly Wed May 01, 2013 8:56 pm | |
| Was clean , no belt line trim either. | |
| Subject: Re: if caprice's could fly Wed May 01, 2013 9:44 pm | |
| Further proof that women CANNOT drive.
Btw, it was the car, ironically, that saved her life. Not the tree.
And yes, it is a highly laughable matter. Her "I tried park neutral everything whatever" b.s. makes no sense to me. | |
| Did you see the entire driver's side lower quarter panel cut out? Wonder what could of caused it if her story is true...she's probably just a dumbass though, there are so many options in that situation! EDIT: Looks like the rear pass. side frame rail is completely broken off right after the rear wheel, you can see it in the tank strap pic, and the one showing the car from the front, pretty bad... | |
| Subject: Re: if caprice's could fly Thu May 02, 2013 7:48 am | |
| She's a dumb ass. Unless the clutches welded together in the trans disabling neutral she just has no idea how to drive a car. Probably had a Camry with a floor shift, wrecked it and has no idea how to use a column shift | |
| Subject: Re: if caprice's could fly | |
