| | Gear discussion? | |
| Subject: Gear discussion? Sat Apr 27, 2013 11:04 pm | |
| I've been reading quite a bit online about rear end ratio swaps. With tire size being a factor in the overall use of the gear set, I'm a little puzzled.
I'd like to hear what members HERE know and/or personally experience.
My interest is going 3.08 to 3.42. 3.42 actually depending on tire size in the end.
I've got the CAI, effed up car back with H pipe, and about a 26" tall tire.
FUTURE (not tomorrow) mods will include headers, cam, and head/valve work, PCM tune.
The car is already super light I believe since ditching the factory exhaust, steel rims with 225s, no window motors, no seat motors, drivers air bag, 9c1 seats with steel plates, etc etc. not a lot of wires running this way and that. I even think the new hood weighs less. Hell, even the springs weigh less than the 9C1 stockers. I'm not saying its a feather, but more than likely lighter than an impala or loaded b4u.
Anyway...
I'm not looking for a race car, but enjoy stop light racing and passing mustangs on the highway.
MPGs aren't a HUGE concern, but I do get great mileage now, since I've owned the car.
Thanks for your input. | |
| | | sdstick
| Subject: Re: Gear discussion? Sat Apr 27, 2013 11:27 pm | |
| My original SS had 3.08's My 96 has 3.42 My new DD has 3.73 I've driven most of the time on SS wheels w/ 40 & 50 series 275's & 255's I've found that all of the above allow for way more top end then you can regularly use Meaning...how frequently do you go 100+? So....my sugggestion is 3.73 MIN.....I'll be going 4.11 if I can ever get a rear built. Gas mileage?....if your mileage is good now....you wont regret gears.
Youre not going to be scary quick UNTIL you do the heads cam At THAT point, your gonna have trouble hooking up anyway
I've never really been able to tell the difference tire diameters make...havent changed much tho | |
| | | bfurches
| Subject: Re: Gear discussion? Sat Apr 27, 2013 11:30 pm | |
| Given that you are running an OD transmission you have a lot of choices....
If I remember correctly....4l60e had an OD of .696:1 so let me give you an idea of where you would be RPM wise based on your gears...
Right now with a 3.08 at 2k rpm in OD you should be cruising at 72mph
With 3.42 at 2k rpm, you will be at 65mph
...and if you went with something like a 3.73, you would be down to 60mph
Me personally.....if I was running an OD trans and wanted the most out of my car from stop to stop....I would run the 3.73s as a good compromise. At 75mph you are still only turning 2500rpm which isnt god awful, you should be able to maintain some of that fuel economy, and the car should really wake up around town and off mid throttle gallops.
If you went to a 28" tire, the rpms would be much closer to what you would experience with 3.42s on your 26's, but obviously that comes with added weight, more rotating mass, and a larger tire to turn which would most likely negate some of your new gearing until you start making more power.
Sorry if this seems like rambling...im tired lol. | |
| | | bfurches
| Subject: Re: Gear discussion? Sat Apr 27, 2013 11:31 pm | |
Shoot me a text tomorrow Steve. | |
| | | bfurches
| Subject: Re: Gear discussion? Sat Apr 27, 2013 11:36 pm | |
| - MASShole9C1 wrote:
- I've been reading quite a bit online about rear end ratio swaps. With tire size being a factor in the overall use of the gear set, I'm a little puzzled.
Think of it kinda like this.....the taller the tire....the more gear you are essentially taking out of the car. A smaller tire will spin much faster.... example.... 26" tire effectively spins 793 times per mile 28" tire effectively spins 743 times per mile a 28" having a larger overall circumference will always cover more distance per axle revolution then a 26" on the same gear...basically meaning the shorter tire will always cover less distance (requiring more rpm to cover the same distance as said taller tire). | |
| | | MASShole9C1
| Subject: Re: Gear discussion? Sun Apr 28, 2013 12:23 am | |
| Thanks guys! This is good stuff right here! Exactly what I'm wanting to learn. | |
| Subject: Re: Gear discussion? | |
