Up first is a set of gauges (RPM and water temp) and a bezel already opened up. I bought these from a guy who used them in a '95 SS. I'll throw in the correct PCM pin with white wire to splice the RPM in to. $45 shipped
Next is so strobe lights. These are excellent and bright! I used them at work on a CVPI. Rubber grommets secure them in a hole you drill. I have the appropriate drill bit I will include as well. Almost forgot! theres a one touch 20 different strobe pattern on the lighter plug. SOLD
Lastly, I have a set of 6K HIDs. Control box and harness are in new shape. Only used for a year (rarely driven at night). I took them out for inspection, no hi beam option tho it does turn a different color
. It looks like the ballasts MIGHT need to be replaced tho. Not sure. For that reason, $25 shipped
Thanks for looking. I DO accept Paypal.
