 Replacement Rear
PostSubject: Replacement Rear   Thu Jun 11, 2009 9:23 pm
Turned Matt loose with some POR15 & caliper paint
OK I helped a little while it was at the shop cause Matts all finish & no prep
But its fine for the 95 daily driver. Yes he HAD to have red calipers
Forgive the cell phone pic
PostSubject: Re: Replacement Rear   Thu Jun 11, 2009 10:42 pm
lookin good, its nice to have it all cleaned b4 the install.. btw i noticed that theres no H rattle clip thingie that goes across the top brake pads
PostSubject: Re: Replacement Rear   Thu Jun 11, 2009 10:48 pm
Sweet! Is that silver POR15?
PostSubject: Re: Replacement Rear   Thu Jun 11, 2009 10:56 pm
She looks sexy!
PostSubject: Re: Replacement Rear   Fri Jun 12, 2009 6:01 am
I couldnt see it here either but its in there hiding just inside the outboard pad
Yup, got 1 of those mixed 6 packs so he could play. 2 black, 2 silver & 2 clear
I wanna say theyre 4 oz cans (tiny) but 1/2 can did the whole thing (& he didnt spill... WOOT)
They sent me 1 gray(must of been packed just after coffee break)
I'm just waiting to see what braking will do to the extra he got around the rotor
My 95 has been neglected forever so I'm sure It'll be happier either way
PostSubject: Re: Replacement Rear   Fri Jun 12, 2009 10:52 am
Sweet. Smile
Paint makes everything better.
(Whether it's shiney or not Wink)
impss
PostSubject: Re: Replacement Rear   Fri Jun 12, 2009 9:01 pm
Looks great. I have been wanting to paint up my calipers also, what kind of paint did you use and where did you get it?
PostSubject: Re: Replacement Rear   Fri Jun 12, 2009 10:13 pm
I bought the silver POR15 caliper kit but NOoooooooooo my son NEEDED red so I just picked up a Duplicolor kit at AZ.
FYI just buy the caliper paint in a can cause the package had a small acid brush (worthless unless your an Arteest) about 6ft of masking tape & a can of spray caliper cleaner that was just relabeled brake cleaner. I think it was like $35. They do give you plenty of paint. No idea how it'll hold up
The POR15 kit has cleaner, metal prep, paint, masking tape, 2 pair of gloves....BUT theyre not shy with the price, I'm thinking it was about $50
PostSubject: Re: Replacement Rear   Thu Jun 18, 2009 8:54 pm
If any of you want lime green alien or purple confused or pink queen calipers here you go...
http://paceperformance.com/index.asp?PageAction=VIEWCATS&Category=10395
Replacement Rear
» Replacement rear quarters
» Rear end Gear ratio's?
» Cox Baja Bug rear tires
» Question on rear main seal... LT1 guru's this is for YOU
» TJ 2.5L Rear Main Seal --- HELP!
