 I put duals on my 9c1 4.3 now it's surging
Evan7796
PostSubject: I put duals on my 9c1 4.3 now it's surging   Thu Feb 28, 2013 8:16 pm
So here's what happened I only bought this car in December and as soon as I got it the blower motor quit,
So I work out of town so I figure what ever I'll get it fixed at one of the local muffler shops while I'm gone and get them to put a nice tight exhaust system on to replace that ugly stock pipe with the second silencer hanging down off the back fender
So I get it home runs good but surges a little at idle but not always then ran good for two weeks.
Flash to yesterday, I'm going through town go to park and when I put it in park it revs up to 3kor so for a few seconds then idles fine but when in gear it's ideled up and pulls forward on the brake a little.
Now if I'm in park or nuetral and it ideling normal it stalls when I put it in gear unless I giver on the throttle
And just so you know the system I had made is 2.5" straight duals no cats cause in Canada you don't need them to knock off flowasters.
Just wondering if you think it's exhaust related also some told me that I might need to have it reprogrammed? And then some one else told me it would take some time but the car would relearn how to run the nEw exhaust, is that true or just stupid?
Thanks for reading take care
PostSubject: Re: I put duals on my 9c1 4.3 now it's surging   Thu Feb 28, 2013 9:32 pm
When you removed the cats you messed up the rear O2 sensors being able to read clean exhaust causing the PCM to make the engine run lean thinking it's getting too much fuel. You need to put cats in it or reprogram the PCM.
Only 96's have this issue.
Evan7796
PostSubject: Re: I put duals on my 9c1 4.3 now it's surging   Thu Feb 28, 2013 9:43 pm
Ok good to know
Is getting a reprogram expensive? Also any ideas on how to find someone to do it?
PostSubject: Re: I put duals on my 9c1 4.3 now it's surging   Thu Feb 28, 2013 9:45 pm
Www.pcm4less.com
Usually around $100 or so I think. But don't quote me on that.
PostSubject: Re: I put duals on my 9c1 4.3 now it's surging   Thu Feb 28, 2013 9:48 pm
Welcome
Another option...better communication (not that PCM4less isnt good)
http://www.pcmperformance.com/programming.html
Evan7796
PostSubject: Re: I put duals on my 9c1 4.3 now it's surging   Thu Feb 28, 2013 9:58 pm
Awesome I'll check out both sites
Thanks for the imput guys!
PostSubject: Re: I put duals on my 9c1 4.3 now it's surging   Fri Mar 01, 2013 5:16 am
Welcome
+1 Arrow
Evan7796
PostSubject: Re: I put duals on my 9c1 4.3 now it's surging   Mon Mar 04, 2013 3:53 pm
Hey toomanytoyz do you know why only 96 has these issues because I'm not getting an o2 code on the car and I had a couple techs say that curing the cats off shouldn't be causing this problem
but the car is getting worse
Thx
PostSubject: Re: I put duals on my 9c1 4.3 now it's surging   Mon Mar 04, 2013 4:30 pm
Some correct me if I'm wrong, but aren't the rear O2's strictly to tell the PCM if the cats are working? My 9C1 has sims on he rear because the cats are gutted. Regular sensors just throw a CEL sayinh "catalyst efficiency is below threshold".
I know that having a bad front O2 will cause the car to run like total garbage. My Caprice wagon did that but only threw a code for a failed sensor after a ton of driving with it like that. Did the 4.3 have dual front sensors from the factory?
PostSubject: Re: I put duals on my 9c1 4.3 now it's surging   Mon Mar 04, 2013 5:04 pm
Or to build on that
Did they reinstall the existing?
Evan7796
PostSubject: Re: I put duals on my 9c1 4.3 now it's surging   Tue Mar 05, 2013 12:49 pm
Not sure about how many It had stock but was pretty sure they went back in I'm goin to go take a look to see how many I can find
Evan7796
PostSubject: Re: I put duals on my 9c1 4.3 now it's surging   Wed Mar 06, 2013 9:33 pm
PROBLEM SEEMS SOLVED
So we got a foot of snow 2 nights ago and with the high idle issues that have plauged me as of late I'd put my car in gear and the tires imedetely shoot to 15 mph, so there was no feathering the throttle it would just stall, so eventually and inevitably I got stuck came off the drive way blah blah blah blah.
So we're pulling me out /hooking it up and I get in the car and the engine temp is WAY up but no electric fans going hmmmmmmm I thought well I guess the coolant temp sensor is gone.( I know enough to figure that out lol) so i call a buddy asked him to pick up the sensor for me and filled him in on my issues, he says to me well maybe that is part of the issue because if the temp sensor doesn't read the motor coming to temp it won't start reading the o2 sensors. (now I'm learning!) changed the sensor added some anti freeze changed the air filter, runs like a dream! Cost 40 bucks with the air filter.
Sweeeeeeet!!
Thx everybody for your imput!
PostSubject: Re: I put duals on my 9c1 4.3 now it's surging   Wed Mar 06, 2013 11:23 pm
Good job finding that one. I never had one go bad myself, but I do at times have a loose connection to the one in my Caprice. Now that I think of it it does cause it to just about stall when it open circuits.
Evan7796
PostSubject: Re: I put duals on my 9c1 4.3 now it's surging   Thu Mar 07, 2013 12:35 am
Yeah first time I've been so happy to get stuck
Keeping me a'learnin!
PostSubject: Re: I put duals on my 9c1 4.3 now it's surging   Thu Mar 07, 2013 8:27 am
My coolant temp sensors always break where the connector plugs in. I just bend the pins away from each other ad that holds the connector on good enough Arrow
PostSubject: Re: I put duals on my 9c1 4.3 now it's surging   Thu Mar 07, 2013 8:53 am
Good that you found it & GREAT that posted it up
I always hated reading thru a thread about a problem, getting to the end & the OP didnt include the fix.
» LA golden demons
» The "MONSTRO" Build Thread
» 350 TBI Surging/ Stalling
» Goldberg "Ranger 42"...Like I NEED another project !
» Surging Dragon Knight Dragoequites
