» 2019 Twelfth Annual B & D Roundup!! Mark your calendar! Saturday October 19th
F/S 2000 GTP silver mist coupe EmptySat Sep 07, 2019 7:36 pm by bigbluey88
F/S 2000 GTP silver mist coupe EmptyThu Aug 08, 2019 9:41 am by CrashMaster
» 1984 Caprice project
F/S 2000 GTP silver mist coupe EmptySun Jun 30, 2019 8:05 pm by Boxchevy84
» C10: Before and After
F/S 2000 GTP silver mist coupe EmptySun Jun 02, 2019 3:01 pm by MalibuSSwagon
F/S 2000 GTP silver mist coupe EmptySat Mar 16, 2019 8:49 am by boojum
» Mass refugee now in Pa
F/S 2000 GTP silver mist coupe EmptyTue Jan 22, 2019 8:46 am by MASShole9C1
F/S 2000 GTP silver mist coupe EmptyTue Jan 22, 2019 12:03 am by boojum
» 1996 DGM RMW
F/S 2000 GTP silver mist coupe EmptyFri Jan 18, 2019 12:00 pm by Gorillabiter
September 2019
Share
PostSubject: F/S 2000 GTP silver mist coupe   F/S 2000 GTP silver mist coupe EmptySat Jan 19, 2013 10:42 pm
Hey guys. My wife is selling her GTP coupe. Purchased used two years ago next month, it has served her well. It is silver mist metallic with 179k.
Options include:
Leather
P/drivers seat
Sunroof
Bose am/fm cd
Heads up
Chrome torque stars
Over all condition:
Glass is good
Interior is near perfect
Body is solid with some scratches, and dings
Runs good
shifts good
No CEL
Mods include
Suncoast ramair hood with functioning intake
2.5 custom exhaust with stock tips.(Don't ask) Rolling Eyes
Cross drilled and slotted rotors and ceramic pads on all four corners
Recent repairs or parts:
4 General Altimax tires with nitrogen (rotated every other oil change)
Both front wheel bearings
Catalytic converter with u bend delete
Front exhaust manifold
Rear O2 sensor
Drivers axle
Both front lower control arms
Sway bar bushings
Both outer tie rod ends
Passenger rear lower control arm
EGR valve
Fuel pump
Fuel filler tube
Both serp and S/C belts
Drivers window regulator
Tune up with new AC Delco wires and plugs
Both headlamps
Valve cover gasket/wire retainer recall at dealership
New Drivers rocker panel welded in last summer.
Passed state inspection without issue.
Recent alignment
The Bad
Engine has had a knock @ idle ever since my wife purchased the car. We spent a lot of time trying to figure it out. Finally Al (V8killer) who is a GM tech, and another gm tech I know both think it is the rear bearing for the balance shaft. It has not affected performance in any way. I have replaced the oil every 4-5k with synthetic 5-30. I have yet to see any metal shavings. It has not been problem so far, Just sounds bad at idle.
Passenger front bearing seems to be getting bad again, and will need replacing very soon.
A/C delete. No working A/C
Drivers heated seat does not work.
Slight dent in rear quarter
passengers floor has just started getting wet from leaky cowl
I wanted to offer it to enthusiasts before she decides to trade it in. So she is asking $2395 or best offer. Badass members $2195 And don't be afraid to make an offer.
You can email me at IMPALADAKID@yahoo.com or call me 603-988-4656. Leave message or text
Thank you
Bill
The most recent pictures
F/S 2000 GTP silver mist coupe Ourtwocars004
F/S 2000 GTP silver mist coupe Ourthreecars003
Tips are stock now
F/S 2000 GTP silver mist coupe SSPX0458
F/S 2000 GTP silver mist coupe SSPX0441
F/S 2000 GTP silver mist coupe SSPX0442
Rust removed and rocker replaced
before
F/S 2000 GTP silver mist coupe SSPX0338-1
After
F/S 2000 GTP silver mist coupe SSPX0349-1
PostSubject: Re: F/S 2000 GTP silver mist coupe   F/S 2000 GTP silver mist coupe EmptySat Jan 26, 2013 5:38 pm
Gone, traded. Thanks for looking.
PostSubject: Re: F/S 2000 GTP silver mist coupe   F/S 2000 GTP silver mist coupe EmptySat Jan 26, 2013 7:59 pm
So.... What'd ya get? Smile
F/S 2000 GTP silver mist coupe ToastedSig_zps6c195980
PostSubject: Re: F/S 2000 GTP silver mist coupe   F/S 2000 GTP silver mist coupe EmptySun Jan 27, 2013 9:18 am
She got the Pontiac version of KL's car. Pontiac G6
It came with the Sun and Sound package. (Sunroof, and upgraded Stereo), and remote start.
F/S 2000 GTP silver mist coupe Fc420eff9a7700c23471efb814d728edx1_zps832866fc
PostSubject: Re: F/S 2000 GTP silver mist coupe   F/S 2000 GTP silver mist coupe EmptySun Jan 27, 2013 10:18 am
Schweet. Very Happy
» F/S 2000 GTP silver mist coupe
» 2000 AD
» Rustoleum..the long term
» Ultravalve for $2000
» [Theory] What did the people on other planets look like/act like in the Silver Millennium?
