 4l60e quick connector.
PostSubject: 4l60e quick connector.   Fri May 29, 2009 10:11 am
I was searching for a quick connector and I came across this website. Has any of you guys used the quick connector or this vendor?
http://www.purechoicemotorsports.com...rod/prd255.htm
PostSubject: Re: 4l60e quick connector.   Fri May 29, 2009 11:05 am
I was unaware the "Page Load Error" was the name of a company making tranny quick connectors! Laughing
PostSubject: Re: 4l60e quick connector.   Fri May 29, 2009 12:32 pm
PostSubject: Re: 4l60e quick connector.   Fri May 29, 2009 12:38 pm
That wont fit are transmissions, if you want AN lines you need these
in 5/8"
http://www.amstreetrod.com/991950ASR.php4#Steel
PostSubject: Re: 4l60e quick connector.   Fri May 29, 2009 12:47 pm
PostSubject: Re: 4l60e quick connector.   Fri May 29, 2009 3:00 pm
Hey Bob, I wasn't sure if what I found, would fit. I'm trying to avoid having to hook up the trans lines once the tranny bellhousing is bolted up. Makes for an esyer install, I would think anyway? I wasn't sure what size the line fitting was or the brass fitting itself. Tom
PostSubject: Re: 4l60e quick connector.   Fri May 29, 2009 3:36 pm
I could not find a "straight pipe" to AN so I left the brass couplers then I used 45 deg. hose ends.
I tighten mine before the crossmember go's back on. as for quick connects you could use the fittings that fisher plows use
