| 94 Wagon LT1 - Swapped battery, now cranks forever but won't start | |
+7sdstick toomanytoyz No Moa Matt Trakker silverfox103 GasTT EnduroCaprice 11 posters |
EnduroCaprice
Posts : 15 Join date : 2012-12-11
| Subject: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Tue Dec 11, 2012 3:32 pm | |
| Hey guys-
I'm new to the BadAss forum. I recently met BadAss memeber Tomz9C1, and he recommended that I join this forum and see if you guys could help me out with a Caprice issue I'm having.
A little background first: I'm into circle track racing. My team and I run street stock type stuff, mostly G-body Monte Carlos. At the end of every season there are a few big "last man standing" type Enduro races where 75+ cars start the race and usually only 5-10 are left at the end of the 150 laps. As you might have guessed, if you're not driving a tank you don't stand a chance.
Caprices are perfect for these races. I've run a wagon and a sedan before, and I recently inherited another 94 wagon with an LT1.
Here’s my issue: The previous owner drove the wagon up until 2 months ago (Oct 2012). They had it running 2 days before I picked it up. When I got there, it would crank, and crank, and crank...but not start (not even a sputter). I brought the car home, swapped the battery and it fired right up. It ran and drove great with no issues. I figured the old battery was junk. This weekend I pulled the good battery out to start another car. When I put it back in the wagon, it once again will not start. It's cranking plenty fast but won't even sputter. Sometimes after I stop cracking it, it seems to backfire out the airbox .The "Pass Key" failure light is not on. I was thinking there may be some security system in there that I don't know about. It's very strange because when I swapped the battery the first time it fired right up. Now, all I did was take it out and put it back in, and nothing.
Has anyone else ever had an issue like this? Any insight is greatly appreciated.
Also- I’ll be stripping the entire interior before I race the wagon. If anyone is interested in anything not associated with the driveline…let me know what you need! Switches, window regs, glass…Tom pointed out that the dash pad is mint. I’m in Tewksbury, MA
Thanks
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Tue Dec 11, 2012 4:33 pm | |
| What color interior? Is it a Buick or a Chevy? | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Tue Dec 11, 2012 4:43 pm | |
| Could be a lot of things, but the first thing I would check is the fuel pump. When you turn the key on, do you hear the fuel pump run for a couple of seconds? Have you checked the fuel pressure with a gauge?
Tom C. | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Tue Dec 11, 2012 5:09 pm | |
| Welcome to the forum! Are you referring to the Halloween Howler in Epping?
Is the car getting spark or fuel? Probably a stupid question, but also a good starting point. I'm wondering if it's something to do with a battery cable issue or something like that?
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Tue Dec 11, 2012 5:11 pm | |
| Also, if this car has the cornering lamp option, I would be interested in the headlight/parklight harness for them that runs across the core support to both sides! | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Tue Dec 11, 2012 5:12 pm | |
| poor caprices. | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Tue Dec 11, 2012 5:13 pm | |
| True, but I think it's better than an all out demolition derby. Or donking one out. | |
EnduroCaprice
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Tue Dec 11, 2012 6:47 pm | |
| Thanks for all of the responses.
A couple of people have mentioned the fuel pump. I do hear the pump turn on when I turn the key. I don't think its a pump issue because from what I'm told, when they go-they go. Same with spark because this issue seems to be intermittent. Someone told me these cars are notorious for needing crank sensors? Anyone know where the sensors are, are they difficult/expensive to replace?
Yes, I am referring to the Howler. My favorite day of the year. You may say "poor caprices", but I bet I have as much, if not MORE, fun in my Caprice on the track as you have in yours on the road. If you're a Caprice lover you'd be proud to see how well they do in the Enduros.
The wagon is a Chevy. It has red interior.
Thanks | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Tue Dec 11, 2012 7:28 pm | |
| - EnduroCaprice wrote:
- . You may say "poor caprices", but I bet I have as much, if not MORE, fun in my Caprice on the track as you have in yours on the road. If you're a Caprice lover you'd be proud to see how well they do in the enduros.Thanks
That is very doubtful. I've done stunt and auto cross with mine. I just saved 2 from the enduros down here, stripped them and then cut them up, and made some $. Done want you enduro guys having to much fun with them. | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Tue Dec 11, 2012 8:35 pm | |
| I would verify spark. Could be a coil or bad/broken grounds at the coil. Could also be the optispark (distributor), which is between the timing cover and the water pump, which is what "they" may be referring to as the crank sensor, as it has one in it. (Holy run-on sentence, Batman!) If it's the opti, you're looking at $150-$400 bucks to swap it out, depending on the parts sourcing. Is that worth the repair to you? What kind of shape is it in? Maybe it could be sold to an enthusiast? There are always guys on this board looking to pick up a wagon. | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Tue Dec 11, 2012 9:26 pm | |
| I'm guessing this is what he bought, seeing it's from the same town and hasn't been driven for 2 months.
http://boston.craigslist.org/nwb/cto/3449937828.html
Tom | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Tue Dec 11, 2012 9:53 pm | |
| I'm over in Andover Pump can fool you but a pressure check is baby food. There's a scrader valve on the fuel line directly behind the intake. It can spray gas when pressed & still be the problem. You have a gauge? If not...PM me where you are I'll help you out If the cars been out in the moisture, it's quite possibly the OPTI = stealth PIA distributor When its dry it fires, moist = cranks...just confirm spark. Pull a wire & gap to ground. Check your battery connection to ground. Moving those cables may be causing an issue. PS...I understand wanting to get rid of red interiors.... ... | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Tue Dec 11, 2012 10:47 pm | |
| This will be my one and only post in this thread just to avoid pissing anyone off, I'm with Glen. Go grab a crown vic next time! | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Tue Dec 11, 2012 10:53 pm | |
| check the aux battery post ,.. sounds like you are moving the batt cable around and its not making good contact there,.
is the front carpet nice??
Nick | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Tue Dec 11, 2012 11:16 pm | |
| Welcome aboard Travis, glad to see you made it here. I forgot to mention the Auxiliary battery post may be the problem. It is located on the Pass side behind the under hood fuse box. It is sometimes made of zinc alloy in the 94 & early 95 models, not a very good electrical conductor, so they corrode most often and cause on and off no start issues. Check if it is of the Zinc,(silverish color, my have corriosion) or Copper, which if so, you should likely have no issues here. | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Tue Dec 11, 2012 11:25 pm | |
| Matt & Glen, nice welcome Wagon. no pun intended. I told Travis there are a bunch of good guys here, was I wrong? He is absolutely doing the right thing with this wagon. You can believe that coming from me. | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Tue Dec 11, 2012 11:33 pm | |
| - Tomz9C1 wrote:
- Matt & Glen, nice welcome Wagon. no pun intended. I told Travis there are a bunch of good guys here, was I wrong? He is absolutely doing the right thing with this wagon. You can believe that coming from me.
Sorry Tom, I guess I should just say I hope it's a rust bucket wagon not worth fixing. I hate seeing parts go to waste is all. Welcome, I hope you get your issues sorted out, and I really hope you don't have to do an opti for what your using the car for, it probably isn't worth it | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Wed Dec 12, 2012 6:52 am | |
No you must be a liar! Every post has a sad person in it, today that's Matt and myself. Lol | |
EnduroCaprice
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Wed Dec 12, 2012 8:35 am | |
| Again, thanks for all of the replies.
I've got stuff to do this week, but this weekend I'll check the aux. battery post, spark, etc. Hopefully it's not the opti.
The wagon has rot issues for sure, but that's no big deal for me. Some sheet metal and self-tapping screws and away we goo! Auto-Cross is fun if that's your thing, but it's definetly not for me. I like to race against someone that I can push out of the way, rather than the clock. But when you're using your street car yes, Auto-Cross is the better option.
I've run Crown Vics as well as Caprices...the 4.6 Crown Vics are nice, very fast...but in my experience the engines don't stand up to the beating like the Caprices.
Phantom - I'll check on the condition of the front carpet. | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Wed Dec 12, 2012 8:40 am | |
| You need a driver let me know, lol. | |
EnduroCaprice
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Wed Dec 12, 2012 8:59 am | |
| I'll add you to the list of back-ups, Tom! | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Wed Dec 12, 2012 11:13 am | |
| Phew....at least Travis is only trashing boxies....& wagons... BTW for clarification....cutting them up is better HOW? You gonna give me that organ donor argument?.. Anyway...Travis...Tom has my # or PM me if I can help...my schedule always sucz but usually because I jamb things like this into an otherwise controllable life. Good luck | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Wed Dec 12, 2012 3:08 pm | |
| I used to go to the enduros at Star back in the 90s with my dad a lot. These days it seems like the only one I can find out about is the Howler, I definitely remember going to some random ones during the summertime, and one around July 4th where they also had a jet truck and used it to melt a Dodge Caravan. Definitely want to hit some up (as a spectator, ha) next season... | |
EnduroCaprice
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Wed Dec 12, 2012 3:12 pm | |
| I race at Star and Hudson all spring/summer. We have Monte Carlos that we race on a weekly basis, but we put them away for the Howler/other year-end events and bring out the Caprices/Crown Vics/Road Masters etc. I can post schedules in the spring, its a good time. | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Wed Dec 12, 2012 3:56 pm | |
- Phew....at least Travis is only trashing boxies....& wagons...
Good luck Listen, as cool as it is seeing cars smash into eachother, I don't like to see it happen to cars I like. And I won't let Travis' thread turn into a boxing ring, but cutting them up is better in my eyes. Look at my rotten 84. Instead of taking it to an enduro race I'm using the following parts: Frame Nose Roof metal as an eventual permanent fix for my roof Engine --> can be saved after the race if it hasn't blow up yet Trans--> can be saved after the race if it hasn't blow up yet Interior pieces and glass as spares for hard to find two door parts. Quarter panel pieces that were not previously ruined by rust or other damage... The list goes on, I'd rather save them! But obviously Travis has fun, and unfortunately I would smile ear to ear when a caprice wins this thing... I just hope all of the useful parts on the cars are swapped out or removed before they get ruined. That being said... Southern California demo derbys should be outlawed! | |
EnduroCaprice
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Wed Dec 12, 2012 4:17 pm | |
| 84Twodoor...
My friend has an 82 two door. Real straight car. I think it has a 289 in it, fresh silver metallic paint two years ago, has a little carb issue that's being figured out right now but otherwise runs good. New hood and fender on it, interior prefesionally cleaned and shampoo'ed! Monte SS rims, brand new edlebrock intake, fresh dual exhaust. Was recently gone through. He's selling it in the spring to buy (gulp) an engagement ring.
Seeing as you're into two-doors, and you hate to see these cars get "ruined" in the enduros...you sound like the perfect buyer! I'll let you know when it hits the market!
Unless, of course...you want...me...to buy it...AND ENDURO IT! He already told me if it doesn't sell it's all mine. I'll be sure to post pics. | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Wed Dec 12, 2012 6:06 pm | |
| You're an asshole. But I lol'd! I think you'll fit in just fine here. | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Thu Dec 13, 2012 12:29 am | |
- 84Twodoor...
My friend has an 82 two door. Real straight car. I think it has a 289 in it, fresh silver metallic paint two years ago, has a little carburetor issue that's being figured out right now but otherwise runs good. New hood and fender on it, interior professionally cleaned and shampooed! Monte SS rims, brand new Edlebrock intake, fresh dual exhaust. Was recently gone through. He's selling it in the spring to buy (gulp) an engagement ring.
Unless, of course...you want...me...to buy it...AND ENDURO IT! He already told me if it doesn't sell it's all mine. I'll be sure to post pics. I guess I do deserve a ration of shit back from the ration I doled out to you. Sorry, I seem to have come on strong bashing the whole enduro thing. I seriously didn't mean to offend you, and I apologize for coming off so strongly. I'm not trying to be an a-hole or an E-tough. Just standing up for my own views about the preservation of great American automobiles. I unfortunately cannot afford to buy any other cars nor do I have the space for them. I will certainly offer to buy parts off of you once you post about it, that is if you follow through with buying the car. I sure hope it isn't the white one I've seen around Tewksbury a few years back! That one was clean! Though again, I'm voicing my opinion here, I really hope that if it truly is that clean, it won't be enduro'd. If you do enduro the poor thing, I'll offer to swap the doors out, if they are perfect, for two of mine which aren't perfect ( rust). I'll also offer to cut the quarters off, if they are in good shape, if that is acceptable and you can cobble something together to make it enduro legal. I'm not really sure how the rules go with that because I've ignored the whole scene forever. All in all, sorry to trash the thread and offend you, no hard feelings bud. Lets see some pics of the wagon. | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Thu Dec 13, 2012 1:08 am | |
| If you have a VATS problem the engine would not crank or the engine would stall after only around 10 seconds (fuel pump enable is shut off). I'd check the coil wire and the ground wires near the ignition coil first. | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Thu Dec 13, 2012 1:31 am | |
| - boojum wrote:
- If you have a VATS problem the engine would not crank or the engine would stall after only around 10 seconds (fuel pump enable is shut off).
Think it's similar to "massholes" l99 issue with the crappy grounds? Seems to be a running problem for the l99/lt1 folks
Last edited by 1984twodoor on Thu Dec 13, 2012 1:40 am; edited 1 time in total | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Thu Dec 13, 2012 1:35 am | |
| Now that I think about it it may be the fuel injectors and not the fuel pump that get cut off. Anyway same symptom. | |
EnduroCaprice
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Thu Dec 13, 2012 8:56 am | |
| Boojum - thanks for the insight. I'm going to be going out to try and get it running this weekend, so I'll look into coil wire and ICM connections as well. And thanks again to all for the adivce and insight. I don't mean to offend anyone by joining your forum and talking enduros. I'm just pushing back a little during this, which I will consider my "freshman hazing". Twodoor- It's not the white one you've seen around Tewksbury. It's silver, and it way nicer than that white one (from what I've seen). There will be no stripping of parts off of this car, it's definitely not a donor. And don't worry, I'm 99% sure I won't end up with it because my guess is he's going to be asking around $4,000 for it and it's going to sell with relative ease. But there's always hope! AND REMEMBER- I'm a car guy too. I have my fun at the track but, like every other racer, I know the infamous phrase "it's too good to race". I've bought and sold many a car that I would love to take out there, but had to sell because I knew it was just too nice to strip. Us circle track guys are generally using up the cars that are rotting away in your grandma's yard or are already on their way to the crusher. And usually, we use them for at least a few years...so really, we are extending their lives. | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Thu Dec 13, 2012 9:37 am | |
| I knew you would have seen that white one, that's the test to see if you were a car guy, knowing the area cars well I hope he sells it if that ring works out in his favor! Well I'm glad you aren't a total killer like some guys are, scrap metal rats, who buy clean cars and rip people off and just bring them right to the crusher...thats a waste of so many good resources...ugh As for "freshman hazing" yeah that's about right lol, hope you get that car fixed, and if you need a hand I'm right in Wilmington. But if there is any boxy carnage put a tarp over it before I come by! | |
EnduroCaprice
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Thu Dec 13, 2012 9:44 am | |
| I'm actually a fan of the boxys over the bubbles... If someone had a box caprice in similar shape to my bubble wagon I would trade for sure (I'm an intake/carb/no computer kind of guy). I still have the 78 Impala in my pics...I love that car, and it's still straight after 2 years of racing. | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Thu Dec 13, 2012 3:00 pm | |
- I'm actually a fan of the boxys over the bubbles... If someone had a box caprice in similar shape to my bubble wagon I would trade for sure (I'm an intake/carb/no computer kind of guy). I still have the 78 Impala in my pics...I love that car, and it's still straight after 2 years of racing.
... Define straight? Well, it looks like I have to like you! No one else here wants to play with carbs! Even the other "carb guy" had talked about EFI! | |
EnduroCaprice
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Thu Dec 13, 2012 3:04 pm | |
| Straight: See pics of Impala, below. Not straight: See every other car in pics, below. Haha.
The Impala has maybe one dent in the rear quarter. The | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Thu Dec 13, 2012 3:21 pm | |
- Straight: See pics of Impala, below.
The Impala has maybe one dent in the rear quarter. The I'd put lights back in it and drive it on the road then | |
EnduroCaprice
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Thu Dec 13, 2012 3:30 pm | |
| Weeeeeeelll....you'd also have to add a full interior (but this car doesn't have a cage so that would be easy!), replace the bumpers since the current ones have been trimmed and reinforced, cut the welds that hold the doors shut, readjust the suspension. But that's only a weekend's work. I plan on driving it on the road-as it, along with all the other racecars in my garage, when the Zombie Apocolypse hits. | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Thu Dec 13, 2012 3:33 pm | |
- Weeeeeeelll....you'd also have to add a full interior (but this car doesn't have a cage so that would be easy!), replace the bumpers since the current ones have been trimmed and reinforced, cut the welds that hold the doors shut, readjust the suspension. But that's only a weekend's work.
I plan on driving it on the road-as it, along with all the other racecars in my garage, when the Zombie Apocolypse hits. That's what I was getting at! Now, when you are done with that car, I'd gladly take it and cobble it together with lights and big push bumpers and drive it until I get caught! To be honest, lights, horns, seatbelts, bumpers, no jagged edges...I don't see any issues with it running on public roads. | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Thu Dec 13, 2012 3:53 pm | |
| - 1984twodoor wrote:
- To be honest, lights, horns, seatbelts, bumpers, no jagged edges...I don't see any issues with it running on public roads.
Until the offocer asked him to "exit the vehicle please" & he starts climbing out the window.... He'd be beat senseless by the time his feet hit the pavement.... | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Thu Dec 13, 2012 10:20 pm | |
EnduroCaprice
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Mon Dec 17, 2012 8:04 am | |
| So I went out to check on all of the things everyone suggested to get this wagon started.
But first, since the only thing I did last time to get it running was swap the battery...I swapped the battery again. And it fired right up. Doesn't make much sense to me, but...whatever, I'll take it. | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start Mon Dec 17, 2012 8:09 am | |
| Cables......follow them all
Assuming the weather (heavy moisture in the air) wasnt a factor | |
| Subject: Re: 94 Wagon LT1 - Swapped battery, now cranks forever but won't start | |
