SlowImpala
Posts : 3 Join date : 2012-11-15
| Subject: A/C Delete Pulley AC Compressor Bypass Fri Nov 16, 2012 9:10 pm | |
| A/C Delete Pulley AC Compressor Bypass New still new in the box This listing is for one All-New Dorman A/C Compressor Bypass Pulley. What is an A/C Bypass Pulley?: An A/C bypass pulley is an alternative to expensive air conditioning repairs. Most late model vehicles use a single belt to drive the water pump, alternator, power steering pump, and A/C compressor. When an A/C compressor fails and locks up, it will break the belt and leave you stranded. Until recently, the only solution was to spend hundreds of dollars to replace the compressor and repair the A/C system. Our bypass pulleys have changed that. Simply unbolt your A/C compressor and bolt in one of our brand new bypass pulleys. This will get your vehicle going again for a fraction of the cost of an A/C repair. Our bypass pulleys are designed to bolt-on just as the original compressor did. You can even use the original compressor bolts and belt in most cases. If later you decide to repair your A/C system, simply remove the bypass pulley and bolt the compressor back in place. Our A/C bypass pulleys also offer a great weight savings for off-road and racing applications. $45 bucks | |
