| Anyone want to help me sunday | |
+5toomanytoyz iceman3201 laidlow91 Tomz9C1 bammax 9 posters |
| Subject: Sunday is canceled per request of my boss Wed May 27, 2009 9:14 am | |
| Like the title says. I could use one or two people to help me with the final push to get my car done. Rear shocks, springs, emergency brake cables, hole in trunk, trim cluster bezel, sand roof, sway bar end links, and bleed the brake system. Maybe a rear quarter will appear as well. I can't offer much. But I can feed you and keep you from dying of thirst. I could really use the help
| Subject: Re: Anyone want to help me sunday Wed May 27, 2009 10:26 am | |
| I might be able to lend a hand. I won't be "driving miss daisy" sunday so it should free up some time in the afternoon. | |
| Subject: Re: Anyone want to help me sunday Wed May 27, 2009 11:13 am | |
| I'll see what the wife has planned. | |
| Subject: Re: Anyone want to help me sunday Wed May 27, 2009 11:16 am | |
| i should be able to come up and give you a hand. you starting bright and early. | |
| Subject: Re: Anyone want to help me sunday Wed May 27, 2009 11:42 am | |
| Dude your new avatar is giving me seizures | |
| Subject: anyone want to help me sunday Wed May 27, 2009 2:19 pm | |
| bill if you need me. ill be there. lmk. if you dont im going to start cleaning out my storage sheds. ive got to come up with some money to get this tranny in this month. | |
| Subject: Re: Anyone want to help me sunday Wed May 27, 2009 5:27 pm | |
| I may be able to. I'm supposd to be going to an Autocross at Devins with my Stepfather and Brother though! | |
onehunglo
| Subject: Re: Anyone want to help me sunday Wed May 27, 2009 6:01 pm | |
| Wifey's got some shower thing so I could swing up! | |
onehunglo
| Subject: Re: Anyone want to help me sunday Wed May 27, 2009 6:44 pm | |
| I really appreciate the offers guys. If you have plans, then no need to drop or alter your plans for this. I just basicly need one extra set of hands to finish up the mechanicals. Yeh! Yeh! Yeh!... He said mechanicals. |
| Subject: Re: Anyone want to help me sunday Wed May 27, 2009 7:37 pm | |
| I didn't have any plans 'til I heard there was an autocross on Sunday. Joking, tenative plans for Sunday. I'll let you know if things change. If I can't make it see if someone has a laptop and cable to scan for codes. | |
| Subject: Re: Anyone want to help me sunday Thu May 28, 2009 8:14 am | |
| - boojum wrote:
- I didn't have any plans 'til I heard there was an autocross on Sunday.
Joking, tenative plans for Sunday. I'll let you know if things change. If I can't make it see if someone has a laptop and cable to scan for codes. That is what I really need to do. I just need the cable and program. I have a lap top I picked up for this. I need to scan the car and see what is going on. I am still not 100% sure that the transmission is the problem. It could be a bad knock sensor causing the timing to retard, it could be the solenoid not working in the transmission. What ever it is, it is just at takeoff. The car just will not spin the tires. And I mean nothing. I was on a hill stopped. As I took off, I floored it, and the car just moved like at part throttle. Once moving, the car drives and runs like it is brand new. At 50mph, I put my foot into it, it drops down to 3rd gear, and gets the job done the way it should. I just gave it a complete tuneup, and though it idles perfect, the slow takeoff symptoms remain. |
| Subject: Re: Anyone want to help me sunday Thu May 28, 2009 12:27 pm | |
| I have a laptop with Datamaster & Tunercat plus cable if you need to use it | |
| Subject: Re: Anyone want to help me sunday Thu May 28, 2009 4:53 pm | |
| When you stomp it & count the shifts does it go thru all 3? | |
| Subject: Re: Anyone want to help me sunday Thu May 28, 2009 6:28 pm | |
| Hopefully you figure out what's wrong because it might help me figure out my stumble off-idle. | |
- When you stomp it & count the shifts does it go thru all 3?
I am not sure. I have not finished getting it ready for inspection, so I have not driven it since the first mod day. It does not feel like it is starting in 1st gear though. I does feel like it is starting in second. My freinds blazer was the same way, but it also had no OD. Both first and od did not work. But I know my od works, as she just cruises on the highway nice. |
| Subject: Re: Anyone want to help me sunday Thu May 28, 2009 6:35 pm | |
| - bammax wrote:
- Hopefully you figure out what's wrong because it might help me figure out my stumble off-idle.
Your problem is a PIA to figure out. It could be anything from a leaky intake manifold gasket, to fuel delivery, to ignition, egr, or even wiring. I had the same thing on a 9c1. I fixed and replaced everything and never found the culprit. |
| Subject: Re: Anyone want to help me sunday Thu May 28, 2009 9:40 pm | |
| This Sunday has been canceled. I have a bunch of stuff to get done before the 4th of june, So sunday will be spent doing non b-body related stuff.
I do want to thank those who were willing to take one for the team and help out. I really appriciate it. |
| Subject: Re: Anyone want to help me sunday | |
