Today at 4:28 pm by fatvet
 Need 1994 transmission OR 1995 RMW computer!
PostSubject: Need 1994 transmission OR 1995 RMW computer!   Sat Oct 27, 2012 9:44 am
I thought I could just mod this one but apparently Joel (sherlock9c1) says it's a bad idea and I should buy some expensive kit and a $200 reaming tool to mod it. No thanks.
I am looking for a used 1994 transmission. I have a 1995 transmission for trade. 4l60e. It's getting close to crunch time I need my winter beater on the road.
PostSubject: Re: Need 1994 transmission OR 1995 RMW computer!   Sat Oct 27, 2012 11:47 am
Doesn't Dave need a '95 Trans?
PostSubject: Re: Need 1994 transmission OR 1995 RMW computer!   Sat Oct 27, 2012 12:27 pm
I dont know, but I need a good working '94 in exchange.
PostSubject: Re: Need 1994 transmission OR 1995 RMW computer!   Sat Oct 27, 2012 2:58 pm
If you wanna sell it back I got no issue with that. HOWEVER Tim you COULD find a 95 computer and just add the single TCC wire from the PCM to the trans plug. I have the complete PCM pin out and can probably guide you through it. I dont know wha $200 kit your guy is talking about seems unneccessary. $.02
PostSubject: Re: Need 1994 transmission OR 1995 RMW computer!   Sat Oct 27, 2012 3:25 pm
If I could find a 95 computer (CHEAP, or I have an extra to trade for stock 95 computer, could be used for programming not sure what's on it) I would add the extra wire. I need this trans in asap.
PostSubject: Re: Need 1994 transmission OR 1995 RMW computer!   Sat Oct 27, 2012 3:31 pm
I'll keep an eye out. Check CL for parting out caprices. Or if anyone programs obd1 they can change the 94 base code to a 95 (I believe)
PostSubject: Re: Need 1994 transmission OR 1995 RMW computer!   Sun Oct 28, 2012 1:18 am
I did need one, found a builder that I happened to work with Smile
Sorry, no 94's here. The wiring and PCM sounds like the way to go in your case. From the sticky on the SS forum:
"An additional wire must be run from the PCM connector D pin 6 to pin "U" on the trans harness for the TCC to work. Also, the PCM must be reprogrammed with ’95 transmission base code"
PostSubject: Re: Need 1994 transmission OR 1995 RMW computer!   Sun Oct 28, 2012 11:12 pm
Here's one cheap in Lincoln, RI
http://providence.craigslist.org/pts/3273548619.html
1994 CHEVY CAPRICE TRANSMISION. CONDITION, SHIFTED PERFECT BEFORE CAR SAT FOR TWO YEARS. WAS WELL MAINTAINED AT DEALERSHIP.
4016923796 ASK FOR STEVE
OTHER PARTS AVAILABLE.
» 1994 & 1995 Impala SS Center Console
» 1995 Caprice 9C1
» FOR SALE LDM 1995 Caprice
» 1994 Cadillac Fleetwood Brougham DCM Baretop!!
