February 2018
 Project: Cop-out, new update
Go to page : Previous  1, 2, 3, 4  Next
PostSubject: Re: Project: Cop-out, new update   Wed May 15, 2013 8:17 am
ROTY!
I forgot to ask, stock running gear? Mods?
PostSubject: Re: Project: Cop-out, new update   Wed May 15, 2013 10:11 am
ROTY!
Not too much mod stuff, mostly maintenance.
Mech. fan converted to e-fan
Home plate, air pump delete, TB bypass
New GM water-pump, t-stat, hoses, coolant flush
New Chandler Motorsports Opti, new plugs and wires, fuel filter
New gas tank straps
Trans flush, repaired cooler lines
Replace exh manifold broken bolts, had manifolds resurfaced, Flowmaster H-pipe w/turbo's
4 new 255-60-15 BFG's
4 new Gabriel ultra's
Alignment
New GM upper control arms (boxed)
Buick rear frame brace
Rear pinion seal replaced, new diff cover, diff service (stk G80 w/2.93 gears)
New brute force u-joints, had driveshaft balanced
Swapped A/C compressor & recharged A/C
Re-flashed PCM
Already had new radiator, alternator, center-link
Tons of other little stuff, window rollers etc. Lots of time spent on the body (too much time) Rolling Eyes Complete interior swap....
Push-bar going on tonight Cool
PostSubject: Re: Project: Cop-out, new update   Wed May 15, 2013 10:39 am
We need to get together with Jim in the mass car, start chasing some bad guys.lol
I'm ready.
PostSubject: Re: Project: Cop-out, new update   Wed May 15, 2013 11:24 am
I'm ready.
Words cannot express the awesome elephant
(wheels look good BTW) Cool
PostSubject: Re: Project: Cop-out, new update   Wed May 15, 2013 11:35 am
I've got the n97 with the hubcaps I'm going to put on that came off Lorne's car, they are mint!
PostSubject: Re: Project: Cop-out, new update   Wed May 15, 2013 12:26 pm
Please relocate vehicle to DD's before next pic.....thank you
PostSubject: Re: Project: Cop-out, new update   Wed May 15, 2013 12:28 pm
Sorry, I use TH no DD
PostSubject: Re: Project: Cop-out, new update   Wed May 15, 2013 12:58 pm
Dude... Awesome. Smile
But you usually need to be the good guys in order to chase the bad guys... Razz
PostSubject: Re: Project: Cop-out, new update   Wed May 15, 2013 1:28 pm
I got like 5 of those bars, would look awesome with clear lenses, but damn it would be bright. lol. Least they wouldn't give you any shit from running blue. lol
PostSubject: Re: Project: Cop-out, new update   Wed May 15, 2013 6:27 pm
For you, Steve...
It is a gorgeous forest green with a hint of a flake, but when the sun comes out from behind the clouds and casts its rays upon the surface, the brilliant gold metalflake literally pops out of the paint and seems to hover there, just barely above the surface, dancing and creating such a brilliant and mesmerizing display that you'll forget that the paint started out as... well... Green. Wink
Seriously though dude, you did a great job! Looks awesome in person! lol!
It's an enlightening experience to see it in the sun. Doesn't hurt that this car has enough SEM on it for stage 3.
PostSubject: Re: Project: Cop-out, new update   Wed May 15, 2013 6:46 pm
Wait...Dont you put SEM....where the sun dont shine?...err....so to speak.
PS: He didnt do all that himself (garage gnomes reach the undercarriage MUCH easier)
PostSubject: Re: Project: Cop-out, new update   Thu May 16, 2013 12:50 am
color is nice,...
booth9C1SS
PostSubject: Re: Project: Cop-out, new update   Thu May 16, 2013 6:21 pm
I'm ready.
Maybe the next 9C1 only get-together should be held in the median of I-95.
PostSubject: Re: Project: Cop-out, new update   Thu May 16, 2013 6:30 pm
I'm ready.
I lol'd hard!
PostSubject: Re: Project: Cop-out, new update   Tue Jun 18, 2013 4:31 pm
4-9C1 door panels all cleaned up and installed
Put around 2,000 miles on it now, my only fail was an old A/C line leaking (big surprise) Laughing
This was the mileage a week ago
PostSubject: Re: Project: Cop-out, new update   Tue Jun 18, 2013 4:37 pm
Sweet!
PostSubject: Re: Project: Cop-out, new update   Tue Jun 18, 2013 6:16 pm
Good to see you're enjoying it! Manual windows is waaaaay cooler tho ;D
PostSubject: Re: Project: Cop-out, new update   Tue Jun 18, 2013 7:40 pm
Yeah, cuz you can't reach the cranks and have to run the AC all the time. Wink
PostSubject: Re: Project: Cop-out, new update   Tue Jun 18, 2013 8:17 pm
Well, I care about the environment, so I have the window down with the AC on max
PostSubject: Re: Project: Cop-out, new update   Wed Jun 19, 2013 6:58 am
Yes they are!!
Guess i'm screwed then, cause i can't reach the cranks, and my AC is nonexistant.
PostSubject: Re: Project: Cop-out, new update   Wed Sep 11, 2013 4:53 pm
The new update: More overhauling continues.......Mad
About 4 weeks ago, driving up 93 North, cruise set a 75 mph, motor revs like I threw it in neutral. Soo I pull over, no forward in a gear, no reverse, fluid ok. Got it towed home (stoopid transmission).
Suspect I lost the front pump, will find out later (when I tear it down).
Needing a transmission, and having another '95 right next to it, I stole the trans out of my lowered L99. It's an already built Level 2, with a 2,800 stall-converter. cheers
I'm currently ready to put the new trans into the cop-car.
I cleaned and painted the crossmember, shift linkage, and the floor/frame areas I couldn't get with the crossmember in.
Gave the new trans a filter & gasket while I was there.
PostSubject: Re: Project: Cop-out, new update   Wed Sep 11, 2013 7:40 pm
*Teepees Fingers*
Egggggggggggsellent Smithers.
Wink
PostSubject: Re: Project: Cop-out, new update   Wed Sep 11, 2013 8:13 pm
Z Pak rebuild?
PostSubject: Re: Project: Cop-out, new update   Wed Sep 11, 2013 10:32 pm
Is that an empty lift?
PostSubject: Re: Project: Cop-out, new update   Thu Sep 12, 2013 10:46 am
Z Pak rebuild?
1 extra 3-4 clutch, billet 1-2 servo, shift-kit, boost valve, HD 2-4 band, modded pressure control solenoid, new shift solenoids. Has about 20k miles on it since it was done. Cool
.Nope, car is up in the air bounce
PostSubject: Re: Project: Cop-out, new update   Thu Sep 12, 2013 10:35 pm
Hopefully everything on the Camaro will be cleaned and painted like this car. SEM Smile
PostSubject: Re: Project: Cop-out, new update   Fri Sep 13, 2013 3:55 pm
The new trans is in, everything underneath bolted up cheers
Brought the radiator and aux cooler to work with me today to flush em out with a few gallons of ATF, on our flush machine (def not taking a chance with any debris that could still be in there somewhere)
PostSubject: Re: Project: Cop-out, new update   Fri Sep 13, 2013 4:20 pm
Woot!!!! Very Happy
PostSubject: Re: Project: Cop-out, new update   Fri Sep 13, 2013 6:30 pm
Shoulda done that the 1st time? Shocked ..Laughing
Can someone off the street get that done?
PostSubject: Re: Project: Cop-out, new update   Sat Sep 14, 2013 11:32 am
The car had a 16 qt flush a few thousand miles ago, whatever broke was a hard part, not clutches, inside of the trans that came out was pretty darn clean inside.
What I did with the trans coolers (which is a totally different flush machine), is only needed if there was a trans failure. Not only does it flush fluid from both directions, both it can also measure the flow through the cooler to check for resistance or blockage. Mine was fine, acceptable is 1.5 gps ,mine was 2.8 (which was a higher flow than any others I've flushed) Very Happy
If someone brought me a cooler I could flush it, dunno what they would charge. Probably 1 hr labor + amount of fluid used.
PostSubject: Re: Project: Cop-out, new update   Sat Sep 14, 2013 11:55 am
1 hour to flush a cooler. holy crap!!!!!! Damn highway robbery Very Happy
PostSubject: Re: Project: Cop-out, new update   Sat Sep 14, 2013 12:18 pm
................The car had a 16 qt flush a few thousand miles ago, whatever broke was a hard part, not clutches, inside of the trans that came out was pretty darn clean inside.
................What I did with the trans coolers (which is a totally different flush machine), is only needed if there was a trans failure. .
Got it...thanks
Wait until your m age....everything seems like highway robbery.
Flush < Rebuild < Stranded
PostSubject: Re: Project: Cop-out, new update   Sat Sep 14, 2013 12:46 pm
Yea, its got to be a bitch getting boned on that SR coffee at mcdonalds. lol
PostSubject: Re: Project: Cop-out, new update   Sat Sep 14, 2013 1:02 pm
That would be for both of them, less for just a radiator cooler.
I'm the only one in the shop that has hook-ups that will fit our cars, cuz I made them. Very Happy
Flush it, or replace it, your choice  Laughing
PostSubject: Re: Project: Cop-out, new update   Sat Sep 14, 2013 1:04 pm
I power wash that biotch. Wink
PostSubject: Re: Project: Cop-out, new update   Sat Sep 14, 2013 1:06 pm
You power wash out the trans cooler? I gotta see this Shocked
PostSubject: Re: Project: Cop-out, new update   Sat Sep 14, 2013 1:21 pm
I take it out, and spray brake cleaner in it, blow it out with air and repeat until there is nothing but brake cleaner coming out. I make sure the coils are horizontal so everything comes out. I do this probably 5-8 times. I do something similar to the lines as well, except I and them so they drain down, and I spray the brake clean followed by the air. This is a great back yard clean out of the cooler and lines.
PostSubject: Re: Project: Cop-out, new update   Sat Sep 14, 2013 3:58 pm
[quote="V8Killer"]
You power wash out the trans cooler? I gotta see this Shocked [/quote
Works good. Stick it In the whole and give r hell.
PostSubject: Re: Project: Cop-out, new update   Sat Sep 14, 2013 6:19 pm
Methinks a new cooler is cheapah. Especially if you upgrade to a larger aftermarket one.
PostSubject: Re: Project: Cop-out, new update   Sun Sep 15, 2013 9:11 pm
Wow...LOL Laughing Razz
I think I like the Maine method better.
PostSubject: Re: Project: Cop-out, new update   Wed Sep 18, 2013 11:13 am
All better! cheers
Nasty 2nd gears shifts, just the way I like it Twisted Evil
Traction has now gotten a lot worse tho.............scratch
PostSubject: Re: Project: Cop-out, new update   Wed Sep 18, 2013 11:15 am
Time for better tires if the traction sucks. Lol
PostSubject: Re: Project: Cop-out, new update   Wed Sep 18, 2013 1:05 pm
I have a couple of pair of DR's if I want to go to the track, but not practical for a DD with the accelerated wear, and rain performance  elephant
PostSubject: Re: Project: Cop-out, new update   Wed Sep 18, 2013 1:50 pm
All better! cheers
Do you work?
PostSubject: Re: Project: Cop-out, new update   Wed Sep 18, 2013 2:07 pm
All better! cheers
Do you work?
Only on the second tuesdays of each week.
PostSubject: Re: Project: Cop-out, new update   Wed Sep 18, 2013 2:16 pm
All better! cheers
Do you work?
Only on the second tuesdays of each week...HIS OWN SHYT
fixt
Thats right!!!
I'm driving around in a shytbox wagon taking no prisoners today....Cool ...Razz
PostSubject: Re: Project: Cop-out, new update   Wed Sep 18, 2013 2:31 pm
All better! cheers
Do you work?
fixt
Thats right!!!
Only because you choose to drive that pos wagon, with ALL the nice cars you have, you will get no sympathy here. Smile
PostSubject: Re: Project: Cop-out, new update   Wed Sep 18, 2013 2:43 pm
but....but....Crying or Very sad ....my DD is broken.....needs tranny work...from ^^^^
OK...back to project cop-out..SOooooo we'll see this at the roundup (or???? truck)
PostSubject: Re: Project: Cop-out, new update   Wed Sep 18, 2013 6:36 pm
Thinking I'm going to take this (well that's the plan anyway) Very Happy
Page 3 of 4Go to page : Previous  1, 2, 3, 4  Next
» Project: Cop-out, new update
» Hobsonville Project....
» 1995 z28 Drag Car Roller Project For Sale
» Stereo 70 project
» My-HiME Big Bang Project?
