 Feeler: 2011 Aluminum 5.3 Block and Crank
PostSubject: Feeler: 2011 Aluminum 5.3 Block and Crank   Wed Sep 26, 2012 4:46 pm
Hey guys...
Just throwing this out there as a feeler. I am considering selling my spare Aluminum 5.3 block and crank. It came out of a 2011 Tahoe and had a cracked piston top (someone dropped a bolt in the motor it appears). Overall, the block is mint, there is no scoring in any of the cylinders and etc. It is as clean as clean gets. I have the crank for it as well. I even have the rods and pistons that came out of it, but at least one piston (maybe 2) need to be replaced if I recall correctly.
I figure if the motor I have in the car ever lets go, I will just swap in the L92. So with that being said....here she is for 300.00
Let me know if you are interested. I am not accepting low balls. I do not need to get rid of it, and I will just keep it as a back up if it comes to that....
» Need advice with drilling aluminum for tapping and heli-coil
» Dallas Event in April 2011
» Cylinder Block Pattern & Cores
» Millers Collectables 2010-2011 By Judith Miller & Mark Hill
