| 96 Fleetwood pulled 3 codes | |
| Subject: 96 Fleetwood pulled 3 codes Sun Sep 09, 2012 3:17 pm | |
| P0200 injector circuit open P0300 random/multiple cylinder misfire P0410 air injection system malfunction
Car was running "shakey" like it wanted to stall, I'm thinking it just needs a full tune up, anybody have experience with the codes not related to misfire? Thanks -Paul | |
| Subject: Re: 96 Fleetwood pulled 3 codes Sun Sep 09, 2012 6:45 pm | |
| I get the po410 code DAILY. I'm learning to live with the light. The Po300 along with the po200 sounds like you have a loose spark plug wire somewhere. | |
| Subject: Re: 96 Fleetwood pulled 3 codes Sun Sep 09, 2012 6:50 pm | |
| - 96Brougham wrote:
- P0200 injector circuit open
Car was running "shakey" like it wanted to stall, I'm thinking it just needs a full tune up, anybody have experience with the codes not related to misfire? Thanks -Paul sounds like the same issues I had when I got my 94 whore..... did plugs , wires, and of course a 3rd opti in 3 months..... took car of the issues....... it started with the wires chaffing on the block ( crovo! ) annd one thing lead to the next. | |
| I think those were the codes I was getting on mine when there was a short in the post cat o2 wiring. But I'm not 100% certain on that. It was a long time ago! | |
IMPALADAKID Admin
| Subject: Re: 96 Fleetwood pulled 3 codes Sun Sep 09, 2012 7:02 pm | |
| I sabotaged you. | |
| Subject: Re: 96 Fleetwood pulled 3 codes Sun Sep 09, 2012 7:22 pm | |
| Thanks for the replies guys, it's definitely time do do plugs wires and opti. I will also check wires to o2 sensors, but they were reading fine when I was looking at their numbers on the scan tool | |
| Subject: Re: 96 Fleetwood pulled 3 codes Sun Sep 09, 2012 7:39 pm | |
| Paul, What scan tool do you use? Comments? | |
| Subject: Re: 96 Fleetwood pulled 3 codes Sun Sep 09, 2012 8:58 pm | |
| It's an OTC genesis we have at work, decent scan tool that covers a broad range of cars from American, Japanese and euro trash. Too expensive to personally buy one, I use a pocket scan tool by Cornwell at the house for just pulling/clearing codes.. | |
| Subject: Re: 96 Fleetwood pulled 3 codes Sun Sep 09, 2012 9:00 pm | |
| - 96Brougham wrote:
- Thanks for the replies guys, it's definitely time do do plugs wires and opti. I will also check wires to o2 sensors, but they were reading fine when I was looking at their numbers on the scan tool
the misfire would cause the 02 code to appear..... Do the plugs & wires first | |
| Subject: Re: 96 Fleetwood pulled 3 codes Sun Sep 09, 2012 9:02 pm | |
| - 96Brougham wrote:
- It's an OTC genesis we have at work, decent scan tool that covers a broad range of cars from American, Japanese and euro trash. Too expensive to personally buy one, I use a pocket scan tool by Cornwell at the house for just pulling/clearing codes..
.... you can google the codes from the Cornwell scanner and get the info you need. Thats how we do it at the shop when the expensive scan tools are being used. | |
| Subject: Re: 96 Fleetwood pulled 3 codes Sun Sep 09, 2012 10:06 pm | |
Funny....my friend just gave me an older model of that (re-labeled Mentor from Mac Tools) Normally, I'd be in heaven having it...but...its tempremental..right now Doesnt work right & its bad enough trying to learn without little glitches screwing you up. I'm not happy with just codes...I need data Thanks for the answer | |
| Subject: Re: 96 Fleetwood pulled 3 codes | |
