 96 Fleetwood pulled 3 codes
PostSubject: 96 Fleetwood pulled 3 codes   Sun Sep 09, 2012 3:17 pm
P0200 injector circuit open
P0300 random/multiple cylinder misfire
P0410 air injection system malfunction
Car was running "shakey" like it wanted to stall, I'm thinking it just needs a full tune up, anybody have experience with the codes not related to misfire? Thanks -Paul
PostSubject: Re: 96 Fleetwood pulled 3 codes   Sun Sep 09, 2012 6:45 pm
I get the po410 code DAILY. I'm learning to live with the light. The Po300 along with the po200 sounds like you have a loose spark plug wire somewhere.
PostSubject: Re: 96 Fleetwood pulled 3 codes   Sun Sep 09, 2012 6:50 pm
sounds like the same issues I had when I got my 94 whore..... did plugs , wires, and of course a 3rd opti in 3 months..... took car of the issues....... it started with the wires chaffing on the block ( crovo! Evil or Very Mad ) annd one thing lead to the next.
I think those were the codes I was getting on mine when there was a short in the post cat o2 wiring. But I'm not 100% certain on that. It was a long time ago!
PostSubject: Re: 96 Fleetwood pulled 3 codes   Sun Sep 09, 2012 6:59 pm
If it was on the passengers side, it was me, not Crovo. Yes, I had my hands in that whore too. Razz
PostSubject: Re: 96 Fleetwood pulled 3 codes   Sun Sep 09, 2012 7:02 pm
I sabotaged you. Wink
PostSubject: Re: 96 Fleetwood pulled 3 codes   Sun Sep 09, 2012 7:22 pm
Thanks for the replies guys, it's definitely time do do plugs wires and opti. I will also check wires to o2 sensors, but they were reading fine when I was looking at their numbers on the scan tool
PostSubject: Re: 96 Fleetwood pulled 3 codes   Sun Sep 09, 2012 7:39 pm
Paul,
What scan tool do you use?
Comments?
PostSubject: Re: 96 Fleetwood pulled 3 codes   Sun Sep 09, 2012 8:58 pm
It's an OTC genesis we have at work, decent scan tool that covers a broad range of cars from American, Japanese and euro trash. Too expensive to personally buy one, I use a pocket scan tool by Cornwell at the house for just pulling/clearing codes..
PostSubject: Re: 96 Fleetwood pulled 3 codes   Sun Sep 09, 2012 9:00 pm
the misfire would cause the 02 code to appear..... Do the plugs & wires first Arrow
PostSubject: Re: 96 Fleetwood pulled 3 codes   Sun Sep 09, 2012 9:02 pm
.... you can google the codes from the Cornwell scanner and get the info you need. Thats how we do it at the shop when the expensive scan tools are being used.
PostSubject: Re: 96 Fleetwood pulled 3 codes   Sun Sep 09, 2012 10:06 pm
Funny....my friend just gave me an older model of that (re-labeled Mentor from Mac Tools)
Normally, I'd be in heaven having it...but...its tempremental..right now
Doesnt work right & its bad enough trying to learn without little glitches screwing you up.
I'm not happy with just codes...I need data
Thanks for the answer
» 1994 Cadillac Fleetwood Brougham DCM Baretop!!
» 96 caddy fleetwood brougham parts NEEDED
» FS: 1996 Cadillac Fleetwood Brougham $1,800.00
» Wide whites on the Fleetwood
» Fleetwood on The Client movie poster
