I took apart the dash to finish some mods today. In my 96 '9C1, the horn didnt work when I bought it. Assuming it was cut when they swiped all the police stuff out, I hooked up a circuit, from the horn fuse, to a button, then to one of the horns. It works perfect, but I have a dumb horn button now.
So anyway, today I found 2 snipped wires of equal length. one on either side of the underside of the bottom of the steering column. One is light blueish and I believe the other is green. They look factory, have transparent white connectors to the column harness going up, but I cannot find where the would have gone to under the dash. I assume they had an air horn inline with the horn circuit like the department I worked for had the "Thumper" hooked up to.
Is this the horn curcuit? How the heck do I hook them back up to the steering wheel? Thanks for any and all help with this!
