So I got all excited when I read Billy Mac's write up of the "stealth bolt mod" and said , hell, I've got an hour or so to kill before I go to see the new Star Trek movie! I install the bolts, check the fluid and then start the bleeding process. As always, being from Maine, I soak the bleeder valves with PB Blaster. I give it about 20 min and the Wife starts pumping the brakes. I cracked the valve loose just before she started applying pressure then tightened in back in place.
So you guys know the drill. I always bleed it a second time for good measure, but something goes wrong! I tell her to pump it again and as she does it bleeds out before I even crack the valve! So I figure it wasn't tight enough so I repeat and again it's still bleeding out, without her pumping, SHYT! I'm tearing it apart today and now has turned into Toms9C1 Mini Mod day! Oh well, I've got to maintain the rears anyway. I'll take pics. Have a great day guys, Tom out.
