February 2018
 1A2 springs
PostSubject: 1A2 springs   Tue Aug 07, 2012 9:32 am
I need to get the 1a2 back up, it's so damn low I can't get in the garage without scraping. So are the wagon rears different? I have a couple sets of 9c1 fronts, but I don't know what the rear uses.
Smile
PostSubject: Re: 1A2 springs   Tue Aug 07, 2012 1:51 pm
25 views and not a wagon guy in the bunch? Someone has to know this shit. lol
PostSubject: Re: 1A2 springs   Tue Aug 07, 2012 2:15 pm
Smile
CC623 is the "heavy duty" wagon rear spring. There was a seller on ebay with them for $39.99 a pair.
PostSubject: Re: 1A2 springs   Tue Aug 07, 2012 3:47 pm
Cheapest i found on sleezebay was 55.00. Am i to assume there are the same as the 9c1's? The listing shows they are, but i want to be sure.
PostSubject: Re: 1A2 springs   Tue Aug 07, 2012 3:49 pm
That, I do not know. However, when you put CC623 into Rockauto it lists them as wagon specific for all years/models. I have them in my wagon and they are stiffer than stock.
PostSubject: Re: 1A2 springs   Tue Aug 07, 2012 5:35 pm
1A2 used stock wagon springs.
SPCS
PostSubject: Re: 1A2 springs   Tue Aug 07, 2012 6:15 pm
Suspension Code for all Wagons is F40. (Suspension System, Front & Rear, Heavy Duty)
PostSubject: Re: 1A2 springs   Tue Aug 07, 2012 10:26 pm
Are those springs you got after market lowering springs? Or are they just so shitty they ride low? I'm interested in going in the reverse direction with mine Arrow
PostSubject: Re: 1A2 springs   Tue Aug 07, 2012 11:16 pm
Why not try a pair of the moog load leveling springs, someone on ebay had them for $40 a pair. A few guys on the longroof forum bought them and liked them, should raise that ass a little Razz
http://www.ebay.com/itm/CC623-Moog-Coil-Springs-Variable-Rate-/150837704425?hash=item231ea0b6e9&item=150837704425&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
PostSubject: Re: 1A2 springs   Wed Aug 08, 2012 12:20 am
What are the spring codes on the SPID label?
6xx, 7xx, 8xx and 9xx.
5 different front springs for wagons: TN, TS, TM, TL, and TY. Same rate as sedan springs, 77 N/MM. These 5 are also listed for non SEO sedans.
3 different rear springs for wagons: RR, RP, and RN. None of these seem to be listed for sedans. The wagon spring rates are higher, 37 N/MM.
PostSubject: Re: 1A2 springs   Wed Aug 08, 2012 8:53 am
Going to put the rims and tires on this week, was going to do springs also if the 9c1 ones fit.
I'll see what the SPID says.
PostSubject: Re: 1A2 springs   Mon Aug 13, 2012 9:20 am
I have the CC623s in the back. Unfortunately, they're in the box in the back. I'll give a full report once I pick up isolators and get them installed.
PostSubject: Re: 1A2 springs   Mon Aug 13, 2012 9:56 am
God damn, look how high that wagon sits. Someone should tell the owner to drop the nose. Rolling Eyes
Oh, and get rid of the ugly ass silver tape.
PostSubject: Re: 1A2 springs   Mon Aug 13, 2012 2:49 pm
It needs aluminum wheels for sure Arrow
PostSubject: Re: 1A2 springs   Wed Aug 15, 2012 12:13 am
Mike...were those the cargo springs you posted an ebay link to before?
.... Someone should tell the owner to drop the nose. Rolling Eyes ....
Dont bother...he doesnt listen. Smile
PostSubject: Re: 1A2 springs   Wed Aug 15, 2012 7:38 am
Those are the ones. $38.44 a pair, shipped.
PostSubject: Re: 1A2 springs   Wed Aug 15, 2012 1:55 pm
Glen,
I've got a pair of those ^^^
You need them?
PostSubject: Re: 1A2 springs   Wed Aug 15, 2012 4:16 pm
Glen,
You need them?
I will let you know sir, i might have found a complete set.
PostSubject: Re: 1A2 springs   Wed Aug 15, 2012 4:22 pm
OK
If you dont, Bill M may need them.
LMK whenever you get it figured out
1A2 springs
» anybody running eibach springs?
» What is this two-toned lot? Answer - they belong to Palm Springs.
» Palm Springs Pat.No.486
» F/S new G body rear springs
» AFR VALVE SPRINGS?
