 WTB Rear end
PostSubject: WTB Rear end   Fri Jul 20, 2012 3:14 pm
I would prefer a unit from an Impala SS with posi and gears such as 3.23 3.42 or 3.73
I would take a 9C1 unit if it is a posi and meets the same criteria!
B4U Drum rear with Posi would also be accepted!
Lower the miles the better! No rebuild needed...well that's even better that the other! Less rust, guess what, that's even better too! Arrow
LMK what you guys have!
Of course, if anyone has an 8.5" posi rear from a civi boxy (5x4.75 bolt pattern) I'd be all over that too! It's getting closer to the time I rebuild the frame so I'll be needing one of these! I don't want to do all this work and run a 2.56 peg leg! pale
PostSubject: Re: WTB Rear end   Mon Jul 23, 2012 4:47 pm
Matt,
If you want, call this guy. Name is Eric, he is (was?) parting a '95 RMS. I pulled my seats from it, decent guy. No bs. Car had a 2:93 posi rear, it was a tow pack car.
(413)2 zero4-4066
PostSubject: Re: WTB Rear end   Mon Jul 23, 2012 6:09 pm
PostSubject: Re: WTB Rear end   Mon Jul 23, 2012 8:44 pm
Sent you a pm, Matt.
PostSubject: Re: WTB Rear end   Tue Jul 24, 2012 1:22 am
bfurches wrote:
supposedly civilian bolt pattern'
http://boston.craigslist.org/sob/pts/3153126235.html
I think I head that 2.56 was a 7.5" housing only. I've been ignoring that ad for a while. hmm
PostSubject: Re: WTB Rear end   Tue Jul 24, 2012 5:44 pm
nttyfufu
PostSubject: Re: WTB Rear end   Wed Jul 25, 2012 1:33 pm
Matt I have a 95 9c1 rear end still in my parts car call me if your intrested (404) 226 0256. The car also has a bunch of stuff that I think you might want for your car also.
http://s1078.photobucket.com/albums/w495/nttyfufu/
PostSubject: Re: WTB Rear end   Sat Jul 28, 2012 1:38 pm
http://boston.craigslist.org/nos/pts/3168210997.html
1996 CHEVY CAPRICE POSI REAR END DRUM BRAKES GREAT SHAPE - $225 (BURLINGTON MA)
I HAVE A COMPLETE DRUM TO DRUM POSI REAR END TOOK OUT OF A 1996 CHEVY CAPRICE OPENED COVER SAYS 14-41 I THINK THE GEARS ARE 293 RATIO GREAT SHAPE BOLT IN AND GO TOOK OUT OF FLORIDA CAR NO ROT SOLID $225 CASH THANKS
10 BOLT,8.5, POSI REAREND,1984 CAPRICE OR PARISIENNE - $300 (DIGHTON ,MA)
TIGHT POSI (safe-t-track) 8.5 REAR END FROM MY 1984 PONTIAC PARISIENNE SEDAN , 2:56 RATIO I THINK , 8.5 INCH RING GEAR , JUST OVER 100K EASY MILES , COMPLETE DRUM TO DRUM .5 lug on 4.75 bolt circle --CALL ME AT 508-----274--7298 ANYTIME THANKS
PostSubject: Re: WTB Rear end   Sat Jul 28, 2012 3:34 pm
Then there's this guy:
http://newhaven.craigslist.org/pts/3158839043.html
Dave, how far are you from that guy? Maybe I could have you go check it out and if it's good grab it for me? I don't want to borrow a truck and make the trip for a rear that isn't worth it. LMK!
Snooze ya lose, dammit!
Thank you Jim, but Bill P made a good point that I had really been ignoring, I think I should go with a disc rear, and I can deal with two different bolt patterns for that.
PostSubject: Re: WTB Rear end   Sat Jul 28, 2012 4:54 pm
I've been thinking of taking a look at the Burlington one, it was on there months ago and I figured it sold. Maybe a B4U axle??? Any easy way to tell, measure brakes?
PostSubject: Re: WTB Rear end   Sat Jul 28, 2012 4:56 pm
Not really sure, I'd go for it but I would rather do the rear disc set up now and have at least a 3.08 gear and worry about building it up later on.
WTB Rear end
» FODEN REAR SPRINGS
» GN rear window mod
» roadmaster rear 8.5"?
» Rear end Gear ratio's?
» F/S new G body rear springs
