Stupid Electical Question- 12v Rotating Light EmptyWed Oct 19, 2022 1:27 pm by scot
Stupid Electical Question- 12v Rotating Light EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Stupid Electical Question- 12v Rotating Light EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Stupid Electical Question- 12v Rotating Light EmptyFri Sep 24, 2021 9:53 am by ElKy
Stupid Electical Question- 12v Rotating Light EmptySun Sep 19, 2021 6:22 pm by black blur 96
Stupid Electical Question- 12v Rotating Light EmptySun Jun 20, 2021 11:37 am by scot
Stupid Electical Question- 12v Rotating Light EmptyFri Jun 11, 2021 10:41 am by scot
Stupid Electical Question- 12v Rotating Light EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Stupid Electical Question- 12v Rotating Light EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
2 posters
PostSubject: Stupid Electical Question- 12v Rotating Light   Stupid Electical Question- 12v Rotating Light EmptyThu Jul 26, 2012 4:13 pm
I have a 12v teardrop rotating light, like this: Stupid Electical Question- 12v Rotating Light 1789_subscription_big
Couple months ago I dropped it and broke the bulb... NBD, tracked down a bulb and ordered it. Drop the new bulb in, go to plug it in, lights up for literally a split second and pops the fuse and shuts off. Put in new fuse, same issue. Change plugs, same issue. Plug it in without bulb, works fine. So now I'm thinking its a bad/wrong bulb. But the p/n was the same as the old one. Any ideas?
nailhead445
PostSubject: Rotating lamp   Stupid Electical Question- 12v Rotating Light EmptyThu Jul 26, 2012 5:16 pm
Without seeing it, my guess would be that when it was dropped, the wiring to the socket was disturbed or distorted in a way that causes the short circuit to occur only when the bulb is in place. Try measuring the resistance across the lighter plug terminals with and without the bulb. If there is an "On/Off" switch, take the reading both ways. Then compare it to the same reading taken when the bulb is in the socket. With the switch in the "Off" position (If there is a switch) the reading across the terminals should be infinity (Or "OL" for DVOM's). With the switch on, you will read the resistance of the rotator motor, whatever it may be. With a properly working unit, the reading should be a little lower (Because the bulb is in parallel with the motor) with the bulb in place, but not "0 ohms". 0 ohms under these conditions would indicate a dead short caused by the condition I described. You would then have to disassemble the unit and inspect the wiring to the socket with and without bulb in place and make repairs accordingly.
» Stupid question?
» Stupid Gas Pedal Question
» Interior light question
» Dash (idiot) light question
» Question on coolant light/reservoir
