» 2019 Twelfth Annual B & D Roundup!! Mark your calendar! Saturday October 19th
removing the Home Base bracket EmptySat Sep 07, 2019 7:36 pm by bigbluey88
removing the Home Base bracket EmptyThu Aug 08, 2019 9:41 am by CrashMaster
» 1984 Caprice project
removing the Home Base bracket EmptySun Jun 30, 2019 8:05 pm by Boxchevy84
» C10: Before and After
removing the Home Base bracket EmptySun Jun 02, 2019 3:01 pm by MalibuSSwagon
removing the Home Base bracket EmptySat Mar 16, 2019 8:49 am by boojum
» Mass refugee now in Pa
removing the Home Base bracket EmptyTue Jan 22, 2019 8:46 am by MASShole9C1
removing the Home Base bracket EmptyTue Jan 22, 2019 12:03 am by boojum
» 1996 DGM RMW
removing the Home Base bracket EmptyFri Jan 18, 2019 12:00 pm by Gorillabiter
September 2019
Share
chapel
chapel
PostSubject: removing the Home Base bracket   removing the Home Base bracket EmptyMon Jun 18, 2012 12:31 pm
Can you guys show me how you secured the wires after removing that bracket?
PostSubject: Re: removing the Home Base bracket   removing the Home Base bracket EmptyMon Jun 18, 2012 1:08 pm
I've done 2 without going any further.
Just remove the bracket let them lay where they want
OR
Dress them however you see fit
Only thing I watched for were the injector wires.....go easy
removing the Home Base bracket Impala2010002
PostSubject: Re: removing the Home Base bracket   removing the Home Base bracket EmptyMon Jun 18, 2012 1:11 pm
If you remove that, what will you hook the engine crane to if you have to remove the motor?
chapel
chapel
PostSubject: Re: removing the Home Base bracket   removing the Home Base bracket EmptyMon Jun 18, 2012 1:16 pm
not really planning on removing the motor, but I'll keep it around
PostSubject: Re: removing the Home Base bracket   removing the Home Base bracket EmptyMon Jun 18, 2012 1:25 pm
Really???
PostSubject: Re: removing the Home Base bracket   removing the Home Base bracket EmptyMon Jun 18, 2012 2:11 pm
Really???
I was kidding, that was my best attempt at a Jim dry-humor special.
To the OP - There are several relatively cheap decorative clamps that you could probably find a bolt that would fit in the stock holes and then a pretty loom that could snake through the clamps.
I have never actually removed one, but my last Impala had it removed and I don't remember where the wires were routed to...
EDIT... This is exactly how mine were run. Good write up.
http://www.impalaclub.com/naisso/Forum2009/topic.asp?TOPIC_ID=45970
chapel
chapel
PostSubject: Re: removing the Home Base bracket   removing the Home Base bracket EmptyMon Jun 18, 2012 2:13 pm
where are they run on a Camaro or a Corvette?
PostSubject: Re: removing the Home Base bracket   removing the Home Base bracket EmptyMon Jun 18, 2012 3:20 pm
Did you read the article? It attempted to do in the Impala (or Roadmaster Wagon) what was done in the corvette
Or did I mis-read your question?
PostSubject: Re: removing the Home Base bracket   removing the Home Base bracket EmptyMon Jun 18, 2012 3:22 pm
Did you read the time-stamp? I posted the edit after he posted that question Wink
chapel
chapel
PostSubject: Re: removing the Home Base bracket   removing the Home Base bracket EmptyMon Jun 18, 2012 3:23 pm
I did not find that article. I wasn't even aware of that site until just now. Thanks
PostSubject: Re: removing the Home Base bracket   removing the Home Base bracket EmptyMon Jun 18, 2012 3:25 pm
Well OK then....good thing I didnt hit it hard then....whoa Razz
PostSubject: Re: removing the Home Base bracket   removing the Home Base bracket EmptyMon Jun 18, 2012 3:29 pm
It's funny how things come across through technology. Depending on how I read your previous post, it came across as you intended or "Hey jackass, someone already answered the question, use your head"
Thankfully I know you are not some internet know-it-all tough guy from ISSF.
PostSubject: Re: removing the Home Base bracket   removing the Home Base bracket EmptyMon Jun 18, 2012 3:33 pm
HA...thats why I put....or did I mis-read your question.
I do occaisionally put my foot in my mouth
But your right....no ITG here lol! know it all....maybe Cool
» PFT's Base of Operations
» Adding a Base to your Model... what have you done?
» Dual Alternator on TBI
» ID on upright bowl form with ripped/torn edge, signed on base
» Cones or retainers - the age old debate
