 Trim Moulding Paint
Wraith'SS
PostSubject: Trim Moulding Paint   Mon May 28, 2012 9:37 pm
Those of you who are cursed with the wheel trim mouldings on the 94-96 'SS, know that replacing one of them is stupid money if you can find one in the whole country.
I want to know how they painted these mouldings. Looks like a plasticized paint that shrinks up and over time pulls back from the edges.
Would a paint with flex additive work like for a bumper cover? It's really got a different texture and thickness to it when you touch it.
Anyhow, I got one peeling and I'd love to correct it. Any ideas would be great, thanks-Pete
PostSubject: Re: Trim Moulding Paint   Wed May 30, 2012 1:03 am
Plasti-Dip ?
PostSubject: Re: Trim Moulding Paint   Wed May 30, 2012 2:50 pm
if u strip them and just base/clear them body color i think u will be fine
Wraith'SS
PostSubject: Re: Trim Moulding Paint   Wed May 30, 2012 8:25 pm
I was thinking that and maybe do the flex additive in the paint with a primer base to eliminate the stainless shine thru and many coats of paint. and enhance the correct texture.
Plasit dip is an interesting alternative if its possible to get it made/mixed in the correct color.
Spoke to a friend of mine at a shop today and going to try a few things.
Good input guys, thankyou
Some point, (96Slowss), we'll cross paths at Halifax show this summer I'm sure. I have seen your car at the cruise nite and the DeSantis show last Sept, when I brought both cars there Cool
PostSubject: Re: Trim Moulding Paint   Wed May 30, 2012 8:47 pm
Scuff real good with 600 grit, wipe with wax/grease remover, one coat of self etching primer, one coat of primer sealer, base coat, then clear coat. I have used clear chip guard down low, before clearing the entire molding.
Wraith'SS
PostSubject: Re: Trim Moulding Paint   Wed May 30, 2012 9:12 pm
Thank you
Trim Moulding Paint
» paint brushes
» Which paint to use where?
» Question: Chipped Paint?
» Need help: How to paint dark and medium dark skin?
» how does one paint a twin-tailed comet? Need help!
