 Radio troubles
PostSubject: Radio troubles   Fri May 08, 2009 12:03 am
So I bought a stock cd radio from a issf member, installed it, found that the fuses had been pulled when the yanked the old radio. Anyway, when the headlights r turned on the display goes dark! Anyone got any ideas?
PostSubject: Re: Radio troubles   Fri May 08, 2009 7:58 am
Is your dimmer working? Does the rest of the lights in the radio illuminate? If just the display, a radio repair shop should be able to fix. Might be worth going to an aftermarket head unit.
PostSubject: Re: Radio troubles   Fri May 08, 2009 8:16 am
yea the dimmer works, i just bought the radio for $50, i'm just wondering if the dimmer in the radio is turned down all the way, not sure whats going on. At least it works, i have tunes now.
Radio troubles
