Today at 4:15 pm by MASShole9C1
Yesterday at 9:21 pm by MASShole9C1
 Adding a tach
PostSubject: Adding a tach   Tue May 08, 2012 12:13 pm
What connector & where can I get pins?
Yes...I'm lazy & dont want to look it up.
Also. I know I'll get some tips with the answer.
Thanks
booth9C1SS
PostSubject: Re: Adding a tach   Tue May 08, 2012 2:37 pm
I think it's A23 in the red connector at the PCM
PostSubject: Re: Adding a tach   Tue May 08, 2012 3:21 pm
Thanks Steve.
How about the pins? any idea where I can get them?
booth9C1SS
PostSubject: Re: Adding a tach   Tue May 08, 2012 3:38 pm
Napa sells them...
Or go to a junkyard to a car that they are about to crush. remove one of the connectors and cut all of the wires with as much length as you can. This method will yield about 30-40 pins. Look for GM B-bodies, F-bodies, vettes, S-10s, Blazers between 94-2000. The pins come out of the connector easily. You will need no more than a paper clip... you might not even need that.
PostSubject: Re: Adding a tach   Tue May 08, 2012 4:14 pm
Nice, didnt think of that.
Notice you said "one they are about to crush" Arrow
PostSubject: Re: Adding a tach   Tue May 08, 2012 4:26 pm
How many you want, have 5 harnesses and 3 cars headed to scrap next sat
PostSubject: Re: Adding a tach   Tue May 08, 2012 4:29 pm
PM sent
PostSubject: Re: Adding a tach   Tue May 08, 2012 5:09 pm
Just for the record, 91-93 pins are the same design. Just might not be the same colored wires. Arrow
PostSubject: Re: Adding a tach   Tue May 08, 2012 5:11 pm
Thanks Justin
Adding a tach
» adding oil to fuels
» Adding cornering lamps
» TD tach race 2012 (Engines on the way home)
» adding a Signal strength meter
» Adding a Base to your Model... what have you done?
