| Need an AC compressor | |
+5No Moa V8Killer IMPALADAKID boojum chapel 9 posters |
chapel
| Subject: Need an AC compressor Mon May 14, 2012 7:25 am | |
| Mine died with a bang over the weekend | |
chapel
| Subject: Re: Need an AC compressor Mon May 14, 2012 9:31 am | |
| wonder if this one is any good http://www.ebay.com/itm/100-BRAND-NEW-A-C-COMPRESSOR-CO-20178DC-/390410686859?fits=Make:Buick|Model:Roadmaster|Year:1995&hash=item5ae64a518b&item=390410686859&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr#ht_4492wt_1396 | |
| Subject: Re: Need an AC compressor Mon May 14, 2012 10:15 am | |
| Advance Auto has one that you can get for $150 with a discount code. | |
chapel
| Subject: Re: Need an AC compressor Mon May 14, 2012 10:25 am | |
IMPALADAKID Admin
| Subject: Re: Need an AC compressor Mon May 14, 2012 10:36 am | |
| code MY30 in the discount code box in the shopping cart. http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Remanufactured-Compressor-with-Clutch-Driveworks_18891994-P_387_R%7CGRP60000_____
Last edited by IMPALADAKID on Mon May 14, 2012 10:38 am; edited 1 time in total | |
chapel
| Subject: Re: Need an AC compressor Mon May 14, 2012 10:37 am | |
| what's the best code to try? that MY30 one? anything better? | |
IMPALADAKID Admin
| Subject: Re: Need an AC compressor Mon May 14, 2012 10:41 am | |
| - chapel wrote:
- what's the best code to try?
that MY30 one? anything better? Order online, choose the "Pick up at store" option, and bring your old one, and get $10 core charge back. Should bring it down to $154.99 | |
| Subject: Re: Need an AC compressor Mon May 14, 2012 11:12 am | |
that MY30 one? anything better? Order online, choose the "Pick up at store" option, and bring your old one, and get $10 core charge back. Should bring it down to $154.99 Should we trust you? I see you only have 42 posts | |
| Subject: Re: Need an AC compressor Mon May 14, 2012 12:36 pm | |
| Subject: Re: Need an AC compressor Mon May 14, 2012 12:56 pm | |
| Subject: Re: Need an AC compressor Mon May 14, 2012 12:57 pm | |
| Use code VISA at advance and get $50 off. | |
chapel
| Subject: Re: Need an AC compressor Mon May 14, 2012 1:48 pm | |
IMPALADAKID Admin
| Subject: Re: Need an AC compressor Mon May 14, 2012 5:26 pm | |
| Subject: Re: Need an AC compressor Mon May 14, 2012 8:06 pm | |
chapel
| Subject: Re: Need an AC compressor Mon May 14, 2012 8:11 pm | |
| Anyone have the electric fan setup? I'd like to do both at the same time. Looks like I need to remove the mechanical fan to get to the compressor? | |
| Subject: Re: Need an AC compressor Mon May 14, 2012 8:48 pm | |
| - chapel wrote:
- Anyone have the electric fan setup? I'd like to do both at the same time. Looks like I need to remove the mechanical fan to get to the compressor?
I believe SS impala nitrous has a fan setup for sale. To swap from mechanical fan, I also believe you have to mess around with the underhoid fuse box by adding the relay and such. I'm sure theres more to it. Mike(96slowss) had a friend also named Mike, who was doing the swap in his B4U Caprice. | |
| Subject: Re: Need an AC compressor Mon May 14, 2012 11:45 pm | |
| - MASShole9C1 wrote:
I believe SS impala nitrous has a fan setup for sale. To swap from mechanical fan, I also believe you have to mess around with the underhoid fuse box by adding the relay and such. I'm sure theres more to it. Mike(96slowss) had a friend also named Mike, who was doing the swap in his B4U Caprice. I did the swap on my RMW. Replaced the mechanical fan with a primary electric one off a Caprice and wired it using Gary's kit (Gary's innovative wiring). You'll need 2 or 3 shorter bolts for the water pump once you get rid of the bracket. I bought a set of grade 8 bolts off the SS forum, but you could get them from a car in the yard with electric fans. I don't recall what length they were. | |
chapel
| Subject: Re: Need an AC compressor Mon May 14, 2012 11:58 pm | |
| Can i run without the mechanical fan or will I overheat? | |
| Subject: Re: Need an AC compressor Tue May 15, 2012 5:59 am | |
| Subject: Re: Need an AC compressor | |
