 Horn wiring question
PostSubject: Horn wiring question   Mon Apr 30, 2012 2:48 pm
I took apart the dash to finish some mods today. In my 96 '9C1, the horn didnt work when I bought it. Assuming it was cut when they swiped all the police stuff out, I hooked up a circuit, from the horn fuse, to a button, then to one of the horns. It works perfect, but I have a dumb horn button now.
So anyway, today I found 2 snipped wires of equal length. one on either side of the underside of the bottom of the steering column. One is light blueish and I believe the other is green. They look factory, have transparent white connectors to the column harness going up, but I cannot find where the would have gone to under the dash. I assume they had an air horn inline with the horn circuit like the department I worked for had the "Thumper" hooked up to.
Is this the horn curcuit? How the heck do I hook them back up to the steering wheel? Thanks for any and all help with this!
PostSubject: Re: Horn wiring question   Mon Apr 30, 2012 3:43 pm
On the impalas (assuming same) there's a black wire to the horn slip ring gnd to the gnd side of the horn relay (convenience center) & a dark grn (always power)to the contact on the horn relay.
PostSubject: Re: Horn wiring question   Tue May 01, 2012 12:31 am
All my 9C1s had the horn wire cut at the top of the driver's inner fender. green wire IIRC. I think it was common practice to wire the horn (button) up to the siren. Find the schematics at http://ss.lencolab.com/
PostSubject: Re: Horn wiring question   Tue Aug 28, 2012 3:49 pm
Thanks Steve and Jim. With the help of the service manual diagrams and a test light. Found the problem. Hint: RPO 6J4
» Horn wiring question
» WIRING QUESTION (answered - please close)
» A470 Outputs [wiring question]
» MK3 VTA Board Wiring Question
