Subject: So I think Sunday is the Day... Tue Apr 24, 2012 7:52 pm
...that the engine is coming out of the Marshmallow.
If anyone would like to lend a hand, come on up!
Subject: Re: So I think Sunday is the Day... Tue Apr 24, 2012 8:05 pm
Put me down as a maybe. I really want to come, but I have to get out of something if I can.
Subject: Re: So I think Sunday is the Day... Tue Apr 24, 2012 8:42 pm
If nothing comes up I'm in for sure.
Subject: Re: So I think Sunday is the Day... Tue Apr 24, 2012 9:52 pm
Awesome! Two firm maybes!
Probably...
I think...
lol!
Subject: Re: So I think Sunday is the Day... Tue Apr 24, 2012 10:00 pm
Probably...
I think...
lol!
Make that three! I've never pulled one so I should go up and observe a bit before I do my own! Then again, I have a boat load of school work being it the end of the semester and possibly work. So...maybe!
nttyfufu
Subject: Re: So I think Sunday is the Day... Wed Apr 25, 2012 11:34 am
Not to thread jack but... Hey Matt I'm gonna be pulling the motor and trans out of my 9c1 in the next month or so so if you want to watch/help/learn it will be right in your own home town.
Subject: Re: So I think Sunday is the Day... Wed Apr 25, 2012 12:02 pm
nttyfufu
Subject: Re: So I think Sunday is the Day... Wed Apr 25, 2012 12:09 pm
HaHa.
Subject: Re: So I think Sunday is the Day... Wed Apr 25, 2012 6:15 pm
Also, I'm a maybe. Might head out to Ironfistdog's place and get my new quarters installed (finally!)
Subject: Re: So I think Sunday is the Day... Wed Apr 25, 2012 9:01 pm
Well, what the hell- I'm a definite maybe too. Probably gotta work but I'll try and sneak out early.
Subject: Re: So I think Sunday is the Day... Wed Apr 25, 2012 9:02 pm
I will try to come by too if I'm free, I'm working Sat, so it's throwing my sched. off!
Subject: Re: So I think Sunday is the Day... Wed Apr 25, 2012 9:25 pm
So maybe everybody will show up. Or maybe they won't.
Subject: Re: So I think Sunday is the Day... Wed Apr 25, 2012 9:53 pm
Now that is one I will make it too, I have to travel farther but I can get there
Subject: Re: So I think Sunday is the Day... Wed Apr 25, 2012 10:34 pm
I'm in process right now. Everythings disconnected & ready to go. Tranny coming out tomorrow. Not looking forward to trying to get at those bellhousing bolts. Consider me part of the thread jack.
Subject: Re: So I think Sunday is the Day... Thu Apr 26, 2012 5:42 am
Put a pan to catch the tranny fluid under the tail shaft, make sure EVERYTHING is disconnected. Remove the crossmember, and let the tranny come down as far as it will go. Now you have direct acces to the bolts with 18" extension. Make sure the torque converter bolts are all out. You will need a 15mm for those three. Tranny bolts are 9/16. You can get the two top tranny bolts from the top before lowering the transmission, then get the other four from below.
Subject: Re: So I think Sunday is the Day... Thu Apr 26, 2012 7:33 am
The bellhousing bolts are easy on a lift!
Subject: Re: So I think Sunday is the Day... Thu Apr 26, 2012 8:51 am
9/16 = 2 tops, tip & extension for the rest....thanks Bill you saved me some time there.
I hate pulling those stock crossmembers.
I've yet to put a stock one back in tho....
Kissing my azz would be easy on a lift too.....
Yea....that's jealousy talkin....ucky bastid
Subject: Re: So I think Sunday is the Day... Thu Apr 26, 2012 8:53 am
I wouldn't know, cause i kiss only Heidi's ass.
Subject: Re: So I think Sunday is the Day... Thu Apr 26, 2012 9:23 am
Subject: Re: So I think Sunday is the Day... Thu Apr 26, 2012 9:47 am
You can get the two top tranny bolts from the top .......
OK, your shytting me right? Holy crap, my hands wont fit in there between the firewall & heads I'm taking a coffeee break & looking again. Any chance of using extension for those too?
BTW to keep this thread current....
Is Crovo...
Still pulling his motor on Sunday?
Still getting nothing but maybe's for help?
Still getting thread jacked?
Sorry Crovo....you know how it is.....
Subject: Re: So I think Sunday is the Day... Thu Apr 26, 2012 10:45 am
Steve, the bellhousing bolts are actually 15mm, or at least, that's what I always used. Lol. Get yourself some "wobble" extensions. They. Are. AWESOME! Will save you headaches everywhere, especially on the upper BH bolts. You can get the all from the bottom with the crossmember out and tranny hanging.
Also, unplug the wiper motor before you drop the tranny. The wiring gets super tight if you don't.
And I have no idea if I'm still doing this sunday. I hope to.
Subject: Re: So I think Sunday is the Day... Thu Apr 26, 2012 11:10 am
Thanks Bill, I have the wobbles & plenty of extension. As soon as I finish degreasing the firewall rash on my arm, I'll drop it. Thanks, everything is unplugged & ready, except for one pesky clamp holding the harness where it goes from driver head ground to over by the pass O2 sensor. Guess GM figured THAT's never coming out under normal circumstances...
Subject: Re: So I think Sunday is the Day... Thu Apr 26, 2012 5:40 pm
I just remembered I'm supposed to be going to the Amherst NH car show/swap thing this Sunday. But, that means I'll be right next to Nashua by the time we leave. I don't know if I'll be behind the wheel of anything so I might not be able to just "drop in" but if I can I'll try to get the "bus" to stop by Crovo's place...lol
Subject: Re: So I think Sunday is the Day... Fri Apr 27, 2012 2:18 pm
OK, not TO bad. Tranny dropped so low I didnt need anythin but an extension on all 6
The rest was baby food
Thanks for the tips Back to your normal SUNDAY programming
ANd Bill....you were SOOOOOO right about draining the tranny fluid. Good news is, my dusty floor is clean now...
Subject: Re: So I think Sunday is the Day... Fri Apr 27, 2012 2:20 pm
where the hell is that shop? Wait, what car are you putting a motor in? I see 2 there. Your not doing the 96 are you?
Subject: Re: So I think Sunday is the Day... Fri Apr 27, 2012 3:50 pm
Steve you're stressing Glen out! Explain to us now!
Looks like he expanded from his previous location. The lucky bastard has plenty of space now...
But seriously Steve what the hell are you doing there? Glen and I both want to know.
Subject: Re: So I think Sunday is the Day... Fri Apr 27, 2012 3:57 pm
Oh I knew what he was doing, just never asked to what.
Subject: Re: So I think Sunday is the Day... Fri Apr 27, 2012 4:04 pm
Even secret society members are left out of the S.S. business eh? interesting.
Subject: Re: So I think Sunday is the Day... Fri Apr 27, 2012 4:22 pm
I am just loaded with wrong information lately.
Subject: Re: So I think Sunday is the Day... Fri Apr 27, 2012 8:50 pm
Jealously.
Subject: Re: So I think Sunday is the Day... Fri Apr 27, 2012 9:24 pm
Bill, if this is still on I'm in for sure. LMK
Subject: Re: So I think Sunday is the Day... Fri Apr 27, 2012 9:34 pm
Yeah, I'll be in the garage all day. If anyone wants to show, you're welcome to!
Subject: Re: So I think Sunday is the Day... Fri Apr 27, 2012 10:16 pm
OK cool I'll be there early AM.
Subject: Re: So I think Sunday is the Day... Sat Apr 28, 2012 9:18 pm
I'm not a definite maybe, I'm an outside chance of maybe. If kids can come it's bumps up my maybe chances by 5 percent or so .
YachtDriver
Subject: Re: So I think Sunday is the Day... Sat Apr 28, 2012 9:31 pm
I will attempt to make an appearance. I have a couple of errands to run tomorrow. This is close to one of them.
Subject: Re: So I think Sunday is the Day... Sat Apr 28, 2012 10:31 pm
Sorry, this isn't a "Kid's friendly" event this time. My wife and daughter will be off galavanting and I will have no one around to watch them. It's just going to be a small group, working all day.
Subject: Re: So I think Sunday is the Day... Sun Apr 29, 2012 8:29 am
... ahhh man really? now what am I suppose to do..... I swear i didnt mean to do it, it was and accident, I promise I wont touch anything, please..... they made me do it, I didnt really want to but then they threaten to stuff me in the trunk of my corolla if I didnt. I can bring cup cakes? you like cupcakes Bill?... yeah you like cup cakes..... so pleaseeeeeee..... I promise it wont happen again..... really mister..... scouts honor....
chapel
Subject: Re: So I think Sunday is the Day... Sun Apr 29, 2012 7:56 pm
how'd it go? today is my kid's birthday party... so I wasn't going to make it
YachtDriver
Subject: Re: So I think Sunday is the Day... Sun Apr 29, 2012 8:08 pm
Progress was made.
Subject: Re: So I think Sunday is the Day... Sun Apr 29, 2012 8:31 pm
YachtDriver wrote:
Progress was made.
LOL! Yeah, we started late and finished early. We got it to within a half hour or so of it being out, and I screwed my back and Tim had to leave...
Thanks for the help, Tim!
chapel
Subject: Re: So I think Sunday is the Day... Sun Apr 29, 2012 8:33 pm
you know what's great for lumbago? Roadmaster seats
Subject: Re: So I think Sunday is the Day... Sun Apr 29, 2012 9:42 pm
YachtDriver wrote:
Progress was made.
Dude that sucks! Glad you got something done though...
If it makes you feel better the lower part of my face and the back of my neck got sunburnt to hell talking to Doug...
YachtDriver
Subject: Re: So I think Sunday is the Day... Sun Apr 29, 2012 10:09 pm
Oh sure. Blame me.....
I did have sunblock you should have asked..
Subject: Re: So I think Sunday is the Day... Sun Apr 29, 2012 10:10 pm
Sorry, I was too busy figuring out Gregg's dual steering wheel option in his Suburban...
YachtDriver
Subject: Re: So I think Sunday is the Day... Sun Apr 29, 2012 10:14 pm
Thought of this when you pulled away.
Subject: Re: So I think Sunday is the Day... Sun Apr 29, 2012 10:22 pm
Hahaha, I forget if it was you but someone brought that up today, I'd never seen that commercial.
Forgot to mention, there was a 77ish Bonneville coupe at the swap meet with an LT1 and 4l60e in it for sale, I think it was 3 grand? Needed a paint job and had a vinyl top though.
Subject: Re: So I think Sunday is the Day... Sun Apr 29, 2012 10:49 pm
Of all the people on this forum to forget pics...where are they!?
I'd like to see that
Subject: Re: So I think Sunday is the Day... Mon Apr 30, 2012 6:07 am
[quote="toomanytoyz" LOL! Yeah, we started late and finished early. We got it to within a half hour or so of it being out, and I screwed my back .....[/quote]
I had a contractor that always used THAT excuse for an early quitting time
Lucky for you I remember you saying you were flat on your back weeks ago or I'd call BS
