All of mine came with RSAs except the Roadmaster sedan Sheriff's car had Eagles.
Steve, I said
greater than $2500 so there is room for T84s if you want them. I will require a larger deposit.
Found 87,150 vehicles matching your year and model in our database.
RPO Description Matches
UM7 RADIO,AM/FM STEREO,ETR,INCLUDES CLOCK STEREO W/CLK(UM7)
22,699
UQ0 SPEAKER SYSTEM,4,DUAL FRONT DOOR MOUNTED,DUAL STANDARD RANGE PACKAGE SHELF/QUARTER 4 SPKR SYS(UQ0)
27,083
UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1)
82,758
U11 CLUSTER,INSTRUMENT,POLICE CERTIFIED SPEEDOMETER(SEO) SEO POLICE INST CSTR(U11)
26,351
U73 ANTENNA,FIXED FIXED ANT(U73)
46,579
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
75,548
VM3 LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH 5 MPH BUMPER INFO LABEL(VM3)
65,393
VQ2 FLEET PROGRAM - DEALER ASSISTANCE, HOLDBACK NOT APPLICABLE
17,949
V03 COOLING SYSTEM,EXTRA CAPACITY EXTRA CAPACITY CLG(V03)
63,629
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
78,036
WU1 SWITCH INSTRUMENTATION LIGHTING SHUTOFF INSTRUMENT LIGHTING SHUTOFF SWITCH(WU1)
26,351
X2J SEO COLOR - BLUE 8
572
YK6 IDENTIFICATION - (SEO)
28,294
01L EXTERIOR COLOR,SECONDARY SPECIAL (01L)
8,597
01U EXTERIOR COLOR,PRIMARY,SPECIAL OVERRIDE (01U)
8,597
1AA SALES INCENTIVE - RETAIL AMENITIES -- DELETE
33,237
1K5 TRANSMISSION LOW GEAR BLOCKOUT SEO LOW GEAR BLOCKOUT(1K5)
28,240
1PP PAINT SCHEME - 1 5
587
1SA PACKAGE-OPTION 01 (1SA)
29,343
1T1 HOSE,RADIATOR & HEATER,SILICONE RUBBER SE0 SILICONE RUBBER HOSE(1T1)
28,240
1Z2 Unk. 28,242
30D TRIM COMBINATION CLOTH, MED DK ADRIATIC BLUE (D) (94) (30D)
10,649
30I INTERIOR TRIM MED DK ADRIATIC BLUE (I) (94) (30I)
29,618
41Q MOLDING COLOR,BLACK (41Q)
20,107
6A2 STEERING COLUMN,SEO KEYED SEO KEYED STRG COL(6A2)
28,240
6A3 HEAVY DUTY FRONT AND REAR FLOOR MAT HVY DUTY FLR MATS(6A3)
16,589
6A4 KEY,SINGLE KEY SYSTEM FOR ALL LOCKS,NO SPECIAL CODE SINGLE KEY SYS(6A4)
21,460
6B2 REAR DOOR HANDLE(INOPERATIVE) SEO INOPERATIVE R/D HDL(6B2)
8,947
6C7 LAMP,PASSENGER DOME SEO PASS DM LP(6C7)
21,121
6H7 LOCK CONTROL RR CMPT - AUTOMATIC TRUNK, RELEASE, LH
25,433
6N5 RR WINDOW HANDLES- INOPERATIVE SEO INOPERATIVE R/WDO HDLS(6N5)
9,060
6N6 RR DOOR LOCKS- INOPERATIVE SEO INOPERATIVE R/D LKS(6N6)
7,355
6SD COMPONENT-COMPUTER SELECTED SUSP SUSP(6SD)
14,508
6Y5 ORNAMENTATION - EXTR, EMBLEM, NON-INSTALLED
28,240
7B3 SPECIAL HANDLING SUSPENSION SEO SUSP(7B3)
33,347
7L9 COOLING SYSTEM - STEERING, OIL
26,351
7P8 COOLER,ENGINE OIL AUXILIARY SEO AUX ENG OIL CLR(7P8)
26,361
7SD COMPONENT-COMPUTER SEL SUSP SUSP(7SD)
14,513
7X8 SPOTLAMP-PROVISIONS, LH PROVISIONS LH SPLP(7X8)
1,625
7Z5 FUSE BOX,ADDITIONAL 12 VOLT SEO ADDITIONAL 12V FUSE BOX(7Z5)
24,745
8RJ COMPONENT RR LH - COMPUTER SEL SUSP (8RJ) SUSP(8RJ)
14,508
9C1 POLICE CAR SEO POLICE CAR(9C1)
26,351
9RJ COMPONENT RR RH - COMPUTER SEL SUSP (9RJ) SUSP(9RJ)
14,508
AAT PAINT PROCESS - TWO TONE SPECIAL
5,043
AA7 WINDOW,ELECTRIC OPERATED,QUICK OPENING QUICK OPG ELEC WDO(AA7)
83,017
AG1 ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER MULTI-DIRECTIONAL PWR D/SEAT ADJR(AG1)
57,834
AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
87,150
ARL PLANT CODE-ARLINGTON TX, CPC ARLINGTON,TX ASSEMBLY PLANT(ARL)
87,150
AS7 SEAT,55-45 FRONT SPLIT FRT SPLIT ST(AS7)
44,130
A75 SPRING,SEAT FRONT,CUSHION AND BACK,HEAVY DUTY HVY DUTY FRT ST(A75)
28,183
A76 SPRING,SEAT REAR,CUSHION AND BACK,HEAVY DUTY HVY DUTY RR ST(A76)
28,183
BF9 COVERING,FLOOR MAT(DELETE) BF9)
20,404
BZ9 VEHICLE GM PROD WEEK 18 GM VEH PROD WEEK 18(BZ9)
872
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
81,260
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
87,150
DE3 MIRROR O/S LH & RH, REM CONT, ELECT, FOLDING, PAINTED O/S MIR(DE3)
22,164
DL5 DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5)
57,217
EGW FLEET PROGRAM - DELAYED WARNING
27,204
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
83,381
FLT SALES PROCESSING - OPTION
31,529
GU4 AXLE,REAR,3.08 RATIO 3.08R(GU4)
41,298
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
45,052
IHD TRIM - INTERIOR DESIGN (HD)
10,810
JA9 BRAKE HEAVY WEIGHT, DISC/DISC BRAKE,HD DISC/DISC(JA9)
26,351
JL9 BRAKE SYSTEM,POWER,FRONT AND REAR DISC,ANTILOCK FRT & RR DISC ANTILOCK BRK(JL9)
47,785
KD1 COOLING SYSTEM,TRANSMISSION OIL TRANS OIL CLG(KD1)
54,551
KG9 GENERATOR,140 AMPERE 140 AMP(KG9)
69,902
LT1 ENGINE-GAS, 8 CYL, 5.7L(5.7P),MFI,HO 5.7P(LT1)
52,349
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0)
87,150
M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30)
87,150
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5)
83,433
NB8 EMISSION OVERRIDE CALIFORNIA SYSTEM EMIS SYS(NB8)
3,786
N10 EXHAUST SYSTEM,DUAL D/EXH(N10)
52,349
N30 STEERING WHEEL(DELUXE) DELUXE STRG WHL(N30)
54,662
N40 STEERING,HYDRAULIC(NON-VARIABLE) NON-VARIABLE P/S(N40)
87,150
N81 TIRE,SPARE(FULL SIZE RADIAL) FULL SIZE RADIAL SPA(N81)
TIRE,SPARE(FULL SIZE RADIAL)(EXPORT) FULL SIZE RADIAL SPA(N81)(EXPORT)
80,122
N97 WHEELS,15X7,HEAVY DUTY HVY DUTY WHL(N97)
28,240
P03 COVER,WHEEL WHL CVR(P03)
14,208
P2B PRICING TWO COLOR, CLASS A (B/F/W-TRK CKGMST) CLASS "A" TWO COLOR PRICING(P2B)
4,645
QQG TIRE ALL- P235/70R15/N BL R/PE ST TL AL3 107V TIRE(QQG)
8,913
R4Y TIRE BRAND ALL - GOODYEAR
21,077
R6D CONTROL - SALES ITEM NO. 04
24,428
R7A CONTROL - SALES ITEM NO. 26
75,761
Rarity...
There are 165 1995 CAPRICE CLASSIC 4 DR vehicles (0.189%) matching your exact options list. There are 165 (0.189%) with at least as many options.
