 rear popouts are leaking
chapel
PostSubject: rear popouts are leaking   Sun Apr 22, 2012 5:11 pm
One hinge on both sides seems to be gone so it's only held in by one side each and at speed, the glass shifts and lets water in... so..... how do I fix that?
PostSubject: Re: rear popouts are leaking   Sun Apr 22, 2012 5:25 pm
Silicone them shut if you don't really use them. I did that to a truck that had the hinges broken. I did not care if they opened.
chapel
PostSubject: Re: rear popouts are leaking   Sun Apr 22, 2012 5:40 pm
I don't really use them, but I would like to use them as I kinda like using the rear seats
PostSubject: Re: rear popouts are leaking   Mon Apr 23, 2012 9:12 am
If the hinge is just separated from the glass remove the roll pin from the latch and open the window all the way use some 5-min epoxy to glue the hinge back to the window. Use a strip of cardboard on the outside glass and on the hinge and clamp with vice grips or small c-clamp till it dries then scrape any cardboard off the hinge that may have stuck during the bonding.
If the hinge is broken in the middle get a new one from the junk yard, heat the glass with a propane torch and the glue bond will break. Don't over heat it and you shouldn't get a broken window/glass shrapnel.
chapel
PostSubject: Re: rear popouts are leaking   Mon Apr 23, 2012 9:15 am
am I leaving the two hinges attached to the car when I'm doing this?
PostSubject: Re: rear popouts are leaking   Mon Apr 23, 2012 9:18 am
If you can remove the window and hinges fromhe car it would probably be easier. But it can be glued while in the car.
chapel
PostSubject: Re: rear popouts are leaking   Mon Apr 23, 2012 9:26 am
I don't know if I've got a clamp big enough to go through the D-pillar and hit the hinges
PostSubject: Re: rear popouts are leaking   Mon Apr 23, 2012 9:31 am
^^^^remove roll pin and open window all the way
this allows the window to open up enough to clamp from the bottom of the vent window.
chapel
PostSubject: Re: rear popouts are leaking   Mon Apr 23, 2012 9:33 am
*smacks head*
durrrrrrrrrrrrrrrrrrr
PostSubject: Re: rear popouts are leaking   Mon Apr 23, 2012 12:40 pm
If that fails PM me, I have a few spare windows with good hinges.
chapel
PostSubject: Re: rear popouts are leaking   Mon Apr 23, 2012 12:42 pm
thanks
» FODEN REAR SPRINGS
» GN rear window mod
» roadmaster rear 8.5"?
» Rear end Gear ratio's?
» F/S new G body rear springs
