| Need some suspension suggestions | |
chapel
| Subject: Need some suspension suggestions Sun Apr 15, 2012 8:28 pm | |
| my shocks seem pretty worn and I know the rear air shock has a leak or something... either way, the car's a bit overly rollie-poly over bumps and I wanted to get something SLIGHTLY more stiff and in control. I'm not sure how old the springs are, but I might as well replace those too if I can afford to. I'd LIKE to remove the air suspension if I can too and make it simpler. | |
| Subject: Re: Need some suspension suggestions Sun Apr 15, 2012 8:39 pm | |
| Gabrial Ultras at autozone are a decent inexpensive shock that will get rid of the bounce. Regular front and rear front http://www.autozone.com/autozone/parts/Gabriel-Ultra-Shock-Strut-Front/1994-Chevrolet-Caprice/_/N-j0wemZ8oxxw?itemIdentifier=220145_172635_7413_2183 rear http://www.autozone.com/autozone/parts/Gabriel-Ultra-Shock-Strut-Rear/1994-Chevrolet-Caprice/_/N-j0wemZ8oxxx?itemIdentifier=358820_6880_7413_2183 Police/taxi front http://www.autozone.com/autozone/parts/Gabriel-Ultra-Shock-Strut-Front/1994-Chevrolet-Caprice/_/N-j0wemZ8oxxw?itemIdentifier=62851_172635_7413_3899 rear http://www.autozone.com/autozone/parts/Gabriel-Ultra-Shock-Strut-Rear/1994-Chevrolet-Caprice/_/N-j0wemZ8oxxx?itemIdentifier=258467_6880_7413_3899
chapel
| Subject: Re: Need some suspension suggestions Sun Apr 15, 2012 8:48 pm | |
| Police/Taxi are heavier duty and good for a wagon? | |
chapel
| Subject: Re: Need some suspension suggestions Sun Apr 15, 2012 8:49 pm | |
| anything fancy I need to do to disable the air assist for the rear? Just pull a fuse or are there lines I need to remove? | |
| Subject: Re: Need some suspension suggestions Sun Apr 15, 2012 9:24 pm | |
| Just unplug the compressor and you'll be fine | |
chapel
| Subject: Re: Need some suspension suggestions Sun Apr 15, 2012 9:27 pm | |
| that's what I figured. you never did the suspension on it, right? | |
| Subject: Re: Need some suspension suggestions Tue Apr 17, 2012 12:51 pm | |
| I have the Gabriel Ultra's in the rear of my wagon. VERY nice shock. Coupled with the CC623 variable rate spring the ride sits and rides great now | |
chapel
| Subject: Re: Need some suspension suggestions Tue Apr 17, 2012 12:58 pm | |
| where do you get those springs from?
is that coil# both front and rear?
| Subject: Re: Need some suspension suggestions Tue Apr 17, 2012 1:00 pm | |
| - chapel wrote:
- where do you get those springs from?
Rockauto. But if you give Autozone/Advance that part number they can order them too. | |
chapel
| Subject: Re: Need some suspension suggestions Tue Apr 17, 2012 1:01 pm | |
| is that coil part# both front and rear?
| Subject: Re: Need some suspension suggestions Tue Apr 17, 2012 1:09 pm | |
| - chapel wrote:
- is that coil part# both front and rear?
No. CC623 is for the rear. I have 5030 for the front which is a 9C1 spring. | |
chapel
| Subject: Re: Need some suspension suggestions Tue Apr 17, 2012 1:17 pm | |
| - Cadet57 wrote:
No. CC623 is for the rear. I have 5030 for the front which is a 9C1 spring. awesome, thanks. so it looks like about $100 for shocks and $100 for springs? anything else that needs to be replaced when doing those? any 'non reusable bolts/nuts' or bushings? | |
| Subject: Re: Need some suspension suggestions Tue Apr 17, 2012 1:21 pm | |
| - chapel wrote:
anything else that needs to be replaced when doing those? any 'non reusable bolts/nuts' or bushings? The Ultra's will come with all new hardware. | |
chapel
| Subject: Re: Need some suspension suggestions Tue Apr 17, 2012 1:26 pm | |
| jeez, you guys are lucky how cheap this can be... $200 with my old cars got you used parts. | |
| Subject: Re: Need some suspension suggestions Tue Apr 17, 2012 1:28 pm | |
| - chapel wrote:
- jeez, you guys are lucky how cheap this can be...
$200 with my old cars got you used parts. I still own the 1.8T. I know... I know.... | |
chapel
| Subject: Re: Need some suspension suggestions Wed Apr 18, 2012 12:39 pm | |
| are the shocks and springs replaceable without an alignment?
and, seeing as I'm at work without my shop manual, how difficult on a scale of 1 to GODF***INGDAMNIT is changing the suspension? | |
| Subject: Re: Need some suspension suggestions Wed Apr 18, 2012 3:07 pm | |
| It is highly recommended when a front steering component is replaced that an alignment should follow. | |
| Subject: Re: Need some suspension suggestions Wed Apr 18, 2012 11:06 pm | |
| Toms right about alignment. Replacing the springs (front) can be a little scary (only because of the power), but, with a helping hand its no problem. New suspensions FTW On the scale....4 ....ONLY because of the front springs & one time battle with upper rear shock mounts.
chapel
| Subject: Re: Need some suspension suggestions Wed Apr 18, 2012 11:07 pm | |
| any special tools required? spring compressor? Is this 'Shock Absorber Socket' necessary? http://www.handsontools.com/Kent-Moore-J-25591-Front-Shock-Absorber-Socket_p_22877.html?utm_source=googlebase&utm_medium=CSE&utm_term=Kent-Moore%20J-25591%20Front%20Shock%20Absorber%20Socket&utm_campaign=BROI | |
| Subject: Re: Need some suspension suggestions Wed Apr 18, 2012 11:19 pm | |
| Nope. I found theyre more trouble to properly implement then theyre worth. Remove the tire & shock Jack under the LCA, loosen BJ castle nut (tap to seperate) Lower jack slowly & remove spring Assemble in reverse. How far are you going?...BJ's too? | |
| Subject: Re: Need some suspension suggestions Wed Apr 18, 2012 11:23 pm | |
| Cant tell what that shock socket is. There is a good one for that. Old shocks I just break it off & go (if your talking fronts). Rears are only because of location & access to both sides of the nut / bolt | |
| Subject: Re: Need some suspension suggestions Thu Apr 19, 2012 5:32 am | |
| I just use a deep 9/16 socket with 12"-18" of extension on it. Place the socket with the extension over the top bolt of the front shock, and move the extension back and forth until the bolt fractures. Could take 5 times. Could take twenty times. Make sure you get at least 6-12" of fore and aft movement. |
chapel
| Subject: Re: Need some suspension suggestions Mon Jun 18, 2012 1:27 pm | |
| I need to get this done next. I gave the front bumper a boot and the car was rolling for days | |
chapel
| Subject: Re: Need some suspension suggestions Thu Jun 21, 2012 12:21 pm | |
| just curious... is there sort of a 'performance' suspension option? I know I'm not gonna make a corner carver... but I'd like to have something a bit more stable | |
| Subject: Re: Need some suspension suggestions | |
