Fuel pump issues EmptyWed Oct 19, 2022 1:27 pm by scot
Fuel pump issues EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Fuel pump issues EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Fuel pump issues EmptyFri Sep 24, 2021 9:53 am by ElKy
Fuel pump issues EmptySun Sep 19, 2021 6:22 pm by black blur 96
Fuel pump issues EmptySun Jun 20, 2021 11:37 am by scot
Fuel pump issues EmptyFri Jun 11, 2021 10:41 am by scot
Fuel pump issues EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Fuel pump issues EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
 Fuel pump issues
3 posters
PostSubject: Fuel pump issues   Fuel pump issues EmptyMon Apr 16, 2012 11:22 pm
My Caprice has been having fuel delivery issues. I can turn a wrench and I'm pretty handy under the hood, BUT, diagnostics are not my strong suit and I'd appreciate a little help from you guys.
Here are the symptoms.
- 99.9% of the time I get no self prime from the pump
- after sitting a while the car will fire up
- if I shut it off, sometimes it won't fire up again
- sometimes motor stumbles with opening the throttle, in park
Facts
- fuel in the tank
- pump runs using test lead
- pump is brand new, just installed yesterday
- trunk ground, and coil grounds are good
- swapped PCM with known good and no change
- swapped FP relay with known good and no change
- FP fuse is good
Possibilities
- fuel pump wiring
- oil pressure switch no good (guage pins when running, wiring diagram suggests the two are somehow linked)
What do you guys think?
PostSubject: Re: Fuel pump issues   Fuel pump issues EmptyMon Apr 16, 2012 11:38 pm
Have you checked the pressure yet? Did you replace the hose from the pump to the top of the sending unit? Those things are known to crack.
PostSubject: Re: Fuel pump issues   Fuel pump issues EmptyTue Apr 17, 2012 12:09 am
Have not checked pressure yet. There is pressure at the valve in back of fuel rail.
When the car does run, the fuel pump stays on and it runs fine.
PostSubject: My experience    Fuel pump issues EmptyTue Apr 17, 2012 12:10 am
I know nothing of the link to the oil pressure switch.
But i do know that when i refurbed my fuel system. = New pump and good used sending unit , I tried to reuse old wirng and when installied it looked fine .But ended up with starting issues.
New harness and it starts and runs fine now.
PostSubject: Re: Fuel pump issues   Fuel pump issues EmptyTue Apr 17, 2012 12:13 am
I did replace that hose and clamped it in place Dave. Thanks Mark. I just might get a new sending unit and upgraded harnesses.
PostSubject: Re: Fuel pump issues   Fuel pump issues EmptyTue Apr 17, 2012 12:31 am
If your sending unit isn't too rusty etc .I'd reuse it .They're awfully expensive.
I got lucky and found one from an SS with 10.000 miles that was being scrapped .
Wirng harness is pretty cheap.Just make sure the connections are tight .
Fuel pump issues BLOWNMUFFLERJULY7TH023
PostSubject: Re: Fuel pump issues   Fuel pump issues EmptyTue Apr 17, 2012 12:34 am
It is a bit rusty. But, it works. I found this topic on ISSF about rebuilding your sending unit. Might give it a shot.
PostSubject: Re: Fuel pump issues   Fuel pump issues EmptyTue Apr 17, 2012 12:43 am
Yea that's a nice writeup.
I love the part about using Ketchup to remove corrision .LOL
I'm pretty sure my problem was the bulkhead connection.
PostSubject: Re: Fuel pump issues   Fuel pump issues EmptyTue Apr 17, 2012 7:40 am
Start with soldering the connections as in that write up and see if that helps. Is it a delco pump?
Fuel pump issues
» Caprice fuel issues
» 95 caprice fuel issues
» Fleetwood fuel delivery issues
» opti?fuel pump? SHIT THE BED
» Which fuel pump?
