| Good News, Bad News | |
| Subject: Good News, Bad News Thu Apr 23, 2009 9:53 pm | |
| Bad news first: #2 son's car went for inspection today and it got confiscated! It seems one of the lower ball joints was so bad they thought it might be unsafe to drive. They refused to let the car go except to be towed or trailered. The State police were called and I'm told we should be expecting a visit from them tomorrow. Also has 4 exhaust leaks (at all the muffler clamps) and needs a new wiper blade.
Good news: The Camaro's driver window fell out after it passed inspection so I can still drive it as long it's not raining. | |
LiveFreeorDieTryin
| Subject: Re: Good News, Bad News Thu Apr 23, 2009 9:59 pm | |
| WTF???? they can take your car????? My god, that is scary. The one thing I don't miss about New England--"safety" Inspections FTL!! | |
JRS9C1
| Subject: Re: Good News, Bad News Thu Apr 23, 2009 10:29 pm | |
| If I were you, I would make it DAMN CLEAR you wouldn't be going back there. EVER! As if they called the state police...SMH... | |
| Subject: Re: Good News, Bad News Fri Apr 24, 2009 9:37 am | |
| That is too bad Jim. I do not know all the laws here in Cow Hampshire, but calling the state police for a ball joint seems a bit extreme. Good news on the broken window. |
| Subject: Re: Good News, Bad News Fri Apr 24, 2009 10:11 am | |
| Jim, how many times do I have to tell you to find a different inspection place???? Jesus!!!!
Do you go to the same one as Mark???
WTF?
GO SOMEWHERE ELSE!!!!!!!!!!!! | |
| Subject: Re: Good News, Bad News Fri Apr 24, 2009 12:03 pm | |
| Well the stud just spins so I'll have to hack it off. Gonna need new front brakes, rotors, water pump and maybe spindle. I think maybe the wheel took a hit some time in the past.
Well I was doing OK with inspections 'til they got all new guys. First I heard of calling the Sate Police 'cause of a bad BJ.
The Camaro window ain't so bad, 'sides I have a whole spare door.
Mark who.
WTF - Work Time Fun?
Of course I'm going back, I already paid.
It's mod (day) marathon weekend. Yahoo... | |
| Subject: Re: Good News, Bad News Fri Apr 24, 2009 12:07 pm | |
| - boojum wrote:
Mark who.
This Mark http://www.inegma.net/mb/index.php?showtopic=4242 |
| Subject: Re: Good News, Bad News Fri Apr 24, 2009 12:22 pm | |
| Hey I'm somewhat of a rebel but I bow in reverence to Mark.
The ball joint is really bad. I don't have a problems with that but towing the car is a bit extreme. Something must have happened at the shop. They seem a little paranoid.
The exhaust leak is my fault. I tend not to tighten the clamps enough.
Bill, have you ever welded stainlees to mild steel?
Well the pizza is gone. Time to go back to work. | |
| Subject: Re: Good News, Bad News Fri Apr 24, 2009 2:50 pm | |
| - boojum wrote:
- Hey I'm somewhat of a rebel but I bow in reverence to Mark.
Well the pizza is gone. Time to go back to work. Yes Welds the same as mild steel. |
| Subject: Re: Good News, Bad News Fri Apr 24, 2009 4:32 pm | |
| Thanks Bill. I couldn't get the AZ ball joint press to work as instructed but in the end I got it to work. The ball joint wasn't too bad. The spindle was the real problem. Somehow the spindle hole was messed up. It had to have been this way for a long, long (± 1 long) time. As if it wasn't torqued correctly. I don't think there was any immediate danger of breaking on the 4 mile ride home. I have to pull a spindle from another car. Got some Spicers to put in. Time for more Pizza. | |
| Subject: Re: Good News, Bad News Sat Apr 25, 2009 9:30 pm | |
| Ball joints are done. The alignment's off a bit but so is the other side. I did a terrible job welding the pipes but it's done. The water pump ought to be easy. | |
| Subject: Re: Good News, Bad News Mon May 04, 2009 12:52 am | |
| Truck Y-pipe has been welded (aka hacked up). The ball socket was rusted. I was too tired to see if I left any pin holes. Access was tight but no way I was going to pull that pipe out. The cat is welded on and it's the size of a small gas tank. The cross member would have had to come out to remove the whole assembly. The things I do to save a few bucks...
Should I dig the weld splatter out of my arm or just let 'em rust? It's only 4 or small ones. | |
| Subject: Re: Good News, Bad News | |
