| TB blade adjustment | |
| Subject: TB blade adjustment Sat Mar 24, 2012 3:36 pm | |
| What do I need to adjust it. I know where & how but dont know whats in that hole? A star? regular allen? I couldve pulled the throttle bracket off & looked in but it wasnt that important. Somebody lmk please. | |
| Subject: Re: TB blade adjustment Sat Mar 24, 2012 6:02 pm | |
| Star not sure on the size, But i suggest pulling the throttle body and reversing the screw to make future adjustments easier. | |
| Subject: Re: TB blade adjustment Sun Mar 25, 2012 12:51 am | |
| This is a quick 1 shot deal. TPS was reading 1.29 slotted it to get .89 need .68 Didnt have my spare TB or TPI @ home so thought I'd play with the TB blades to see if I could drop Volts down & still maintain idle. Didnt want to buy ANOTHER tps to save 1 day. Running ok now so I'll play with stars (thanks Mark) tomorrow & see. I hear you on reversing the screw but this is VERY temporary.... March is goodbye motor month. | |
| Subject: Re: TB blade adjustment Sun Mar 25, 2012 12:59 am | |
- This is a quick 1 shot deal.
TPS was reading 1.29 slotted it to get .89 need .68 Didnt have my spare TB or TPI @ home so thought I'd play with the TB blades to see if I could drop Volts down & still maintain idle. Didnt want to buy ANOTHER tps to save 1 day. Running ok now so I'll play with stars (thanks Mark) tomorrow & see. I hear you on reversing the screw but this is VERY temporary.... March is goodbye motor month. Good bye motor? hmmmm Interesting. Which car? | |
| Subject: Re: TB blade adjustment Sun Mar 25, 2012 11:22 am | |
| The black one | |
| Subject: Re: TB blade adjustment Sun Mar 25, 2012 12:49 pm | |
| I set my Throttle Blades by IAC counts in Datamaster,I try to get them at around 32 with a hot engine and A/C off then I adjust the TPS volts | |
| Subject: Re: TB blade adjustment Sun Mar 25, 2012 1:08 pm | |
| I SO tried to get datamaster working on this car.....failed. Cable passed the ALDL test. TTS said maybe noise...check my grounds etc...got nowhere. Ate up all the free trials, but had a couple of laptops to work with. Gave up but it pisses me off that I cant record, I'd love that capability. I REALLY needed it as I had a very random CEL Car started to high idle yesterday so I looked at the TPS After notching it was still high Volts. Will swap out when I get my spare from work. Thanks for the tip Bobby, maybe I'll try it again.
| Subject: Re: TB blade adjustment Sun Mar 25, 2012 1:18 pm | |
| we will have get datamaster going for you next time we meet. check for vacuum leaks and you want to start setting the IAC with Throttle Blades shut | |
| Subject: Re: TB blade adjustment Sun Mar 25, 2012 9:12 pm | |
| Subject: Re: TB blade adjustment | |
