 Headlight switch replacement?
chapel
PostSubject: Headlight switch replacement?   Wed Mar 21, 2012 10:24 am
My switch is kinda messed up. if it's not turned just to the point of turning the interior lights on, the cluster is dead.
What do I need to replace the switch?
I have the 'twilight sentinel' dial below it (despite not understanding how it works at all)
which one of these would work?
http://www.rockauto.com/catalog/raframecatalog.php?carcode=1022184&parttype=4472&partkey=1980514&a=FRc1022184k1980514-1663016
PostSubject: Re: Headlight switch replacement?   Wed Mar 21, 2012 12:57 pm
Not too sure, I kind of remember getting mine from the dealer years back. I have a spare one for $20 if you want it.
chapel
PostSubject: Re: Headlight switch replacement?   Wed Mar 21, 2012 1:07 pm
does it look like this?
PostSubject: Re: Headlight switch replacement?   Wed Mar 21, 2012 7:57 pm
I'll dig out the spare and take a look. I think the only visible difference between a regular one and one for a car with twilight is a few connections in the plug. My RMW came with the base switch and as a result my twilight never worked.
chapel
PostSubject: Re: Headlight switch replacement?   Wed Mar 21, 2012 10:20 pm
what the hell does it do?
PostSubject: Re: Headlight switch replacement?   Wed Mar 21, 2012 11:02 pm
Twilight sentinel is an automatic headlight system. When the slider is moved from the off position it will automatically activate the headlights when it gets dark out. On top of that, it will keep the headlights illuminated after you exit the vehicle at night. They will stay lit between 30 seconds to 3 minutes depending on where the slider is. To the left is less time right is more time.
chapel
PostSubject: Re: Headlight switch replacement?   Wed Mar 21, 2012 11:29 pm
Does the headlight switch need to be on?
PostSubject: Re: Headlight switch replacement?   Thu Mar 22, 2012 9:53 am
No. Twilight controls all the lights automatically as long as its not set to off.
chapel
PostSubject: Re: Headlight switch replacement?   Thu Mar 22, 2012 10:01 am
oh, neat. ok. I'll give it a try.
so there's like a light sensor?
PostSubject: Re: Headlight switch replacement?   Thu Mar 22, 2012 5:02 pm
Yes, there is a little sensor on the dashboard vent.
» SCA-35 selector switch
» Replacing Selector Switch on PAS 3
» Bypass filter switch Pas-3
» Stereo/Mono Switch....
» Recommended replacement PS transformer for Mk4/
