 Springs
PostSubject: Springs   Fri Mar 16, 2012 9:45 pm
I was thinking of getting these springs for the Impala:
Moog 7170
Inside Diameter 4.000
Bar Diameter .812
Install Height 10.50
Load 1815
Spring Rate 845
Free Height 12.60
Should be around a 1" drop.
And maybe later for the rear:
80108, 5415, 5041, 8537, 5387,6381
Rates range from 169-198
All should be from 1/2"-1" drop.
Any thoughts?
PostSubject: Re: Springs   Fri Mar 16, 2012 9:52 pm
I think they sound like possible spring/fall springs... Wink
PostSubject: Re: Springs   Thu Mar 22, 2012 12:50 am
Moog 7170 in the front (845 lb. for about -1")
and 5387 in the back (157 lb. for about -1/2") or just keep the SS stockers
PostSubject: Re: Springs   Wed Apr 04, 2012 12:39 am
nervermind
PostSubject: Re: Springs   Wed Apr 04, 2012 8:07 am
Why nevermind?
PostSubject: Re: Springs   Wed Apr 04, 2012 9:10 am
Because I went with Moog 5662.
PostSubject: Re: Springs   Wed Apr 04, 2012 9:14 am
I knew that...
Springs
» anybody running eibach springs?
» What is this two-toned lot? Answer - they belong to Palm Springs.
» Palm Springs Pat.No.486
» F/S new G body rear springs
» AFR VALVE SPRINGS?
