February 2018
 sKIPPING sOUND!
PostSubject: sKIPPING sOUND!   Sun May 03, 2009 8:59 pm
i had the skipping sound for awhile now but since i put the summit turbo muffs on the skip is louder. its only coming out the right side of the exhuast pipe..
what the hell could be the problem? scratch
PostSubject: Re: sKIPPING sOUND!   Sun May 03, 2009 9:19 pm
That would be the hesitation you have. So now we know it is in the right bank of cylinders. You need to look for a bad plug, plug wire or injector on that side, or even wiring on that side. I know you had a tuneup, but it still could be a loose plug wire or a cracked spark plug. In the past I have swiched one bank of injectors with the other and discovered the problem moved to the other side. This told me the problem was infact a bad injector.
PostSubject: Re: sKIPPING sOUND!   Sun May 03, 2009 9:22 pm
I still say it's a bad plug wire...
Check to see if any are contacting the exhaust manifold. I bet one is. Maybe number 6?
PostSubject: Re: sKIPPING sOUND!   Sun May 03, 2009 9:33 pm
Ill Check in the AM
thanx
so if the plugs check out .. check the injectors by switching the sides
PostSubject: Re: sKIPPING sOUND!   Sun May 03, 2009 10:00 pm
BoSStonsSS wrote:
Ill Check in the AM
thanx
You might want to wait til saturday for that. I will bring the Vasaline. Suspect
PostSubject: Re: sKIPPING sOUND!   Sun May 03, 2009 10:28 pm
Aren'tcha gonna buy him dinner first or somehing??? affraid
PostSubject: Re: sKIPPING sOUND!   Mon May 04, 2009 3:03 am
Ohhhhhh Geesh You set youself up for that one Bill
PostSubject: Re: sKIPPING sOUND!   Mon May 04, 2009 8:18 am
Yeh Yeh. I know. I forgot (NO HOMO!)
PostSubject: Re: sKIPPING sOUND!   Mon May 04, 2009 10:14 pm
You sure it's not that god awful speaker dragging under the car? It was only held in by half a broken door panel after all Razz
Quick test, does the noise you hear synch up to the music your listening to?
sKIPPING sOUND!
» sKIPPING sOUND!
» Right channel does not sound nearly as loud as the left
» Sculptress of Sound: The Lost Works of Delia Derbyshire
» zenith royal 3000 no stations no sound
» The sound of coyote in the night
