| shudder | |
+1095brmw YachtDriver toomanytoyz No Moa 1984twodoor Cadet57 V8Killer sdstick MASShole9C1 mega 14 posters |
| Subject: shudder Thu Feb 16, 2012 10:04 am | |
| ok i went out to the store today and noticed after the car warmed it started to shudder under patial throttle, wot is fine, I checked tranny fluid and its low. will that cause the shudder or am i looking at opti? | |
| Subject: Re: shudder Thu Feb 16, 2012 11:44 am | |
| Nope, its just your cars sense of humor now that you've got money and time into some custom stuff. Fill the trans, see where it gets you. last time that happened to me, I was out 2nd and 3rd gear. Did an unwanted trans swap.
However, you'll have to go into detail about the shudder, pulling from a stop, what gear its in, noises, etc. | |
| Subject: Re: shudder Thu Feb 16, 2012 11:57 am | |
| Tell me about it I paint it brakes go well irs weird ill top ir off this aftanoon bur when im all warmed up it does it when im up to speed its fine only when im givimg it feom.quarter to half throtrle it does it. Im going to get a opti payday new pan gasket and filtwr as well.
| Subject: Re: shudder Thu Feb 16, 2012 12:16 pm | |
| Have you been playing with the motor at all? I'd look around for bad wires plugs vacuum before I jumped But not an opti, just a cap & rotor right? Tim??? Tim??? where are you..... | |
| Subject: Re: shudder Thu Feb 16, 2012 12:44 pm | |
| All vacum hoses seem to be ok and yrs the whole opti its never been done yet I hope its just low fluid
| Subject: Re: shudder Thu Feb 16, 2012 1:31 pm | |
| ok topped off the fluid and she is doing alot better. there is still a slight hesitation but im leaning toward opti still, since theres new plugs wires egr etc. | |
| Subject: Re: shudder Thu Feb 16, 2012 3:12 pm | |
| getting a whole unit just waiting till payday. tranny filter and new fluid as well. maybe change rear diff fluid to. timing cover do you need to drop oil pan to get it off? | |
| Subject: Re: shudder Thu Feb 16, 2012 3:33 pm | |
| - V8Killer wrote:
- sdstick wrote:
- Have you been playing with the motor at all?
Tim??? Tim??? where are you..... Even if it is just the cap/rotor, they will break off in the housing when you try to change em! What happened to the gorilla emoticon? Ted, please save your old opti for me...thanks PS...and dont try to undo them...cuz well you know ^^^^ | |
| Subject: Re: shudder Thu Feb 16, 2012 4:11 pm | |
| Wait... topped off trans fluid, but think its the Opti? | |
| Subject: Re: shudder Thu Feb 16, 2012 4:24 pm | |
| Subject: Re: shudder Thu Feb 16, 2012 4:25 pm | |
| Subject: Re: shudder Thu Feb 16, 2012 4:28 pm | |
| Im sure if ur opti had 135k on it u would worry about that at least mine took 1 fuel pump and unit | |
| Subject: Re: shudder Thu Feb 16, 2012 4:32 pm | |
| Dont let him fool you Ted, he thought about replacing the distributor too... | |
| Subject: Re: shudder Thu Feb 16, 2012 5:15 pm | |
| Well at least I wont have to worry once I put it ib
| Subject: Re: shudder Fri Feb 17, 2012 1:17 am | |
| - mega wrote:
- Well at least I wont have to worry once I put it ib
Unless it isn't GM, or so I've heard. | |
| Subject: Re: shudder Fri Feb 17, 2012 7:09 am | |
| Subject: Re: shudder Fri Feb 17, 2012 8:43 am | |
- Ted, please save your old opti for me...thanks
What are you hording parts now? | |
| Subject: Re: shudder Fri Feb 17, 2012 8:48 am | |
| idk if ya want it, lastr time i had it out there was a small wiggle in the bearing, I know i shoulda replaced it then but oh well, live n learn right. but if ya want it thats a possiblility at the meet. | |
| Subject: Re: shudder Fri Feb 17, 2012 9:24 am | |
| Yes, I want it. See you at the March meet. Thanks | |
| Subject: Re: shudder Fri Feb 17, 2012 9:26 am | |
| - No Moa wrote:
What are you hording parts now? Feeding 4 mouths right now and...ahhh....yes | |
| Subject: Re: shudder Fri Feb 17, 2012 9:27 am | |
| he's hoarding parts and im trying to get rid of some. | |
| Subject: Re: shudder Fri Feb 17, 2012 10:55 am | |
| Light throttle? Off idle? EGR. | |
YachtDriver
| Subject: Re: shudder Fri Feb 17, 2012 11:00 am | |
| I agree with Bill.
Had the same thing except for the low fluid.
Changed the EGR and it went away. | |
| Subject: Re: shudder Fri Feb 17, 2012 11:21 am | |
| idles great egr and solinoid are new, last spring, its weird i just went for a ride rode perfect. slight hesitation or it just might be me in 2nd gear say im crusing at 35-40 steady throttle and if i give it just a bit more its like it bogs a bit till i give more throttle and it goes just fine. I did notice my tranny fluid is on the darker side so Maybe a flush is in order along with new filter. fuel filter was done around 4k ago new plugs less than 2k on em and wires. next week ill drop the pan and change it out wont hurt right. and ill order a opti just in case.
edit: I just realized i replaced the egr vacume hose last week, maybe it is a bad hose ill look at that to. | |
| Subject: Re: shudder Fri Feb 17, 2012 4:00 pm | |
| - mega wrote:
- idles great egr and solinoid are new, last spring, its weird i just went for a ride rode perfect. slight hesitation or it just might be me in 2nd gear say im crusing at 35-40 steady throttle and if i give it just a bit more its like it bogs a bit till i give more throttle and it goes just fine. I did notice my tranny fluid is on the darker side so Maybe a flush is in order along with new filter. fuel filter was done around 4k ago new plugs less than 2k on em and wires. next week ill drop the pan and change it out wont hurt right. and ill order a opti just in case.
edit: I just realized i replaced the egr vacume hose last week, maybe it is a bad hose ill look at that to. Just because they are new, does not mean they are working correctly. I would unplug the vacum line to the egr, and plug the line with with something, and take it for a ride. If the problem goes away, you need to look at the egr, or solenoid as the culprit. |
| Subject: Re: shudder Sun Feb 19, 2012 12:48 pm | |
| fixt. was just tranny. weird every other car i had when tranny was low it would slip alot. | |
| Subject: Re: shudder Wed Feb 22, 2012 12:13 pm | |
| ok problem is back. I did plug egr and drive it no change, squezzed plunger acted like it wante dto die. so belive there still good. now the problem aint really there till the engine warms up. coolant temp sensor? or opti? tps? it it is ok on wot but anything else boggs out like opti is wet. | |
| Subject: Re: shudder Wed Feb 22, 2012 12:53 pm | |
| Sounds similar to my 9C1. The connector on my coolant temp sensor on the WP came loose. When the connection is lost the computer goes from the actual coolant temp (around 190 degrees) to -140 degrees and dumps gas to try to compensate. Try wiggling it while its running and see if it does anything weird. | |
jvette65
| Subject: Re: shudder Wed Feb 22, 2012 1:37 pm | |
| Subject: Re: shudder Wed Feb 22, 2012 2:02 pm | |
| was your fans running like when you remove the connector and they come on? | |
| Subject: Re: shudder Wed Feb 22, 2012 2:09 pm | |
| im having the opposite problem, mine is ok till warm up no hard starts, I also let it idle till it got really hot fans came one and it never changed idle or anything. same as when it was first started. | |
| Subject: Re: shudder Wed Feb 22, 2012 2:57 pm | |
| When the sensor is unplugged the fans will be on. | |
jvette65
| Subject: Re: shudder Wed Feb 22, 2012 3:44 pm | |
| Hi Ted, yes, after you pull the Engine Coolant Sensor plug away from the sensor (at the water pump) the fans will come on after several seconds. You have changed the fuel filter, but have you checked fuel pressure at idle and when on throttle? Also static pressure check, when engine off and check for fuel pressure bleed down. -Joe
| Subject: Re: shudder Wed Feb 22, 2012 3:59 pm | |
| i dont have a pressure tester. its wierd the only time it has the problem is hot under load. but illl go down to auto zone and see it they got one. | |
| Subject: Re: shudder Wed Feb 22, 2012 4:26 pm | |
| I'm telling ya 02 sensors...... Only happens when warm, stumble under load Look at your plugs are they Black? Running rich? You could be developing an intake gasket leak too. | |
| Subject: Re: shudder Wed Feb 22, 2012 4:36 pm | |
| ill get some carb cleaner and spray the intake while running, also instead of replacing o2's can someone just tune em out. also i did check water pump weep hole dry. i did unplug temp sensor fans came on and idle went higher, then stumbled when I pluged it back in. plugs ill pull em tommorow and check em but i dont see any black smoke out back. MY head says opti, the rest says wtf. didndt some say it one here if you keep feeling its the opti its the opti. I want to be wrong on this. I almost just want a lt1 in there now. | |
| Subject: Re: shudder Wed Feb 22, 2012 4:49 pm | |
| bridged obd port and heater fan comes on. no blink in light just steady on. | |
| Subject: Re: shudder Wed Feb 22, 2012 5:36 pm | |
| ok read this little article and the first to posts are exactly my symptoms. pcm maybe? | |
SPCS
| Subject: Re: shudder Wed Feb 22, 2012 5:38 pm | |
| - mega wrote:
- MY head says opti, the rest says wtf. didndt some say it one here if you keep feeling its the opti its the opti. I want to be wrong on this.
Had the same thing with an L99. Would start and run just fine, but once warmed up, and only when really warm (close to 180°), the engine would shudder, hesitate and generally make no power. This happened at part throttle only, went away at WOT. I suspected the Opti right away, but... While searching for an easier-to-access cause, I swapped out a mildly inefficient (according to the fuell pressure gauge) fuel pump plus filters and pressure regulator, fixed a mild vacuum leak, replaced plugs and wires becaue they were due anyway, did the O2s while I was at it (and because that only takes two minutes on a desert car), threw in a new set of knock sensors and topped it off with a new EGR. Yep, it still turned out to be the Opti. | |
| Subject: Re: shudder Wed Feb 22, 2012 5:47 pm | |
| yep im gonna order one tonight. I am getting really sick of this motor design. I want a old style carbed 383. with a real hei distibutor lol. | |
| Subject: Re: shudder Wed Feb 22, 2012 5:48 pm | |
| Ive got pressure sensor you can use. or you can get a cheapo autozone one that works good. Easy to hook up shrader valve fitting behind the intake near the fire wall. | |
| Subject: Re: shudder Wed Feb 22, 2012 5:49 pm | |
| thanks brian but the way its running im afraid to drive far. good thing autozones like a mile awasy | |
| Subject: Re: shudder Wed Feb 22, 2012 5:50 pm | |
| No problem. Id bring it to you, but its kind of a hike with a baby you know. | |
| Subject: Re: shudder Wed Feb 22, 2012 6:45 pm | |
| opti will be here in 2-6 days | |
| Subject: Re: shudder Wed Feb 22, 2012 7:37 pm | |
| throw some money down with me, lets get that lt1 | |
| Subject: Re: shudder Wed Feb 22, 2012 7:42 pm | |
| if i had it i would I want one now. but after the summer. winter sucks. money wise. | |
| Subject: Re: shudder | |
| shudder | |
