Who is online? | In total there are 9 users online :: 0 Registered, 0 Hidden and 9 Guests None Most users ever online was 182 on Thu May 27, 2021 9:57 pm |
| | another cooling system question | |
soshoresig
Posts : 34 Join date : 2010-09-13
| Subject: another cooling system question Sun Feb 26, 2012 2:06 pm | |
| So as I mentioned in my other post, the mechanical fan belt tensioner seized on the wifes RMW, which has reminded me that 6 months ago her secodary electric fan was running constantly and would not shut off at all. I pulled the relay from the under hood box and kind of forget about it. I think I was messing with the a/c when the fan started stayin on. Any ideas what I may have done?? thanks | |
| | | SPCS
| Subject: Re: another cooling system question Sun Feb 26, 2012 2:23 pm | |
| Not turned off the A/C maybe? A/C "On" is supposed to set off the cooling fans constantly, up to a certain speed, anyway. | |
| | | Guest Guest
| Subject: Re: another cooling system question Sun Feb 26, 2012 3:33 pm | |
| - SPCS wrote:
- Not turned off the A/C maybe?
A/C "On" is supposed to set off the cooling fans constantly, up to a certain speed, anyway. You are correct. I think after 45mph it shuts off. I would say the relay might be bad. I have never seen an LT1 overheat, and I never use A/C. The only way I have ever seen the secondary fan come on is when I force it too by unplugging the coolant temp sensor at the water pump. |
| | | sdstick
| Subject: Re: another cooling system question Sun Feb 26, 2012 4:14 pm | |
| I pulled the mechanical fan right off the RMW. No problems. I didnt pull the bracket yet as I didnt have the shorter bolts available. The secondary will cycle when sitting @ idle for extended periods of time. Dont know if thats all or just mine. | |
| | | 95brmw
| Subject: Re: another cooling system question Sun Feb 26, 2012 5:41 pm | |
| Any CELs? certain ones will cause the fans to run constantly. | |
| | | soshoresig
| Subject: Re: another cooling system question Sun Feb 26, 2012 9:16 pm | |
| A/C is off ( it is February in New England after all) besides it doesnt work. I was playing with the freon, would an overpressure cond cause the fan to run constantly? | |
| | | SPCS
| Subject: Re: another cooling system question Mon Feb 27, 2012 5:51 am | |
| Yes. I'm not sure about the one mechanical / one eletrical setup, but the dual electrical fans will come on at 189 psi for the primary and 240 psi A/C head pressure for the secondary fan, and stay on until pressure has dropped below 150 adn 210 psi respectively. | |
| Subject: Re: another cooling system question | |
