4.10 gears EmptyWed Oct 19, 2022 1:27 pm by scot
4.10 gears EmptyTue Oct 18, 2022 8:58 pm by silverfox103
4.10 gears EmptyTue Sep 28, 2021 11:01 pm by silverfox103
4.10 gears EmptyFri Sep 24, 2021 9:53 am by ElKy
4.10 gears EmptySun Sep 19, 2021 6:22 pm by black blur 96
4.10 gears EmptySun Jun 20, 2021 11:37 am by scot
4.10 gears EmptyFri Jun 11, 2021 10:41 am by scot
4.10 gears EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
4.10 gears EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
 4.10 gears
7 posters
4.10 gears Empty
PostSubject: 4.10 gears   4.10 gears EmptySun Feb 19, 2012 3:30 pm
will i have issues with my new rearend with the 4.10 gears and my stock driveshaft??
4.10 gears Empty
PostSubject: Re: 4.10 gears   4.10 gears EmptySun Feb 19, 2012 3:33 pm
The common answer is 3.73's are the dividing line (some have vibes, some dont)
Anything after that requires a driveshaft.
Also depends on extended LCA's.
Thats just the USUAL answer tho....anything could happen.
4.10 gears Empty
PostSubject: Re: 4.10 gears   4.10 gears EmptySun Feb 19, 2012 3:37 pm
Time to buy a 3" aluminum drive shaft.
Black death 13
4.10 gears Empty
PostSubject: 4.10 Rear end    4.10 gears EmptySun Feb 19, 2012 4:38 pm
I had 4:10 put in in my stock Caprice with LT-1 rearend and used the stock driveshaft and I have had no problems at all with it . Just my speed is looking crazy lol
4.10 gears Empty
PostSubject: Re: 4.10 gears   4.10 gears EmptySun Feb 19, 2012 7:56 pm
I too had 4.11 gears with stock shaft and no trouble.
I plan to go aluminum on the 96 asap
4.10 gears Empty
PostSubject: Re: 4.10 gears   4.10 gears EmptySun Feb 19, 2012 8:00 pm
Mine with the T56 didn't vibrate til about 80mph. But it's a harmonic thing with the steel driveshaft. You just can't avoid the physics... Wink
4.10 gears Empty
PostSubject: Re: 4.10 gears   4.10 gears EmptyMon Feb 20, 2012 10:24 am
thanks i plan on getting a new driveshaft when the new motor goes in. but me new rearend should be in next week and i didnt know if i could do alittle "test driving" with my stock shaft for now..
4.10 gears Empty
PostSubject: Re: 4.10 gears   4.10 gears EmptyMon Feb 20, 2012 11:54 am
Yes, thats why a drive-shaft loop is such a great idea!
Calculate your driveshaft speed by tire diameter & wheel RPMs, rear gear ratio and the maximum expected vehicle speed.
Then, measure your driveshaft length and refer to this chart below:
http://www.markwilliams.com/driveshafttech.aspx -
http://www.markwilliams.com/servicebull/sb0049.pdf
http://www.markwilliams.com/driveshafts.aspx -
Here's an interesting calculator page:
http://www.roversd1.nl/sd1web/wheelcalc.html -
4.10 gears Empty
4.10 gears
» Got the new gears in....will update......
» My 4L65-E is complete and professionally installed!!!
» 3.42 gears
» 3.08 gears from 94 Impala
» gears/stall
