 Early '94 SS Front Springs
PostSubject: Early '94 SS Front Springs   Sun Feb 19, 2012 12:39 pm
My '94 Impala sits very high in the front.
This is what I found on the left front spring tag:
FTM
22076511
The RPO codes are 6TM 7TS 8HK and 9HK.
Now I can't find that part number anywhere. The big board says all SSes got part number 22077450.
I can't find any threads regarding some of the early SSes sitting up very high in the front, if they are still there.
So there you have it.
PostSubject: Re: Early '94 SS Front Springs   Sun Feb 19, 2012 12:49 pm
Very early 94s had the higher springs up front. Not sure why. My original 94 was #5500+, and had the lower front springs. The one I had a couple years ago was an early #392, so it had the higher springs. I am not sure where GM made the change. Bruce's 6 speed 94 was also high in the front. And yes, the number was the same. It was just a change in the height.
PostSubject: Re: Early '94 SS Front Springs   Sun Feb 19, 2012 12:51 pm
Mine was manufactured in March. I don't know what number it is.
I say GM used the wrong or different spring for some reason.
PostSubject: Re: Early '94 SS Front Springs   Sun Feb 19, 2012 12:56 pm
But with a RPO of TY the springs should have a TY code. I say GM used the wrong or different spring for some reason.
Your car would be an early car. Production started in late February, or early March of 94 for the WX3 Option.
It might be possible that another suspension package spring was either miss labeled originaly from the supplier, or the true SS springs were not ready, so they let them go out the door with different springs since the car was ready other than the springs. Your guess is as good as mine. They maybe were 93 LTZ springs labeled with the correct SS number.
PostSubject: Re: Early '94 SS Front Springs   Sun Feb 19, 2012 1:00 pm
From the big board production for the SS started on February 14, 1994.
PostSubject: Re: Early '94 SS Front Springs   Sun Feb 19, 2012 1:07 pm
I knew it was around that time. That last one I had was a March car also.
PostSubject: Re: Early '94 SS Front Springs   Sun Feb 19, 2012 1:10 pm
sorry to thread jack where is car number 1
PostSubject: Re: Early '94 SS Front Springs   Sun Feb 19, 2012 1:58 pm
Went to the crusher.
PostSubject: Re: Early '94 SS Front Springs   Sun Feb 19, 2012 2:23 pm
someone really scrapped #1 Impala Surprised
PostSubject: Re: Early '94 SS Front Springs   Sun Feb 19, 2012 2:25 pm
I found a few people with 6TM and 7TM RPO codes that have Roadmaster Wagons and OCCs.
I think Billy is right and someone at GM thought wagon springs would be close enough until the correct springs arrived. Maybe they changed their mind after seeing how high it was.
I add my actual RPO codes to the earlier posts.
PostSubject: Re: Early '94 SS Front Springs   Sun Feb 19, 2012 2:30 pm
someone was probbably new or disgruntle at the factory.
PostSubject: Re: Early '94 SS Front Springs   Sun Feb 19, 2012 6:17 pm
Best I can do
No 6511 bot all around it
PostSubject: Re: Early '94 SS Front Springs   Sun Feb 19, 2012 6:27 pm
Just cut a coil off em and quitcherbitchin... Wink Razz
PostSubject: Re: Early '94 SS Front Springs   Sun Feb 19, 2012 6:30 pm
Your starting to sound like someone who would live across from a McDonalds. Razz
PostSubject: Re: Early '94 SS Front Springs   Sun Feb 19, 2012 6:34 pm
ROFLMAO! I see what you did there! Very Happy
PostSubject: Re: Early '94 SS Front Springs   Sun Feb 19, 2012 6:52 pm
Yes I did. Now slow down! Rolling Eyes
PostSubject: Re: Early '94 SS Front Springs   Sun Feb 19, 2012 7:45 pm
Steve,
Go to page 6-C15 in the not FE1 table.
22076511 is listed a a mid range spring, a couple higher than later SSes (FTY).
It looks like GM had SS FTY springs, pn22077540, back in '91. I think they changed the front springs because the early '94s were too high in the front. HK (rear SS) aren't listed unitl '94. Now I can sleep.
Oh, I'm going to relace or cut them anyway. Nottoworry Smile
PostSubject: Re: Early '94 SS Front Springs   Mon Feb 20, 2012 12:11 am
http://boston.craigslist.org/gbs/cto/2859590006.html
1995 Buick Roadmaster Estate Wagon Caprice 84K
6TM 7TM springs
PostSubject: Re: Early '94 SS Front Springs   Sun May 13, 2012 4:38 pm
FTY Impala on the top.
Early FTM Impala on the bottom.
» Early '94 SS Front Springs
» Official restore/modify my OCC thread
» Front and Rear wheels..
» The Early Crown Lynn Shape 38 vase
» TOTAL DETAIL Sd Kfz 252, 253 & early 250
