 HEADLIGHTS NOT WORKING
PostSubject: HEADLIGHTS NOT WORKING   Thu Feb 05, 2009 8:56 pm
PARKING LIGHTS WORK
TURNING SIGNALS WORK
HIGHBEAMS WORK
HEADLIGHTS DONT? I BOUGHT A HEADLIGHT SWITCH THINKING THAT WAS THE PROBLEM BUT WASNT Crying or Very sad
WHAT COULD IT BE?
PostSubject: Re: HEADLIGHTS NOT WORKING   Thu Feb 05, 2009 9:53 pm
BoSStonsSS wrote:
PARKING LIGHTS WORK
HIGHBEAMS WORK
WHAT COULD IT BE?
Behind the passenger side footwell trim. The piece that goes from under the dash, and becomes the door sill. There is a white box whith a wire harness. This is the control box for twilite centinal. It may have failed and needs replacement. But there is a maxi fuse for just the head lights I think in the fuse panel. Try there first.
PostSubject: Re: HEADLIGHTS NOT WORKING   Thu Feb 05, 2009 9:58 pm
I had both bulbs fail at the same time on my old 9C1. I couldn't believe it! Did you check them? I know it seems unlikely...
PostSubject: Re: HEADLIGHTS NOT WORKING   Thu Feb 05, 2009 10:09 pm
would the high beams still work if the bulbs failed?
PostSubject: Re: HEADLIGHTS NOT WORKING   Thu Feb 05, 2009 10:12 pm
Pull the bulbs out and inspect the elements. Very Happy And yes if the lower elements are the only thing that failed. Wink
PostSubject: Re: HEADLIGHTS NOT WORKING   Thu Feb 05, 2009 10:25 pm
Mine did.
PostSubject: Re: HEADLIGHTS NOT WORKING   Thu Feb 05, 2009 10:28 pm
i'll check tomarrow morning its freezing out there(and finish watching the celts and lakers)...... thanx guyz will definitely check alll those things Very Happy
PostSubject: Re: HEADLIGHTS NOT WORKING   Fri Feb 06, 2009 7:14 pm
Its the black wire connected to the blue socket thingy( its burnt).. what should i do?
PostSubject: Re: HEADLIGHTS NOT WORKING   Fri Feb 06, 2009 9:54 pm
Splice in a new wire. Or you can replace the whole socket. They sell them at Autozone and PepBoys...
Upgrade the wiring. APC makes a nice, cheap harness. There's plenny on eBay, too... Smile
(And it'll help your light output, too! Very Happy)
PostSubject: Re: HEADLIGHTS NOT WORKING   Fri Feb 06, 2009 11:03 pm
thanx man appreciate it Very Happy
PostSubject: Re: HEADLIGHTS NOT WORKING   Sat Feb 07, 2009 8:51 am
NP. Smile
» Triode ST-70 kit, one side not working, fuse blows when biased past 0.9V
» Wanted - Good working posi
» 2012 (working title) - Work In Progress
» waterpump is not working enough
» Philco 47-1227 Phono not working
