| Project L99 | |
Posts : 4253 Join date : 2009-12-16
 | Subject: Re: Project L99 Tue Feb 21, 2012 2:49 pm | |
Posts : 907 Join date : 2011-03-01 Age : 37 Location : Hyannis, ma
 | Subject: Re: Project L99 Tue Feb 21, 2012 2:51 pm | |
| soon hopefully very soon, might go back to work a bit early. |
Posts : 2132 Join date : 2011-01-11 Age : 36 Location : Warren, MA
 | Subject: Re: Project L99 Tue Feb 21, 2012 3:28 pm | |
| White letter tires go almost all the way ( they have a bad relationship with their father.... I'll get the joke outta the way  ) I'm running 215/70r15's on the caddy skinny whites. When I can find time to smooth out the side wall's on a set Im gonna paint 4" whites with roofing paint, it's rubberized and is flexible so it won't crack. Here's a white letter tire cut;
 | Subject: Re: Project L99 Tue Feb 21, 2012 3:45 pm | |
| He needs that height for sweet jumps _________________ Steve 96BBB 28K 3.42 Bolt-ons 95BBB 100K 3.73 383 New DD...already broke fixt the 4L60E twice 95 Black WB4 Hole...ee...grail 96 Black WB4 No holes in this 95BBB 189K 3.08 Old DD Stolen...by Matt.  Whine..eee...Silver LS6 |
 | Subject: Re: Project L99 Tue Feb 21, 2012 4:10 pm | |
| how far would one coil do. |
 | Subject: Re: Project L99 Tue Feb 21, 2012 4:14 pm | |
| Ive still got those ss springs you need right here. If you cut, do one half coil at a time. If you want to do bags later, this isnt a bad alternative, just like we said, you half ass the work, you get a half ass car. |
 | Subject: Re: Project L99 Tue Feb 21, 2012 4:26 pm | |
| yep and I still want the springs btw. with a half coil out and ss springs will front be higher than rear. or is this gonna depend on what spring I have in the car. they are the soft ride ones. |
Posts : 1566 Join date : 2010-06-19 Age : 33 Location : working a corner near you
 | Subject: Re: Project L99 Tue Feb 21, 2012 4:33 pm | |
 | Subject: Re: Project L99 Tue Feb 21, 2012 4:57 pm | |
| i want 9c1 center caps but cheapest repro i found are like 75 bucks. |
 | Subject: Re: Project L99 Tue Feb 21, 2012 5:44 pm | |
| - mega wrote:
- i want 9c1 center caps but cheapest repro i found are like 75 bucks.
Theres a store here where they are $25 a piece. OEM, no repro. Other than that, you can go to the junk yard and try and get some off a conversion van or some GMC work truck. I just sold my last N97/9C1 center cap. |
Posts : 5087 Join date : 2009-07-30 Age : 36 Location : Reading, MA
 | Subject: Re: Project L99 Wed Feb 22, 2012 1:54 am | |
| That looks AMAZING.
Those whitewalls look like they came out pretty damn even! I'm impressed! |
 | Subject: Re: Project L99 Wed Feb 22, 2012 7:20 am | |
| thabks matt. yeah there pretty even. not perfect but fiest time doing it. |
Posts : 1691 Join date : 2009-03-12 Age : 46 Location : Southern, NH
 | Subject: Re: Project L99 Wed Feb 22, 2012 3:16 pm | |
..........and your wheels are regular Civi's right? You'll have to drill and tap them to put N97 caps on. |
 | Subject: Re: Project L99 Wed Feb 22, 2012 3:20 pm | |
| drill and tap no problem. now to figure this stumble out |
 | Subject: Re: Project L99 Sat Feb 25, 2012 10:00 am | |
| well was going through my recipts, and damn. i never realized how much I have done to this car. not everything is here but wow.
Hose, line 32.44 Radiator, Thermo. 170.85 Bolts, air pump delete. 9.56 Oil filter 5.44 3 jaw puller 60.51 Egr, egr valve, egr solenoid,a/c bypass pulley wires, 295.02 Driver o2 sensor, air flow cleaner, 58.29 Wiper blades and washers, 11.63 Fuel pump, sending unit, labor 589.33 Rear brakes, complete drums, shoes hardware, wheel cyl. 203.24 Tow, impound 390.00 Front pads, 20.55 Fuel filter, fuel treat, plugs 41.61 High flow filter, 21.99 Oil filter 5quarts oil, 15.94 Egr gasket, a/c bypass pulley 26.48 Rear 6x9 speakers, 31.86 a/c bypass pulley #3 new belt 38.24 vac hose 3.50 idler pulley 35.99exaust gasket 11.68 timing cover gasket kit, silicone 13.85 5 quart oil, coolant, flush, washer fluid, 32.76 Bolts for exahust 7.94 Coolant, flush 41.70 Tie rods, adj sleeves, idler arm, center link, upper ball joints 235.00 Front pads, rotors 175.00 Opti spark. 49.99 Total to date: 2-25-2011
 | Subject: Re: Project L99 Sat Feb 25, 2012 10:19 am | |
| - Quote :
- Total to date: 2-25-2011
First of all thats a date not a price LOL second of all it's 2012....... Stop living in the past man |
 | Subject: Re: Project L99 Sat Feb 25, 2012 10:35 am | |
| lol i forgot total and im glad i spent all that time and money. makes me kinda feel good that theres that much new stuff in there. |
SPCS
Posts : 122 Join date : 2012-02-17 Age : 40 Location : Stuttgart, Germany
 | Subject: Re: Project L99 Sat Feb 25, 2012 5:18 pm | |
| Some guy in Germany seems to be stealing your ideas! LINK |
 | Subject: Re: Project L99 Sat Feb 25, 2012 5:39 pm | |
| - SPCS wrote:
- Some guy in Germany seems to be stealing your ideas!
LINK
Nope, that one looks better  |
 | Subject: Re: Project L99 Sat Feb 25, 2012 5:43 pm | |
| lmao even got the maltesse cross to. to bad looks like it was a DGGM car. |
 | Subject: Re: Project L99 Sat Feb 25, 2012 6:20 pm | |
| Ok Just scanned your list^^^^ 2 things 1) WTF is $49.99 Opti? OMG....I cant imagine 2) Flashed back to your Tow Impound post....you've come a long way since then. _________________ Steve 96BBB 28K 3.42 Bolt-ons 95BBB 100K 3.73 383 New DD...already broke fixt the 4L60E twice 95 Black WB4 Hole...ee...grail 96 Black WB4 No holes in this 95BBB 189K 3.08 Old DD Stolen...by Matt.  Whine..eee...Silver LS6 |
 | Subject: Re: Project L99 Sat Feb 25, 2012 6:23 pm | |
- Ok
Ebay Opti cap and rotor. |
 | Subject: Re: Project L99 Sat Feb 25, 2012 6:25 pm | |
| i found a opti for 49.99 cant be worse than what i got and cant afford a ac delco. ive had alotof luck with off name parts for some reason. so dont jinx me. lol and i learned alot from that day. but lets not talk about it. lol |
 | Subject: Re: Project L99 Sat Feb 25, 2012 7:17 pm | |
| - mega wrote:
- i found a opti for 49.99 cant be worse than what i got...........
OK....ouch my tongue....ouch my tongue.... - mega wrote:
- so dont jinx me. ...........
OK, I get that. - mega wrote:
- IMPALADAKID wrote:
- sdstick wrote:
- Ok
WTF is $49.99 Opti? OMG....I cant imagine Ebay Opti cap and rotor. whole unit. http://www.ebay.com/itm/260932640431?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Ted, ask Bill how many opti's he's removed / fixed / installed You've posted a gazillion times the past month. PERHAPS you should have asked.... so i'm gonna do the opti, what do youz guyz suggest? Um...OK?  (future reference at this point) PS.....bring me your old one.. |
 | Subject: Re: Project L99 Sat Feb 25, 2012 7:43 pm | |
OK, I get that.
- sdstick wrote:
- Ok
Exactly! I would not trust a 50 buck item like an opti considering it's location if it fails. I would rather buy a ebay brass terminal cap and rotor for $50, and get a decent used ACdelco/Delphi Opti with a Mitsubishi pickup if the one I had was bad. With that you have no Idea what you are getting. I can replace an Optispark in about two hours. Can you? |
 | Subject: Re: Project L99 Sat Feb 25, 2012 7:52 pm | |
| Yes I can. Do I want to ever again? NO!  |
 | Subject: Re: Project L99 Sat Feb 25, 2012 7:53 pm | |
| i will time myself prolly 2 2.5 hours. ive done one before lol.and at the moment trying to save as much as possible. I see a LT1 in my future. |
Posts : 4481 Join date : 2010-03-14 Age : 30 Location : Chicopee, MA
 | Subject: Re: Project L99 Sat Feb 25, 2012 8:08 pm | |
| whats confusing about wanting a lt1 |
 | Subject: Re: Project L99 Sat Feb 25, 2012 8:09 pm | |
| - mega wrote:
- I see a LT1 in my future.
Same, wait...yea |
 | Subject: Re: Project L99 Sun Feb 26, 2012 7:55 am | |
| Grab that 95 road Master wagon Bartend1 has for sale! $200 forthe whole car. Get the engine and part the rest/send to scrap. |
 | Subject: Re: Project L99 Sun Feb 26, 2012 8:55 am | |
| lol. I would have bought that car but no place to put it, condos suck |
 | Subject: Re: Project L99 Tue Mar 06, 2012 4:04 pm | |
 | Subject: Re: Project L99 Tue Mar 06, 2012 4:09 pm | |
| Ted I'm so sorry! Are you gonna insurance money? I know where theres another L99....... Was just starting to look really good too!
 | Subject: Re: Project L99 Tue Mar 06, 2012 4:12 pm | |
| i am gonna go thru insurance but have no clue if they had it or not. guy was drunk, so he is locked up, and his mother was drunk to she got arrested for hitting the cops lol. i need another b body asap, but money, were to get some. i need one dirt cheap idc if it is 20 diff colors, looks like hell. but if they come total this it would be gone asap i want my parts. |
 | Subject: Re: Project L99 Tue Mar 06, 2012 4:13 pm | |
| Oh man, that sucks. Hope you're ok. Just you in the car? _________________ Bill "The Verb" Crovo - Resident Car Slut & Unicorn Hunter  A Toasted Marshmallow, A Long German, A Lame Suburban and expensive dreams... Missing all my previous B's, D's and V... American Ricerwww.badassofne.net"Ooooh! Look! Something shiny!"NO MORE UNICORNS!!!!!LOWER IT!!!  |
 | Subject: Re: Project L99 Tue Mar 06, 2012 4:16 pm | |
| Take the rims and gut as much of the interior and the engine as you can. scrap the rest, Someone here (Lonnie?) was looking for a hood, save the small stuff and scrap the rest,
| my back is toast got home and sat down now can barely move but yeah im ok i guess lol. luckly my son was home. i wish i had a dash cam for the chase, woulda made the cops look bad lol. |
 | Subject: Re: Project L99 Tue Mar 06, 2012 4:19 pm | |
| fenders are good fronts toast, hit a truck but funnyy they ran to. interior may come out and most of the engine parts, before they tow her away i may shed a tear over this. it was very sentimental to me. mirrors gotta come off to lol |
 | Subject: Re: Project L99 Tue Mar 06, 2012 4:25 pm | |
 | Subject: Re: Project L99 Tue Mar 06, 2012 4:29 pm | |
| if i had 1000 right now i would i got like a 100 bucks, this winter killed me with no snow. and i was just looking at it, i guess i gotta wait till insurance cuts a check before i get another one. |
 | Subject: Re: Project L99 Tue Mar 06, 2012 4:33 pm | |
| Damn! Sorry to hear of the bad news man. I hope they get what they deserve and everything works out for you in the end. Dont jump into the first b you find next. Do some looking around or you'll be stuck with a lousy deal you cant get rid of... |
 | Subject: Re: Project L99 Tue Mar 06, 2012 4:34 pm | |
| this has never happened so now im lost idk what to do about insurance and what not. |
 | Subject: Re: Project L99 Tue Mar 06, 2012 4:38 pm | |
| You have to get their insurance info an put a claim in with their company. They will send an appraiser and tell you what it's worth, you have the option to buy the car back from ins for what they deem salvage is worth, then they will cut you the check, If the other guy DOESN'T have insurance then you will have to try and sue them personally or take the loss and try and make as much as you can in parts,
 | Subject: Re: Project L99 Tue Mar 06, 2012 4:43 pm | |
| So they say its valuse is 2000 and scrap is worth 300 i can get them to pay me 1700 and keep the car? |
 | Subject: Re: Project L99 Tue Mar 06, 2012 4:47 pm | |
| Man, I hope they have insurance. Its shocking how many people I had to send walking home and towed the car for no insurance/registration. Chances are you'll be in immediate traffic with about 2 I'd say per day. |
 | Subject: Re: Project L99 Tue Mar 06, 2012 5:31 pm | |
| i bet the truck that i rear ended in all this didnt have it either. he took off faster than the guy that hit me. they got him on about 5 diff thing i know of, dui, leaving scene of mva, leaving scene of injured person, destruction of property, destruction of town property, so he pretty screwed, and it was his mothers lexus and she hit a cop when they showed up. typical white trash cops episode. |
 | Subject: Re: Project L99  | |
| Project L99 | |
