| 3.42 gears | |
| Subject: 3.42 gears Tue Feb 14, 2012 1:07 pm | |
| sellin a set of 3.42 gears with around 3k miles on them. there gm gears came out of 95 ss $50+shipping | |
chapel
| Subject: Re: 3.42 gears Tue Feb 14, 2012 3:32 pm | |
| Subject: Re: 3.42 gears Tue Feb 14, 2012 4:56 pm | |
| Subject: Re: 3.42 gears Tue Feb 14, 2012 7:03 pm | |
| Reluctors for 3.42's are still available http://www.clearimageautomotive.com/chevy_impala_ss_drive_train.php 3.42 reluctor B-body 26018946 (20 teeth) | |
| Subject: Re: 3.42 gears Tue Feb 14, 2012 7:58 pm | |
| I think you can get them from GM too. I think mine was like 7 bucks...? | |
chapel
| Subject: Re: 3.42 gears Tue Feb 14, 2012 8:39 pm | |
| How hard is it to swap rear gears?
| Subject: Re: 3.42 gears Tue Feb 14, 2012 8:53 pm | |
| - chapel wrote:
- How hard is it to swap rear gears?
PITA. Setting the pre load, crush sleeve and all. | |
chapel
| Subject: Re: 3.42 gears Tue Feb 14, 2012 9:16 pm | |
| yeah, was just reading a few magazine articles on swapping into the 10-bolt... the majority of them mention having a professional do it..
I remembered hearing something about setting shims and adjusting gear lash and stuff and it being sort of 'not easy'.
not to mention, I no longer have a press... or any of those fancy tools to install it. | |
| Subject: Re: 3.42 gears Fri Feb 17, 2012 6:16 am | |
| Reluctor http://www.impalassforum.com/vBulletin/showthread.php?t=267903 | |
| Subject: Re: 3.42 gears Fri Feb 17, 2012 8:49 am | |
| I spent some time yesterday reading my GM manual on rebuilding a rearend, its all jiberish to me. lol. | |
| Subject: Re: 3.42 gears Fri Feb 17, 2012 9:17 am | |
| it really is to bad.. i had no idea what to do till i torn into mine with my dad(who knows what hes doin) and it really is a simple set up. biggest part it getting the lash right and lining up the gears.. i watched him do his rearend over in his 53 chevy and drive it to ohio so i think i trust him doin it | |
| Subject: Re: 3.42 gears Fri Feb 17, 2012 9:18 am | |
| Probably like anything else, once you know what to do, its MUCH easier. The pinion gear can go front to back The carrier can go left to right. Getting those 2 positioned properly is the part that bothers me, especially when they say the crush sleeve has to be correct, so crushed, but not to much. Maybe if the rear was on a bench & I had no time limit.....but....nah....thats not gonna happen. | |
| Subject: Re: 3.42 gears Fri Feb 17, 2012 9:23 am | |
- Probably like anything else, once you know what to do, its MUCH easier.
The pinion gear can go front to back The carrier can go left to right. Getting those 2 positioned properly is the part that bothers me, especially when they say the crush sleeve has to be correct, so crushed, but not to much. Maybe if the rear was on a bench & I had no time limit.....but....nah....thats not gonna happen. I've got a bench, and no time limit, and i'm still not doing it. | |
| Subject: Re: 3.42 gears Fri Feb 17, 2012 11:47 pm | |
| - No Moa wrote:
The pinion gear can go front to back The carrier can go left to right. Getting those 2 positioned properly is the part that bothers me, especially when they say the crush sleeve has to be correct, so crushed, but not to much. Maybe if the rear was on a bench & I had no time limit.....but....nah....thats not gonna happen. I've got a bench, and no time limit, and i'm still not doing it. Theres my philosophy! | |
| Subject: Re: 3.42 gears | |
| 3.42 gears | |
