 ABS- light on code 61?
94SSkid
PostSubject: ABS- light on code 61?   Sun Apr 26, 2009 9:49 pm
Hey guys, I have had a light on for about a year. Finally found someone will a scanner. The ABS code was 61 and said something about the pump? I am horrible at Abs. any ideas? I checked the sensors while i test drove it with the scan tool in. All the wheel sensors were reacting equally same speed. I could really use some help thanks for those who have input.
PostSubject: Re: ABS- light on code 61?   Sun Apr 26, 2009 10:50 pm
I don't know much about the ABS system, but if the sensors appear to be working, and the fuses to the pump are good, then I'd replace the pump unit. There's plenty of used ones in the boneyard.
In fact, I know of a nice one in Pawtucket... Wink
94SSkid
PostSubject: Re: ABS- light on code 61?   Tue Apr 28, 2009 1:24 pm
Yeah thats what i'll have to do. You wouldn't know how much they go for?
PostSubject: Re: ABS- light on code 61?   Tue Apr 28, 2009 9:33 pm
not cheap iirc, but isnt there a speical way to bleed them,
PostSubject: Re: ABS- light on code 61?   Tue Apr 28, 2009 9:45 pm
Just pm gastt on this forum. He has one in a wagon he is parting out. If it is still availible, he will hook you up.
PostSubject: Re: ABS- light on code 61?   Wed Apr 29, 2009 5:25 pm
EYE didn't take it... If THAT's what you're implying... Wink
PostSubject: Re: ABS- light on code 61?   Wed Apr 29, 2009 6:59 pm
Nope. Just connecting the dots. Wink
» ABS- light on code 61?
» SEM Color Code for 94 SS Interior...
» Pass Key Light?
» Light Warrior Deck
» Code enforcement: Hobbyist loophole?
