» C10: Before and After
evap canister lines EmptyThu Apr 11, 2019 12:47 pm by MalibuSSwagon
evap canister lines EmptySat Mar 16, 2019 8:49 am by boojum
» Mass refugee now in Pa
evap canister lines EmptyTue Jan 22, 2019 8:46 am by MASShole9C1
evap canister lines EmptyTue Jan 22, 2019 12:03 am by boojum
» 1996 DGM RMW
evap canister lines EmptyFri Jan 18, 2019 12:00 pm by Gorillabiter
evap canister lines EmptyWed Oct 31, 2018 7:53 pm by Ironfistdog
» Roundup pics?
evap canister lines EmptyTue Oct 23, 2018 12:41 pm by silverfox103
evap canister lines EmptyThu Oct 18, 2018 7:51 pm by silverfox103
» Looking for exhaust part
evap canister lines EmptyTue Oct 16, 2018 12:37 pm by fatvet
May 2019
Share
 evap canister lines
PostSubject: evap canister lines   evap canister lines EmptySat Jan 28, 2012 8:40 pm
I was able to breifly look at the canister and saw all the line were dry rotted. anyone know what size all the rubber ones are?
PostSubject: Re: evap canister lines   evap canister lines EmptySat Jan 28, 2012 8:47 pm
Bring a piece with you to Autozone, match it up to the sizes of hose the have in stock. Problem solved.
PostSubject: Re: evap canister lines   evap canister lines EmptySat Jan 28, 2012 8:51 pm
kinda didnt want to rip the bumper off drive to autozone and check. Only have one car.
PostSubject: Re: evap canister lines   evap canister lines EmptySat Jan 28, 2012 10:11 pm
Dont quote me, but I remember using 5/8 fuel hose to fix mine. Only because I already had it in my parts box. It was more of a trial and error thing.
PostSubject: Re: evap canister lines   evap canister lines EmptySat Jan 28, 2012 10:36 pm
I think you can see it by the pass side frame where it connects to the fuel line vent hose. Those hoses always are dryrotted. Did you get a CEL? if not leave it be.
You will break some plastic if you want to replace it all. Pull out the plastic cover that the air dam attached to & you'll see part of it. Access sucks.
EDIT: Assuming your cars like mine...
evap canister lines Impala2010002
PostSubject: Re: evap canister lines   evap canister lines EmptySun Jan 29, 2012 6:20 am
getting at it aint a problem. well after the fronts off the car lol. but these line are really bad. were if i touched it it will go to dust.
Ill give those 5/8 lines a try, think I got some of that.
evap canister lines
» evap canister lines
» Fry in filter bigger
» Braided Stainless Brake Lines
» Finished my PH15 but humming
» Hallard and Munakata
