 Tachometer wiring
PostSubject: Tachometer wiring   Fri Jan 13, 2012 8:37 pm
I'm sure someone out there knows where that wire is. Can anyone tell me which wire to tap into to hook up my tachometer? Thanks.
PostSubject: Re: Tachometer wiring   Fri Jan 13, 2012 8:54 pm
PostSubject: Re: Tachometer wiring   Fri Jan 13, 2012 9:19 pm
cheers That is exactly what I was looking for. Thank you.
PostSubject: Re: Tachometer wiring   Sat Jan 14, 2012 6:42 am
Rob
If you can't find the connector, you can use the coil wire plan as well. Both are discussed here.
http://www.theherd.com/articles/tach.html
PostSubject: Re: Tachometer wiring   Sat Jan 14, 2012 5:41 pm
Does any one know locally where I can get one of the pcm pins to do this?
PostSubject: Re: Tachometer wiring   Sat Jan 14, 2012 5:47 pm
Dover auto world or radio shack I would guess. If you go to the coil wire, just strip back some insulation, wrap the tach wire around the exposed wire, solder and tape. No need to look for connector. I have used this location at least 4 times with no problems.
PostSubject: Re: Tachometer wiring   Sun Jan 15, 2012 5:35 am
radio shack has them. there in those drawers with all the switches and stuff. dont ask the guys that work there though.. they dont know squat.
Tachometer wiring
» NEED HELP WITH G.E. MODEL GD-60 WIRING
» Hobbico Tachometer on Sale $21
» Final wiring procedures on ST-120
» New AC plug wiring for ST-70
» VTA-70 LED wiring....
