 Is this legal?
PostSubject: Is this legal?   Sun Jan 08, 2012 5:46 pm
PostSubject: Re: Is this legal?   Sun Jan 08, 2012 6:08 pm
Headlights on at night are not legal in any state. You must shut them off as soon as it gets dark. Razz
PostSubject: Re: Is this legal?   Sun Jan 08, 2012 6:24 pm
Hmmm, did you do something to the marker lights?
PostSubject: Re: Is this legal?   Sun Jan 08, 2012 10:07 pm
I moved the turn signals/marker lights into the cornering light housings. I was going to add cornering lights, but I like the look of this and might add fog lights or second high beams where the turn signals are supposed to go.
PostSubject: Re: Is this legal?   Sun Jan 08, 2012 11:42 pm
You're gonna have to supply us with a video! I like the extra high beam idea a lot TBH Can't wait to see which way you go with it.
PostSubject: Re: Is this legal?   Mon Jan 09, 2012 12:09 am
Now that's a great idea!
It's legal in MA as long as the bulbs/lens is amber...... (I used to get stopped ALOT! Very Happy )
I'm gonna do clear corners in the caddy,
If this works out for you I may try to add fogs to the lac's setup.
Great job Mike !!!!
PostSubject: Re: Is this legal?   Mon Jan 09, 2012 12:45 am
That looks pretty awesome...I'm assuming some sort of fog bulb like what's on my Tahoe may twist into the spot for the inner marker lights, then it would just have to be wired up?
PostSubject: Re: Is this legal?   Mon Jan 09, 2012 7:50 am
That's not a problem; I don't drive with them on. I just put them on when it's parked for decoration.
I turn the dash lights off at night, too. Total stealth mode.
PostSubject: Re: Is this legal?   Mon Jan 09, 2012 7:52 am
Exactly. How do the fog lights turn on in the Tahoe? I was thinking of adapting a Chrysler LHS setup; you pull the headlight switch out to turn the fogs on.
PostSubject: Re: Is this legal?   Mon Jan 09, 2012 10:03 am
+1 if that idea works that's really cool. I would never have thought of that.
PostSubject: Re: Is this legal?   Mon Jan 09, 2012 2:49 pm
On my Tahoe there is a button on the dash you push to turn them on, and you push it again to shut them off again, it's a momentary contact switch I guess. They shut off if you shut the truck off, and you have to turn them back on again manual when you restart...on my truck it may be a complicated system...however the bulbs themselves seem like they may work in the headlight capsules on a caprice? I think my bulbs are an "880", the ones for non-Z71 Tahoes are a different bulb...
PostSubject: Re: Is this legal?   Tue Jan 10, 2012 10:33 am
aset of retrofit projectors in there hooked to high beam would work better with a clear polished lense.
Nick
Is this legal?
» My Exodia Deck (Legal)
» Stealth Rock+Sheer Force
» Vylon Disigma
» Hey Guys. Newbie diggin the site!
» Ice Barrier deck
