 Undercarriage winterizing (Revisited)
PostSubject: Undercarriage winterizing (Revisited)    Sun Dec 18, 2011 8:25 pm
OK so I will be driving the Fleetwood through winter. I have steelies and snow tires on it already. Last year I did a half assed job on the Roadmaster. The rust did seep back through the shitty coat of spray paint.
I want to give the wheels another coat of red paint. I like them red it gives it a nice subtle touch.
My plans this time:
Scrape everything using surfacing discs and or wire brush.
Rust converter with a brush
Spray on paintable rubberized undercoat
Paint floors white, frame and suspension black
I have access to a lift so I'll be able to do this in an afternoon.
Any other suggestions? (I'll be less stubborn this time) Smile
PostSubject: Re: Undercarriage winterizing (Revisited)    Sun Dec 18, 2011 8:35 pm
CHAINSAW OIL
PostSubject: Re: Undercarriage winterizing (Revisited)    Sun Dec 18, 2011 8:45 pm
PostSubject: Re: Undercarriage winterizing (Revisited)    Sun Dec 18, 2011 8:47 pm
Sem Rust-shield. Hands down the best paint Eva! Do it once and forget about it.
Optional: Chainsaw oil does work well
PostSubject: Re: Undercarriage winterizing (Revisited)    Sun Dec 18, 2011 8:54 pm
Where can I get the stuff and how much does it run? How much would I need? I see it comes in different colors. I can just buy white and black and be done.
PostSubject: Re: Undercarriage winterizing (Revisited)    Sun Dec 18, 2011 9:19 pm
It's expensive but less than POR-15. Robbins Auto Parts has it in stock up here. They have a compatible lower cost hardner and gloss enhancer.
PostSubject: Re: Undercarriage winterizing (Revisited)    Sun Dec 18, 2011 9:29 pm
Any auto body supply store ( Providence Paint & lacquer ) Im sure there is one like it near you on the cape.....
........ some Autozone and Advance stores carry select SEM products.
PostSubject: Re: Undercarriage winterizing (Revisited)    Sun Dec 18, 2011 11:04 pm
I will say try using a good application of a paint and frequent underbody washing in lieu of undercoating, I used it and had good luck but sometimes I feel like it could trap in moisture if not applied well. I want to try that SEM stuff, friend used it on his old Caddy and liked it.
PostSubject: Re: Undercarriage winterizing (Revisited)    Mon Dec 19, 2011 10:03 am
Usually the rubberized junk traps in moisture and causes rust anyway.
Fluid film is very good and it does not run off it only keeps creeping into other places. You just have to be interested in a greasy undercarriage.
PostSubject: Re: Undercarriage winterizing (Revisited)    Mon Dec 19, 2011 11:55 am
Dont forget to chase your brakelines (remove the fuel filter bracket to get behind) you know, while your on the llift
» winterizing on a fire escape
» Art Prize revisited
» Build Log: Converting a 31" Super Cub to .049 Power (revisited)
» Attempt an EMU
» Amodel An-26 in Polish markings
