February 2018
 How I Learned to Stop Worrying and Make a 9C1 Clone of the SS
Go to page : Previous  1, 2, 3, 4, 5, 6  Next
booth9C1SS
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Thu Mar 15, 2012 9:07 pm
My car was made within a few days of that one... my vin ends in SR170156... about 400 cars earier. They might have been in the plant at the same time! Shocked Smile
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Thu Mar 15, 2012 11:52 pm
Turns out the instrument cluster is still not working right. I picked up another one tonight.
The car it came from was pick over pretty good. The only other thing left on the interior was the steering column and wheel.
This time maybe I'll 9C1 it before I install it.
You're lucky, if I had thought about it earlier I would have bought that too! Mad
Well you didn't call DIBS so I'm keepin' it. Smile
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Fri Mar 16, 2012 1:58 pm
I said it, you just were'nt there yet Laughing
SPCS
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sun Mar 18, 2012 3:09 pm
Had the 9C6 up on the lift today and checked the frame while I was there, and whadayaknow, Crosses.
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Mon Mar 19, 2012 1:20 am
The only thing that I can think of that has only three different suspension part numbers (or groups of numbers) for all the different models is the body bushings.
cross - 9C1 9C6 (7B3) body mounts
UFO - Wagon body mounts (maybe changed to no stamp '94 and up)
triangle - all the rest (FE1, FE2, FE3, FE4. F41)
part number refernce from Navy Lifer:
http://www.impalassforum.com/vBulletin/showthread.php?t=228460
There was a change,
Technical Service Bulletin number 43-20-01, that eliminated the lower bushings. Despite the issue date on this TSB the change must have been in effect from the start since it seems all Impalas do not have the lower bushings.
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sun Mar 25, 2012 1:50 am
More on the 9C1 oil pressure gage.
I removed the oil pressure and fuel gage from a 9C1 cluster (bottom) and installed it in a civi cluster (middle). They just uplug, no fasteners.
A close up of the different gages.
The small display unit is where the mileage is stored. I also swapped the SS display in to the "new" civi cluster to keep the correct mileage.
The display unit is slightly different in the '94 and '95 clusters that I have taken apart. They are not interchangeable.
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sun Mar 25, 2012 5:09 pm
So the actual LCD screen is where the mileage and stuff is stored? To cool!
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sat Mar 31, 2012 3:22 am
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sat Mar 31, 2012 10:12 am
Are those the 750's or 850's in the middle?
Cool shot!
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sat Mar 31, 2012 11:45 am
From left to right
Winter springs
Spring springs
Summer springs
Fall springs
Extra Fall springs Smile
Early Impala FTM
Eibach 140
Secretly Selected Moog Springs
9C1 FSB
9C1 3/4 coil cut
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sat Mar 31, 2012 12:12 pm
Oh.....NOW its all clear to me.... scratch Razz
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sat Mar 31, 2012 12:21 pm
Fixted, mostly.
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sat Mar 31, 2012 12:23 pm
Thanks, now report back on the handling on those SS moogs Arrow
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sat Mar 31, 2012 10:19 pm
-2.5"
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sat Mar 31, 2012 10:28 pm
Sweet. Have they settled already?
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sat Mar 31, 2012 10:35 pm
Settled about 1/4" overnight and a after few miles on on some bumpy roads. 27" floor to fender with 235 RSAs.
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sat Mar 31, 2012 11:31 pm
What springs are those?
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sat Mar 31, 2012 11:53 pm
Looks good! How's it ride?
1/2" lower would be perfect. Wink
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sun Apr 01, 2012 2:28 am
Secretly Selected Moog Springs Smile
Rides fine, not harsh at all. I'm going to have replace the bump stops or cut them a bit.
Maybe lower wolud be OK but it's too late now and besides my low profile jack just fits. Smile
I did the caster and camber tonight. Sure is easier without rust. Toe Tomorrow. Maybe a 9C1 PCM tune too.
Maybe I'll let out the secret part number after I test 'em out a bit.
BTW the spring height spreadsheet on the big forum is close but I think it's using the wrong motion ratio. Anyone have a lower control arm out the car?
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sun Apr 01, 2012 9:57 pm
....................... Anyone have a lower control arm out the car?
I have a pair out of Matts car sitting at the shop waiting to be stripped for sandblasting.
What do you need?
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sun Apr 01, 2012 10:10 pm
The distance from the bushing bolts to the center of the spring pocket and to the center of the ball joint.
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sun Apr 01, 2012 11:02 pm
Total A-Arm length ref = 15 531 (Center BJ to Center Pivot axis) (D2)
Ball Joint Ref point
Spring Pocket Ref point
Bushing Axis Ref
Spring pocket to bushing axis = 15.531-7.625= 7.906 (D1)
I tried to get the pic angle correct so you could see the ref points
The ball joint pic was a little tough because I angled it perpendicular to its mounting surface.
Bottom line is, you should be damn close with these dimensions.
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Tue Apr 03, 2012 12:27 am
Thanks Steve. So the ratio is about .5 (assuming the spring angle is 90°).
From the forum spread sheet data and my springs a stock SS with stock tires should be about 28.3" from the ground to the fender. Sound about right? With the early SS springs I was at 29.5".
I installed 750 lb. Moog 5662 springs. These have beed used on A-bodies, G-bodies, F-bodies (stock for Z28 '91-'92 ?), and S10s. They are not too expensive.
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Tue Apr 03, 2012 12:41 am
Interesting. If you've taken it for a test drive already, how do they ride? Can you get a side shot of how it sits stance wise?
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Tue Apr 03, 2012 12:53 am
They ride fine. Still not as firm as the 4th gen or #1's 3rd gen Camaro. I haven't pushed it very hard. I suspect even a highe rate spring would be fine.
It will take me a while to get a photo, it's dark when I get home from work. In the photo above the camera was held low so it's a bit misleading.
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Tue Apr 03, 2012 1:00 am
No problem. Theres no rush. I like how they sit. My setup is WAAAAY too low. I slam speed bumps and scrape on driveways all day long. I'm actually getting pretty tired of it now that I sold the L99 car. It looks neat, definitely helps the car handle and launch, but its just impractical for where Im at in my life. I just might get a set of these, swap those in, swap the rear ST lowering springs out with my stock SS ones. I don't look forward to dropping $300 on a complete lowering "kit" either.
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Tue Apr 03, 2012 1:43 am
You can find these for around $50 shipped. You can always cut them shorter.
Some of the rears I was looking at are around $70.
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sat Apr 07, 2012 10:57 pm
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sat Apr 07, 2012 11:50 pm
That looks perfect!
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sun Apr 08, 2012 3:13 am
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sun Apr 08, 2012 10:26 am
9C1 buckets would have fit in right at home there.
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sun Apr 08, 2012 2:32 pm
Nice!
Stripped down for the BADASS drags?
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sun Apr 08, 2012 3:08 pm
That looks awesome up front. Did you say that was 3/4 of a coil? On 9C1 springs or something else? That's right where i'd like the wagon to sit.
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sun Apr 08, 2012 8:43 pm
The front springs are Moog 5662. From what I know a wagon would sit a bit higher 'cause it has less weight on the front.
The driver's seat was rocking and it was irritating me so I thought it would be a good time to put Bonnies in. Now the passenger seat rocks but it doesn't bother me so much.
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sat Apr 14, 2012 10:09 pm
Still high in the front. It'll probably settle a little bit but I fell like I'm falling over backwards sitting in the driver's seat...
Now it feels like I'm falling over forwards!
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sat Apr 14, 2012 10:15 pm
hahaha! Try driving with SS springs with about 100k miles and one coil chopped. It handles amazing. Bumps hard too tho. I'll be putting those moogs in soon along with some belltech shocks and a set of zq8's.
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sat May 05, 2012 6:00 pm
Lowerd it another inch today.
With stock tires.
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sat May 05, 2012 6:39 pm
wagon springs with stock tires? what about the camaro springs and nascar tires? caddy springs in the back with 9c1 in the front? is it calibrated for auto cross? you should buy a miata Very Happy
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sat May 05, 2012 10:13 pm
The wagon springs have been off almost as long as it takes some members to buy and sell a car. Smile
The Camaro springs are in. I know nothing about secret NASCAR tires.
No Caddy springs. The right side is calibrated for auto cross, I have to redo the left side.
No Miata for me. I'm waiting on a tube frame for my rat rod. I placed my order a while back.
The front now sits 1-3/4" higher than the 9C1 and that's with the taller stock tires. I'm thinking maybe Moog 80108 or 5399 for the rear.
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sun May 06, 2012 1:21 am
So the wagon Springs have been off for anytime span between 5 minutes and 30 days.
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sun May 06, 2012 7:33 am
What's the rat rod your building???? Very Happy
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sun May 06, 2012 2:36 pm
I'm not actually building it. I would like to. I have collected some of the big parts.
Invoke club motto here.
My version would have a six speed and a fuel injected engine.
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sun May 06, 2012 2:50 pm
And the side view is just as awesome.
Couldnt find the post but....I drool every time I see that... tongue
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sun May 06, 2012 3:13 pm
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sun May 06, 2012 4:23 pm
If you came down to my old mans house you'd shit your pants!
What kinda stuff you need for it? My old man as a 34 chevy master and has tons of stuff or can source it out.
I also have friends/family in AZ, NM, and NV. Smile
I'm selling my 30 Plymouth, cuz. Just bought "something" else Wink Wink Wink Twisted Evil
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sun May 06, 2012 7:41 pm
I would need the body.
47 and older don't require fenders in NH.
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Mon May 07, 2012 9:10 am
That's cool, more like circle track racer than a rat rod, but I get the idea. Coupe's are hard to find around here. If you decide you'd like a sedan to chop up I'm only selling mine for $1000 and that includes the entire body, frame with straight axle, steering and linkage, some glass, and a few other odds and ends, already boxed the front of the frame and it's set up with chevy motor mounts and a crossmember to accept any GM tranny.
Just puttin it out there! Very Happy
Now back to "loving the SS"
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sun May 13, 2012 4:49 pm
Here's some doors and other stuff that I got from No Moa for the clone project.
And the instument cluster that I got from Mark. My cluster is still having problems so I'll try one more time.
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sun May 13, 2012 8:32 pm
PostSubject: Re: How I Learned to Stop Worrying and Make a 9C1 Clone of the SS   Sun May 13, 2012 9:46 pm
Awesome. Freekin awesome
Page 4 of 6Go to page : Previous  1, 2, 3, 4, 5, 6  Next
» How I Learned to Stop Worrying and Make a 9C1 Clone of the SS
» Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1
» Impala Parts
» If the bulb has gone would this make the fan stop too?
» How to stop soggy pizza
